EB-80/8inPA 1,981 #16001 Posted June 5, 2022 On 5/29/2022 at 8:08 AM, EB-80/8inPA said: found the air cleaner gasket was messed up, too. I managed to fashion one out of some 40mil EPDM membrane I was a little concerned about using this material but assumed it wouldn’t be in contact with gasoline, and it was all I had on hand, anyway. Well it was getting gassed and started failing fast. It’s always good to understand the compatibility of materials in contact, but also important is to keep some gasket material on hand for those unforeseen emergency repairs! Question: Is it normal for the air cleaner gasket to be exposed to gasoline sitting in front of the choke? Is this indicative of a carburetor issue? Share this post Link to post Share on other sites
Stormin 9,987 #16002 Posted June 6, 2022 This morning I refitted the finger bar, sickle bar to you lads States side, to the C-81 now it's trans' is fixed. Everything was working fine so decided to have a go at an overgrown section of the bridleway. One pass down then back up. That was then Murphy decided to put a spoke in. The finger bar came loose on the gearbox. Only one bolt was stopping it from falling off completely. And yes! I had tightened them. OK then! I'll fit new bolts and this time I'll remember to use thread locker. Murphy struck again. I was rather short on imperial bolts of the correct size. So paid a visit to the local smithy. I wasn't holding out much hope, but in old stock the required bolts were obtained. Put everything back together, this time using thread locker. So lets have another test. That Murphy was having a field day. Tractor wouldn't start. Flat battery. I had left the ignition on. Battery now on charge, but things will have to wait till Wednesday 1 1 5 Share this post Link to post Share on other sites
Fishroe 261 #16003 Posted June 6, 2022 Sounds like something I would do 1 1 Share this post Link to post Share on other sites
ebinmaine 77,364 #16004 Posted June 6, 2022 1 minute ago, Fishroe said: Sounds like something I would do Oh yeah me too. Absolutely. Share this post Link to post Share on other sites
rjg854 12,847 #16005 Posted June 6, 2022 Now that my kitchen is done I can start working on the 1045 again. So today I attacked the rear hubs. The hubs were shot. The wheels were swinging back and forth on the axle but surprisingly the slot in the axle was in good shape. I had a set of hubs on the shelf so I put those on and before I did that I put studs in, so I could use lug nuts instead of just the studs like it originally came with. Obviously the tractor needs a lot of cleaning up but that will come after I work all the rest of the bugs out of it. 13 Share this post Link to post Share on other sites
Stormin 9,987 #16006 Posted June 7, 2022 Change of plans today so back to the C-81. Battery fully charged so lets start her up. Not to be. Starter whirling round but not engaging. Murphy strikes again. Easy diagnosis. Sticking bendix. Off with the motor and a squirt or two of brake cleaner and freed up nicely. Replaced and the tractor fired up straight away. 9 Share this post Link to post Share on other sites
rjg854 12,847 #16007 Posted June 7, 2022 Worked on the 1045 again today. I tightened up the steering fan gear on the bar that moves the tie rods. Had to remove the the 2 roll pins and drill the holes for larger roll pins. 8 Share this post Link to post Share on other sites
Evguy 566 #16008 Posted June 8, 2022 I had tried to find replacement seat springs for the seat tray to no avail. Finding the correct spring so seat switch would work was giving me fits. I went to garage and noticed an old dead Briggs twin, I took the valve springs and retainers and bolts and viola, they worked! I just need to add some rubber bumpers, but they are what I needed. I like to recycle stuff! 2 3 Share this post Link to post Share on other sites
Handy Don 15,951 #16009 Posted June 8, 2022 14 hours ago, rjg854 said: I tightened up the steering fan gear on the bar that moves the tie rods. Had to remove the the 2 roll pins and drill the holes for larger roll pins. I had the same problem, but realized that a larger hole in the lower steering shaft would leave less metal at the point of contact. I had seen that later tractors have this joint welded so that became my inaugural use of my new welder. No wiggle. 3 Share this post Link to post Share on other sites
