ebinmaine 72,104 #19301 Posted June 20, 2023 7 minutes ago, Horse Newbie said: I never removed the Welch plug… I guess had I removed it, although I had no idea how, I would have had to use a new Welch plug to replace, huh ? That's correct. Generally, they are destroyed while being removed. 2 Share this post Link to post Share on other sites
lynnmor 7,753 #19302 Posted June 20, 2023 19 minutes ago, Horse Newbie said: I never removed the Welch plug… I guess had I removed it, although I had no idea how, I would have had to use a new Welch plug to replace, huh ? Drill a small hole in it being careful to limit the drill depth to the very minimum, then pry it out. Yes. you would need a new 3/8" aluminum plug. 1 1 Share this post Link to post Share on other sites
Handy Don 13,800 #19303 Posted June 20, 2023 There was dirt behind mine even after an ultrasonic bath. 2 Share this post Link to post Share on other sites
kpinnc 14,404 #19304 Posted June 20, 2023 On 6/18/2023 at 9:39 PM, davem1111 said: And curse a lot. If you can do it without cursing, I admire you. If you don't curse for religious reasons, God Bless you. I'll just say that I shouldn't curse for religious reasons. ... but, I still do. 2 Share this post Link to post Share on other sites
CasualObserver 3,410 #19305 Posted June 20, 2023 Ordered up a new fuel pump for my 416-8. This one developed a slight drip. 1 2 Share this post Link to post Share on other sites
Desko 623 #19306 Posted June 20, 2023 New aftermarket carb is installed and I must say I am impressed with how it runs! No more surging most importantly! I will most likely strip the original one down and pull all of the plugs in it and give it a thorough cleaning and keep it as a back up incase this one doesn't hold up but for under $40 it is definitely worth the try! 6 Share this post Link to post Share on other sites
sjoemie himself 3,099 #19307 Posted June 20, 2023 On 6/3/2023 at 8:36 PM, Tractorhead said: They hack more instead of they cut. Thanks for posting the update. Pretty tall grass and the mower seems to cut well. About hacking the grass: perhaps you could try to choose a lower gear to give the blades a bit more time to cut. or try to speed up the rpm's of the mower to give it more chance to cut. I've assembled a few Claas disc mowers in the past weeks and they cut with 1000 pto rpm and i'm pretty sure the mowerdrums turn even faster. Please keep us posted. Greetings from the Netherlands, Mark 2 Share this post Link to post Share on other sites
ineedanother 1,665 #19308 Posted June 20, 2023 7 hours ago, Horse Newbie said: I never removed the Welch plug… I guess had I removed it, although I had no idea how, I would have had to use a new Welch plug to replace, huh ? I gently punch an awl through them and pry them out, being careful not to drive it into the casting behind. They are cheap to buy, usually in packs of 10 on the and installation is simple. Google it, there are some good tutorials on video. What I have found lately is that even with relatively new carbs, is that fuel lines disintegrate from the inside because of the ethanol and small pieces find their way into the drillings and jets. That is something compressed air takes care of during a cleaning or rebuild as opposed to the corrosion that ultrasonic cleaners and solvents take care of. All of those drillings have a purpose. I now move the fuel filter as close to the carb as possible and replace fuel lines every couple years. 2 2 Share this post Link to post Share on other sites
ebinmaine 72,104 #19309 Posted June 21, 2023 2 hours ago, ineedanother said: usually in packs of 10 on the You wouldn't happen to know the right size Welch plug for a 70s Kohler carb? 1 Share this post Link to post Share on other sites
ineedanother 1,665 #19310 Posted June 21, 2023 34 minutes ago, ebinmaine said: You wouldn't happen to know the right size Welch plug for a 70s Kohler carb? I don't. I don't have any here right now or I would measure one. I think they're larger than what I have, probably 7/16 or 11mm but don't bank on that. I need to order some. 2 Share this post Link to post Share on other sites
Wvtroutbum81 266 #19311 Posted June 21, 2023 Put a new brake band and shifter boot on the old 312-8. Also changed the water in the transmission😁 9 Share this post Link to post Share on other sites
ebinmaine 72,104 #19312 Posted June 21, 2023 26 minutes ago, Wvtroutbum81 said: Put a new brake band and shifter boot on the old 312-8. Also changed the water in the transmission😁 You add some fresh caramel did ya?? 2 Share this post Link to post Share on other sites
ccs002 79 #19313 Posted June 22, 2023 (edited) Got this B-100 Automatic I picked up recently back together. Someone managed to shear all the teeth off both of the sun gears that drive the axles 😬. Edited June 22, 2023 by ccs002 Added another picture of the tractor when I got it. 1 9 Share this post Link to post Share on other sites
D_Mac 9,299 #19314 Posted June 22, 2023 (edited) Did some detailing on the FREE10-8 this morning. Coming along nicely. Talked to @Vinylguy yesterday about my custom decals. He should have them done and shipped to me by Monday. If any of you are even even thinking about decals, either factory originals, or a set of customs, @Vinylguy is the best in the business. Great quality and affordable prices. I have purchased several sets from him and he has never disappointed. Can't wait to get them on. I guess I should drag the deck out of the shed and give it a once over. I have no plans on painting it. I fear if I drag it out of the shed those plans might change. Edited June 22, 2023 by D_Mac 6 3 Share this post Link to post Share on other sites
ccs002 79 #19315 Posted June 22, 2023 Was cleaning up parts and tools from working on the B100 Auto and grabbed a picture of the wiped out axle gears along with the homemade lead wheel weights that no doubt helped make them that way. 2 Share this post Link to post Share on other sites
