ebinmaine 80,808 #15551 Posted May 2, 2022 11 minutes ago, Dan.gerous said: Are they sleeves that go over the original axles? Guess you weld them on? These are standard trailer hubs that are cut close to where the seal rides then bored down the middle 3/4" to accept the Wheelhorse spindles. They could be welded. We used J. B. Weld to hold them together. 2 1 Share this post Link to post Share on other sites
CodyP 51 #15552 Posted May 2, 2022 I'll be running a 14 mile journey to work and back on a rocky dirt road I just need at this point a two different pullys for more speed right now I got a 6 in front and 4 in the back so I'm only going 10mph I had the stock tires but one of each side went flat so I'm looking to replace them with this suitable task because I don't know squat about tractors but I know my way around the engine today I greased the steering changed the oil and topped off diff now I'm trying to break a bead on a tire I found out back just to have air in the fronts while I look to replace the back 2 with suggested tires from you fellas 3 Share this post Link to post Share on other sites
Thor27 892 #15553 Posted May 2, 2022 imho, you place a lot of faith in that glue... Would it give you peace of mind to drill just one hole and a quick plug weld. Probably be fine, my luck would have it fail as far from the house as possible with the chipper on the front, and it seems you venture far into the woods, your mileage may vary 4 Share this post Link to post Share on other sites
balconio 606 #15554 Posted May 2, 2022 (edited) Both of these have "12hp" engines, both are gear driven, and both are from the HW Bush era. But one is a toy and the other is a tool. The back tires on the little guy are smaller than the front tires on the big guy lol. Both are fine machines, I'm going to start having my 12yo mow on the little Yard Pro which just got a new ignition coil. I also changed up my steel winch cable for a poly winch rope with a nice new hook and rubber stopper. We'll see how it holds up but I look forward to not having my hands chewed up by the cable. Edited May 2, 2022 by balconio 7 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15555 Posted May 2, 2022 7 hours ago, ebinmaine said: These are standard trailer hubs that are cut close to where the seal rides then bored down the middle 3/4" to accept the Wheelhorse spindles. They could be welded. We used J. B. Weld to hold them together. Thanks, its a modification I want to make but had no clue where to start 2 Share this post Link to post Share on other sites
ebinmaine 80,808 #15556 Posted May 2, 2022 25 minutes ago, Dan.gerous said: Thanks, its a modification I want to make but had no clue where to start I'll get some pics for you of all the parts used. 2 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15557 Posted May 2, 2022 13 minutes ago, ebinmaine said: I'll get some pics for you of all the parts used. Yes please, that will help a lot. Getting the diesel project back underway with the C-161, almost a waste with the Hydro but I have further plans for it that will require the hubs to be beefed up 1 1 Share this post Link to post Share on other sites
ebinmaine 80,808 #15558 Posted May 2, 2022 8 hours ago, Thor27 said: imho, you place a lot of faith in that glue... Would it give you peace of mind to drill just one hole and a quick plug weld. Probably be fine, my luck would have it fail as far from the house as possible with the chipper on the front, and it seems you venture far into the woods, your mileage may vary Oh, my luck runs the same! 😀 I've seen good results as far as J B holding and this application requires only to keep the stub in place but little to no actual pressure is on the glue. I'm doing it kind of as an experiment to see just how rugged the stuff is. If it fails I'll run a small bead of weld around the part where the spindle connects to the stub. 4 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15559 Posted May 2, 2022 8 hours ago, CodyP said: I'll be running a 14 mile journey to work and back on a rocky dirt road I just need at this point a two different pullys for more speed right now I got a 6 in front and 4 in the back so I'm only going 10mph I had the stock tires but one of each side went flat so I'm looking to replace them with this suitable task because I don't know squat about tractors but I know my way around the engine today I greased the steering changed the oil and topped off diff now I'm trying to break a bead on a tire I found out back just to have air in the fronts while I look to replace the back 2 with suggested tires from you fellas This wheelhorse was geared up for about + 40mph. It had direct drive to a solid rear axle and a motorbike disc brake. I didn't build it, brought it already converted, but there is a good guide on Facebook from a young guy that built one from scratch. 3 2 Share this post Link to post Share on other sites
Bill Winn 157 #15560 Posted May 2, 2022 On 4/30/2022 at 9:31 PM, JPWH said: Finished the 3 point hitch and subsoiler then gave the 953 a little workout in hard red clay. Did this particular Horse come with a 3-point or did you fabricate it from scratch? 1 Share this post Link to post Share on other sites
Desko 686 #15561 Posted May 2, 2022 Did some work on the 520-8 this evening while I had a little time. I started off with a new 5 pin plug and spades for the key switch. Then I moved onto the parking brake wiring and repaired that. I'm waiting on the new flag connectors for the clutch switch which I was able to cross to a 3 pin GE fridge light switch since they are nla from toro. I also repaired the hood corner since the spot welds broke out and it was separating but I still have to fix the dent under the headlights yet but haven't come up with a good idea that won't mess up the ribbing of it. Also is there anyone that keeps a record of the build date/unit numbers of these on here? 4 Share this post Link to post Share on other sites