rjg854 12,847 #16010 Posted June 8, 2022 6 hours ago, Handy Don said: I had seen that later tractors have this joint welded so that became my inaugural use of my new welder. No wiggle. I considered that myself, but this is how the service bulletin suggested as the fix. Today I repaired a loose steering arm with the same process. Put a newer pepper pot muffler on and that takes care of the things that needed attention. Then gave it a MMO rubdown, really improved the appearance. I replaced the seat with the style that was originally on it. Now just have to paint the wheels. 6 7 2 Share this post Link to post Share on other sites
SylvanLakeWH 30,598 #16011 Posted June 8, 2022 @rjg854 looking good!!! 1 1 Share this post Link to post Share on other sites
squonk 45,539 #16012 Posted June 8, 2022 4 minutes ago, rjg854 said: I considered that myself, but this is how the service bulletin suggested as the fix. Today I repaired a loose steering arm with the same process. Put a newer pepper pot muffler on and that takes care of the things that needed attention. Then gave it a MMO rubdown, really improved the appearance. I replaced the seat with the style that was originally on it. Now just have to paint the wheels. Got everything good and Tight? 1 Share this post Link to post Share on other sites
rjg854 12,847 #16013 Posted June 8, 2022 I'm happy with it 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #16014 Posted June 8, 2022 (edited) Today, I replaced the axle seal & idler pulley along with put a new drive belt on my 314-8. After that I finished up running quick disconnect battery cables to the rear hitch. Edited June 8, 2022 by OldWorkHorse 7 7 Share this post Link to post Share on other sites
ebinmaine 77,364 #16015 Posted June 8, 2022 4 minutes ago, OldWorkHorse said: drive belt How's that WHEELHORSE BRAND belt? 1 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,807 #16016 Posted June 8, 2022 @OldWorkHorse That is a darn handy looking setup sir! Nice rig! 1 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #16017 Posted June 8, 2022 35 minutes ago, OutdoorEnvy said: @OldWorkHorse That is a darn handy looking setup sir! Nice rig! Thank you! 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #16018 Posted June 8, 2022 1 hour ago, ebinmaine said: How's that WHEELHORSE BRAND belt? It's amazing that new belt with the I forgot to mention new clutch spring I added thing grips and rips! All new horse now haha. Got to get use to it again 1 1 Share this post Link to post Share on other sites
mrc 1,052 #16019 Posted June 10, 2022 GREAT trailer oldworkhorse!!! 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #16020 Posted June 11, 2022 Not much pulled them out of the stables for some fresh air. 2 7 Share this post Link to post Share on other sites
ebinmaine 77,364 #16021 Posted June 11, 2022 4 minutes ago, OldWorkHorse said: Not much pulled them out of the stables for some fresh air. 4 minutes ago, OldWorkHorse said: Steve which of those run n drive? Is the 1257 going yet? Share this post Link to post Share on other sites
OldWorkHorse 3,130 #16022 Posted June 11, 2022 4 minutes ago, ebinmaine said: Steve which of those run n drive? Is the 1257 going yet? All but the 1257Heavy haha :/ soon tho! 1 Share this post Link to post Share on other sites
ebinmaine 77,364 #16023 Posted June 11, 2022 Just now, OldWorkHorse said: All but the 1257Heavy haha :/ soon tho! Toss it the trailer bub. We'll have it cookin in no time. 1 Share this post Link to post Share on other sites
ebinmaine 77,364 #16024 Posted June 11, 2022 (edited) Excellent busy day around the EB/BBT acreage today. General yard duty stuff. Moved wood. Split wood. Chipper shredder got some activities. One of the things I've always found interesting about Trina and I is how much we think alike. Earlier today I was out in the forest and took this pic. A bit if time later she's up front by the shed and sends me this. Neither one knew the other one had done that... 🤪 Here's a few more..... And a video... Edited June 11, 2022 by ebinmaine 5 5 Share this post Link to post Share on other sites
JPWH 6,542 #16025 Posted June 11, 2022 I removed the ram pac hydraulic pump and installed the rebuilt pump and changed the hydraulic cylinder out with a rebuilt one. No more leak down or hydraulic fluid leaks. It looks like the pump shaft seal was leaking on the ram pac. I opened it up and found a broken spring. 7 Share this post Link to post Share on other sites
