ebinmaine 80,438 #19176 Posted June 4, 2023 27 minutes ago, davem1111 said: She followed me home today.... REALLY looking forward to seeing how this one goes. 1 1 1 Share this post Link to post Share on other sites
davem1111 2,320 #19177 Posted June 5, 2023 6 hours ago, ebinmaine said: REALLY looking forward to seeing how this one goes. Me too, man! So, I get the feeling there will be tears shed if I decided to part this 520-8 out, so I'd like to fix it up. But so far I've only done some half-a$$ed rattle can painting. If I'm going to do this one I'd like to do a decent job, but don't have the experience. I know this is the right place for advice on restorations, so I'm hoping to get some good advice (but I need to do it within budget, which right now is pretty small. Maybe I can sell the 416-H I have to fund it. So far all I've done is pulled the deck and sprayed some PB Blaster on the blade nuts. The spindles seem to be in good shape, so that's a big plus. It's missing the deck belt covers but I have a spare pair from another 48" SD that was too far gone to rescue. Mostly I need advice on proper rust removal, prep and painting of the tins. I have a cheap air gun from Harbor Freight and a mid-sized compressor, and a can of Regal Red I bought when Rural King was out of rattle cans but had that. Haven't tried it yet. I'd like to get a really nice gloss on this baby. Also, need to replace the starter relay, and the engine is doing something weird where the governor keeps revving and dropping over and over again, mostly at low throttle. Hoping it's just the carb. Tires are dry rotted but they all hold air except the right front. Maybe I'll start a restore thread on this. I may do some minor work, get it running well, and sit on it till I move and retire in a few years. BTW, it only has about 620 hours on it. 3 2 Share this post Link to post Share on other sites
c-series don 12,375 #19178 Posted June 5, 2023 @davem1111 I’ve now done three frame up restorations with the guidance and help of my brother. He is a perfectionist in the trade. One of the things I learned from him is it’s all in the prep. He won’t paint anything until it’s properly prepared. Pretty much everything is glass beaded or sand blasted down to bare metal. Then a good primer that is sanded until it’s baby’s ass smooth. Paint, wet sand and clear coat. Yes it’s a lot of work but the end result is worth the effort. Don’t get me wrong, not everything I paint is done to this extreme. However you can’t expect good results without proper preparation. It’s unfortunate that since the early eighties and especially into the nineties Wheel Horse didn’t prime or prep the metal properly. This is why you see paint peeling off in sheets. You didn’t see that with the older tractors, it basically had to ware off!! Didn’t peel. 4 1 Share this post Link to post Share on other sites
ebinmaine 80,438 #19179 Posted June 5, 2023 6 hours ago, c-series don said: since the early eighties and especially into the nineties Wheel Horse didn’t prime or prep the metal properly. This is why you see paint peeling off in sheets. You didn’t see that with the older tractors, it basically had to ware off!! Didn’t peel That's when the gummint mandated Low VOC paint came on the scene. It was extremely difficult for manufacturers to get most paints to stick. SOOOOO many issues...... 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,070 #19180 Posted June 5, 2023 1 hour ago, ebinmaine said: gummint Spell check...... gumit as in gum it up. 2 Share this post Link to post Share on other sites
Ed Kennell 47,070 #19181 Posted June 5, 2023 10 hours ago, davem1111 said: governor keeps revving and dropping Common dirty carb symptom on the Onans. 1 1 Share this post Link to post Share on other sites
8ntruck 9,240 #19182 Posted June 5, 2023 Maybe a leak in the 2 piece intake manifold on the surging Onan? 1 Share this post Link to post Share on other sites
davem1111 2,320 #19183 Posted June 5, 2023 6 hours ago, Ed Kennell said: Common dirty carb symptom on the Onans. 1 hour ago, 8ntruck said: Maybe a leak in the 2 piece intake manifold on the surging Onan? Two very likely culprits - will be checking those out closely. I'm wondering if it's worthwhile to spray the carb, or should I just tear it down to clean it? I've done this to lots of carbs. However, I've rarely rebuilt a carb, and I'm wondering how you know it's needed (other than the obvious like gummed up beyond cleaning, messed up jets, etc.) ? Or are those the only times it's necessary, otherwise a good cleaning will do the trick? Share this post Link to post Share on other sites
ebinmaine 80,438 #19184 Posted June 5, 2023 3 minutes ago, davem1111 said: rebuilt a carb, a good cleaning These two things should be considered identical. The same. Interchangeable. "A good cleaning" should include removing the bowl and replacing that gasket at the very least. While you're in there you might as well throw a new needle and seat and finish doing the rest of the job. In the case of an Onan 20 to clean out the bowl you need to split the carb. I've only done a couple but it's super easy. What I understand on those engines the manifold is far more of a concern than the carburetor as far as disassembly. 1 Share this post Link to post Share on other sites
lynnmor 9,022 #19185 Posted June 5, 2023 Spraying an assembled carburetor will do exactly nothing. A Nikki carburetor used on Wheel Horse Onans needs to be taken apart. You can try removing the top of the carburetor while in place, but be careful that nothing falls inside. Often this shortcut will get it going with no purchase of parts. If you want to do a complete cleaning, the intake with the carburetor needs to be pulled. With the intake off, remove the carburetor from it and inspect the intake for leaks between the two halves as well of cuts in the edge where heat shields may have been rubbing. Leaks between halves are rare, cuts in the edge happen often. If you have those cuts, cut some clearance in the heat shields. There is a welch plug just above the idle mixture screw that you can pull to clean behind it, or try blasting holes to flush it out, often it is clean behind it if you want to take a chance. Be sure that you have new genuine Onan gaskets and a small 1/4” drive torque wrench for reassembly. I always suggest a valve adjustment when you go to the work of removing the intake. Also it is a good time to bead blast the exhaust and paint with a high temperature paint. Depending on the year you may need two or three gaskets for the valve covers and two exhaust gaskets. 1 1 1 Share this post Link to post Share on other sites