ebinmaine 72,104 #19316 Posted June 22, 2023 49 minutes ago, ccs002 said: Was cleaning up parts and tools from working on the B100 Auto and grabbed a picture of the wiped out axle gears along with the homemade lead wheel weights that DID NOT help make them that way. @ccs002 Those stripped gears are almost definitely the result of someone using improper methods to attempt removal of the rear hubs. The hubs MUST be pulled using a good quality hub puller that is NOT a standard 3 jaw type. MANY times I've seen pics and in person where folks use a hammer to remove the hubs. This destroys the axles as your machine has experienced. Lots of folks run lots of weight and never have issues. Those gears are destroyed by an outward motion. Heavy weights produce a downward motion. 1 Share this post Link to post Share on other sites
WHX?? 51,562 #19317 Posted June 23, 2023 46 minutes ago, ebinmaine said: @ccs002 Those gears are destroyed by an outward motion. Heavy weights produce a downward motion. How do you figure EB... I would say 🔨 out on the hubs would break them c clips first? One side and a PO would have learned the lesson? Can't tell but looks like both sides are mangled. Something get in the diff @ccs002? What did the pinions look like? 1 Share this post Link to post Share on other sites
ebinmaine 72,104 #19318 Posted June 23, 2023 8 minutes ago, WHX?? said: How do you figure EB... I would say 🔨 out on the hubs would break them c clips first? One side and a PO would have learned the lesson? Can't tell but looks like both sides are mangled. Something get in the diff @ccs002? What did the pinions look like? Looks to me like someone tried one side - failed to remove - and continued to the other ... I've had transmissions apart with only one bad, but definitely also seen damage to both sides. 2 Share this post Link to post Share on other sites
ccs002 79 #19319 Posted June 23, 2023 6 minutes ago, WHX?? said: How do you figure EB... I would say 🔨 out on the hubs would break them c clips first? One side and a PO would have learned the lesson? Can't tell but looks like both sides are mangled. Something get in the diff @ccs002? What did the pinions look like? WHX?? The pinions were all pretty beat up, I was guessing from eating all the teeth of those gears. I was guessing jerking something with a chain caused the damage as the hitch pin was very bent but now I'm not as sure. Someone had replaced the LH hub and it looks practically brand new. The keyway on both sides were badly worn and looked like it may have sheered a key or two along the way. 1 1 Share this post Link to post Share on other sites
ebinmaine 72,104 #19320 Posted June 23, 2023 10 minutes ago, WHX?? said: How do you figure EB... I would say 🔨 out on the hubs would break them c clips first? One side and a PO would have learned the lesson? Can't tell but looks like both sides are mangled. Something get in the diff @ccs002? What did the pinions look like? You certainly do raise a valid point of wondering if there's foreign matter in the differential too. 1 Share this post Link to post Share on other sites
ebinmaine 72,104 #19321 Posted June 23, 2023 1 minute ago, ccs002 said: The pinions were all pretty beat up, I was guessing from eating all the teeth of those gears That's a good guess 1 Share this post Link to post Share on other sites
WHX?? 51,562 #19322 Posted June 23, 2023 21 minutes ago, ccs002 said: WHX?? The pinions were all pretty beat up, I was guessing from eating all the teeth of those gears. I was guessing jerking something with a chain caused the damage as the hitch pin was very bent The keyway on both sides were badly worn and looked like it may have sheered a key or two along the way. Eicch ... sounds like a clear cut case of animal abuse then... I would notify PETA... Hub keyways are shot I can fix them. 2 Share this post Link to post Share on other sites
ebinmaine 72,104 #19323 Posted June 23, 2023 26 minutes ago, ccs002 said: WHX?? The pinions were all pretty beat up, I was guessing from eating all the teeth of those gears. I was guessing jerking something with a chain caused the damage as the hitch pin was very bent but now I'm not as sure. Someone had replaced the LH hub and it looks practically brand new. The keyway on both sides were badly worn and looked like it may have sheered a key or two along the way. Pop up some pics of the transmission guts and we can see just what ya need. Share this post Link to post Share on other sites
8ntruck 7,707 #19324 Posted June 23, 2023 I got around to installing the new battery in Clyde. He fired right up, and the voltage at the battery was the same as when he was not running. Not good. Started tracing wires and discovered that the voltage regulator plug was not plugged into the regulator! Well, that would explain why the old battery was looking like wasn't holding a charge. The voltage checked a little higher when running after connecting the regulator. The meter I have available is an ancient, small analog VOM. Not sure about its accuracy. I'll have to update that piece of equipment and take another check. While I was behind the dash, I pulled the hour meter to check it out on the bench. It has not been connected since I got the tractor. Hooked it up and discovered that it works. Cool! I'll clean it up and reconnect it in the tractor. 5 Share this post Link to post Share on other sites
kpinnc 14,404 #19325 Posted June 23, 2023 1 hour ago, WHX?? said: How do you figure EB... I would say 🔨 out on the hubs would break them c clips first? Nope. It will shear the spline ends from the axle. Seen it several times. I'd be curious about the condition of both the axle and differential bearings. Likely the result of a case full of water for a very long time. Axle bearings corrode first, then begin to fail. This allows for misalignment of the axles in the diff end cap. Crunch and grind... 4 Share this post Link to post Share on other sites