JPWH 6,544 #15562 Posted May 3, 2022 (edited) 59 minutes ago, Bill Winn said: Did this particular Horse come with a 3-point or did you fabricate it from scratch? @Bill WinnI fabricated it from scratch. The build thread is 3 point hitch for Hank. Edited May 3, 2022 by JPWH 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,827 #15563 Posted May 3, 2022 On 5/1/2022 at 8:09 PM, ebinmaine said: These are standard trailer hubs that are cut close to where the seal rides then bored down the middle 3/4" to accept the Wheelhorse spindles. They could be welded. We used J. B. Weld to hold them together. Ive still Gotta get that spindle upgrade done on Dug! Have one spindle bored, and another to go. 2 Share this post Link to post Share on other sites
Stormin 9,988 #15564 Posted May 3, 2022 (edited) Last week while mowing the green, front, right engine to shaker plate bolt broke on the C125. Today I finally got to work on it. Getting the mounting bar off to remove the broken piece of bolt was a bit of work. First bonnet/hood off. No way to get a socket/spanner the the bolts holding the bar. So off with the front axle mounting. Eased up the shaker plate and inserted a small piece of wood 'twix it and chassis/frame. Then undid the bar and removed it. The broken piece was then drilled out from the under side. The drill bit actually screwed it out. Just a case of putting it all back together after that. Edited May 3, 2022 by Stormin 9 1 Share this post Link to post Share on other sites
Ed Kennell 47,459 #15565 Posted May 3, 2022 Shaker plate engine mounts.......One of Wheel Horses bad ideas. 8 Share this post Link to post Share on other sites
Stormin 9,988 #15566 Posted May 3, 2022 7 minutes ago, Ed Kennell said: Shaker plate engine mounts.......One of Wheel Horses bad ideas. I agree. You'll notice the ally spacers fitted and the washer under one of them. That's because the plate is not even. Slight twist. 3 Share this post Link to post Share on other sites
cleat 9,360 #15567 Posted May 3, 2022 My Ford LGT165 had those as well. Must have been something about that time frame. I think it was a 1979 or thereabouts.. 2 Share this post Link to post Share on other sites
peter lena 10,080 #15568 Posted May 3, 2022 @Desko noting your wiring , I regularly use spiral cable wrap on my wires to stop chafing and prevent the usual shorting issues , then I use nylon hangers secured to a nearby bolt or screw , just picked up 20 ft of 3/8" ID clear cable wrap on amazon for $ 6 . 5 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15569 Posted May 3, 2022 3 minutes ago, peter lena said: @Desko noting your wiring , I regularly use spiral cable wrap on my wires to stop chafing and prevent the usual shorting issues , then I use nylon hangers secured to a nearby bolt or screw , just picked up 20 ft of 3/8" ID clear cable wrap on amazon for $ 6 . Good idea. We used some of that the other day to help prevent one of the ropes on our rescue boat chafing through. "Ning" is the guy in the picture, great seaman and so full of energy you have a job keeping up with him! I also notice the little C125 I have been working on today has several chafed wires 4 Share this post Link to post Share on other sites
Desko 686 #15570 Posted May 3, 2022 2 hours ago, peter lena said: @Desko noting your wiring , I regularly use spiral cable wrap on my wires to stop chafing and prevent the usual shorting issues , then I use nylon hangers secured to a nearby bolt or screw , just picked up 20 ft of 3/8" ID clear cable wrap on amazon for $ 6 . Yea I'll reloom it when it's done and tie it off properly so it doesn't get caught up in the shifter or on the brake cross shaft. I try and get my stuff locally even if it costs a little more but it's worth helping the small businesses when I can. 3 1 Share this post Link to post Share on other sites
peter lena 10,080 #15571 Posted May 3, 2022 @Desko agree with that , when you can support a local store , thats a good call. good luck with that project , pete 3 Share this post Link to post Share on other sites
WHX?? 58,254 #15572 Posted May 3, 2022 Had the 1067 in the shop for some repair & upkeep. This was broken BR (before resto). I welded it but it cracked again. Made a plate to bolt over it & hopefully cures the problem. Put a new @76c12091520h seat on it. Yep It needed spacers too @Achto 7 11 Share this post Link to post Share on other sites
ebinmaine 80,808 #15573 Posted May 3, 2022 20 minutes ago, WHX?? said: Made a plate Nice work on that bub. 2 1 Share this post Link to post Share on other sites
8ntruck 9,315 #15574 Posted May 4, 2022 That looks like a fatigue crack. Was your weld repair a weld and grind smooth type of repair? In this case, the weld left a stress riser that eventually grew into another fatigue crack. If you make another similar weld repair, go over the weld with a pneumatic needle de-scaler. The de-scaler will leave a layer of compressed metal along the repair, which will help prevent another crack from forming. Then again, your plate repair is effective as well. Nicely done, too. The best repair is quite often the one that matches the resources and tools at hand. 4 4 Share this post Link to post Share on other sites
kpinnc 18,993 #15575 Posted May 4, 2022 3 hours ago, WHX?? said: Had the 1067 in the shop for some repair & upkeep. That's a very nice looking machine. 1 1 Share this post Link to post Share on other sites