ranger 1,862 #19186 Posted June 5, 2023 Hooked up the broadcaster to the C121, ready to overseed the paddocks after the hay has been cut and the buttercups sprayed. Also been busy machining the double pulley on the 36” RD deck, due to a broken lower flange, and unable to locate a replacement over here. 2 8 Share this post Link to post Share on other sites
ebinmaine 80,438 #19187 Posted June 5, 2023 Many moons ago I thought it would be neato to have a mid mount grader blade. @Chris G helped me out with sourcing one. Got it here. Showed it to the BBT Trina person and immediately lost possession of said neato to have mid mount grader blade. But..... She does GREAT work with it maintaining our front dooryahd. I mentioned the other day we'd had some heavier than normal water flows screw up the driveway. Here's what it looks like after she rode around on her Tractah for an hour or so.... 4 8 Share this post Link to post Share on other sites
BrianKoch 370 #19188 Posted June 6, 2023 More chore work! 2 3 Share this post Link to post Share on other sites
lynnmor 9,022 #19189 Posted June 6, 2023 50 minutes ago, ebinmaine said: Many moons ago I thought it would be neato to have a mid mount grader blade. @Chris G helped me out with sourcing one. Got it here. Showed it to the BBT Trina person and immediately lost possession of said neato to have mid mount grader blade. But..... She does GREAT work with it maintaining our front dooryahd. I mentioned the other day we'd had some heavier than normal water flows screw up the driveway. It appears like the highway department is donating the bulk of the water. Can you get your road grading department to do some creative work so that the water can find a new home? 1 Share this post Link to post Share on other sites
ebinmaine 80,438 #19190 Posted June 6, 2023 25 minutes ago, lynnmor said: It appears like the highway department is donating the bulk of the water. Can you get your road grading department to do some creative work so that the water can find a new home? Yeah they're gonna have to do some ditch creation and maintenance across the street. Share this post Link to post Share on other sites
Sparky-(Admin) 26,242 #19191 Posted June 7, 2023 New “e” rated fuel lines on the B-80 today … used the clear/yellow line only from the pump to the carb. 7 3 Share this post Link to post Share on other sites
dotcomdz 49 #19192 Posted June 7, 2023 I spent 2 days cleaning up, tuning up, greasing up the commando 800 I had listed for 150.00 I was amazed at how strong this motor runs afterwards. I knew it ran but I hadn't done an effort with it. So I changed the listing 400 obo and there is video on wheelhorsefanatics also its on market place since can't post video here if anyone's interested. Then if I can get rid of it and another brand one I have. I think I can pick up a 520H with snow thrower deck and blade. It could be my keeper. 2 Share this post Link to post Share on other sites
WHGuy413 2,859 #19193 Posted June 8, 2023 Took a ride with my buddy this evening. He purchased his first Wheel Horse tonight. I think it’s a 551 with the wrong engine. Hoping he joins here. His son has been talking non stop about them since he drove one of my sons tractors a few weeks ago at the show we went to. 1 5 Share this post Link to post Share on other sites
johnnymag3 2,646 #19194 Posted June 8, 2023 On 6/6/2023 at 8:41 PM, Sparky said: used the clear/yellow line only from the pump to the carb No clamps??? I see seepage in your future...and maybe a fire on hot items....you may want to add at least spring clamps.... Just a suggestion.... john 2 Share this post Link to post Share on other sites
squonk 47,974 #19195 Posted June 8, 2023 I would throw that yellow line as far as I could! 1 Share this post Link to post Share on other sites
rjg854 13,329 #19196 Posted June 8, 2023 Why do you say that Mike? I've had it on a couple of my tractors for better than 2 years with no problems. 2 Share this post Link to post Share on other sites
ebinmaine 80,438 #19197 Posted June 8, 2023 Just now, rjg854 said: Why do you say that Mike? I've had it on a couple of my tractors for better than 2 years with no problems. I can't speak for Mike but I've had that yellow line on couple tractors. It went brittle and stiff after about 2 seasons. That's using strictly non ethanol gas. I've since switched to the blue line. Better... but it isn't the solution. Maybe 3 to 4 years. Share this post Link to post Share on other sites
rjg854 13,329 #19198 Posted June 8, 2023 I have noticed that it became stiff, but it doesn't leak. I may have to change them once I change the filter, but my tractors don't get that many hours on them over a season because I have so many. Each has it own job. I change gas filters like I change hydro filters, about every 100 hours. 2 Share this post Link to post Share on other sites
BrianKoch 370 #19199 Posted June 8, 2023 (edited) Gentlemen, It appears I have lost my mower deck lift rod … Does any one have an extra rod kicking around I could purchase? I have the trunnion and nut, just can’t find the rod! Thanks! Edited June 8, 2023 by BrianKoch Share this post Link to post Share on other sites
squonk 47,974 #19200 Posted June 8, 2023 15 minutes ago, rjg854 said: Why do you say that Mike? I've had it on a couple of my tractors for better than 2 years with no problems. They usually get rock hard and split at the worst possible time 1 Share this post Link to post Share on other sites
