ebinmaine 75,038 #15351 Posted April 15, 2022 23 minutes ago, peter lena said: @Ed Kennell nice job on that ed ! axel hub and trans burp , good tips , that size to size hub bore is the perfect slide hammer , pete Agreed. @Ed Kennell Well done man. I've used that slide hammer hub trick too. Worked excellent. 2 1 Share this post Link to post Share on other sites
WHX?? 53,081 #15352 Posted April 15, 2022 (edited) 2 hours ago, OutdoorEnvy said: Pre Engine rebuild Ahhhhhh that 241 you went through? Dan @Achto you see what Ed did for a seal setter? We maimed one Ed cause we was being backyard hammers. Edited April 15, 2022 by WHX?? 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,909 #15353 Posted April 16, 2022 Plow came off the 308 a few weeks ago, hung the 36RD on it in preparation on the first mow . The deck is barely wider than the tires 10 2 Share this post Link to post Share on other sites
Ed Kennell 43,407 #15354 Posted April 16, 2022 6 minutes ago, WHX?? said: we was being backyard hammers. I was about to use a pipe in a pipe in a tube against some arbor spacers when I kicked the hub and the light came on. 3 2 Share this post Link to post Share on other sites
WHX?? 53,081 #15355 Posted April 16, 2022 We tried using everything we could get our mitts on. Pipes below the kitchen sink or the whole sink was next! 2 Share this post Link to post Share on other sites
ebinmaine 75,038 #15356 Posted April 16, 2022 7 minutes ago, Ed Kennell said: kicked the hub and the light came on 👢🥾 💡💡 1 Share this post Link to post Share on other sites
Ed Kennell 43,407 #15357 Posted April 16, 2022 (edited) I hear ya, I searched thru boxes of old bearings looking for a race with the correct ID and OD. Ya got any old hubs with broken flanges and bad key ways. Paint em up and sell em as axle seal installion tools. Edited April 16, 2022 by Ed Kennell 1 4 Share this post Link to post Share on other sites
dmoore 966 #15358 Posted April 16, 2022 1 hour ago, peter lena said: @dmoore thats a very sweet looking 101 ! detail care and love of the unit is very obvious , make it live on , good job , pete Thanks Pete! I went through the deck and reunited it with the tractor not since 96. It still fits! I will be letting it go soon. I don't use it anymore. 6 2 Share this post Link to post Share on other sites
WHX?? 53,081 #15359 Posted April 16, 2022 (edited) Funny you should say that Ed. A 856 I bought at auction last year came with a box of stuff. This was in it with some other home made tools. A 16 penny nail that was labeled the same way a detent spring depressor for transmissions. Guess we know the trannys been opened up before! Gotta like this PO. Edited April 16, 2022 by WHX?? speeling 2 7 Share this post Link to post Share on other sites
Renrag 69 #15360 Posted April 16, 2022 😰what I did wasn't very productive, after mowing one yard I started to mow mine, but halfway through the front the pin that holds deck bracket and front axle decided it was tired of holding, so a dropped deck and twisted axle later, I was jacking up the front end to beat everything back in line. I don't trust just a spring clip to hold it in a wore out hole that's almost the size of the clip. It drives, but idk about it holding the weight of the deck too. Do I chisel the weld and bolt it or weld a bigger washer to cover the gap around pin? 1 Share this post Link to post Share on other sites
Ed Kennell 43,407 #15361 Posted April 16, 2022 (edited) 52 minutes ago, Renrag said: the pin that holds deck bracket and front axle Where is this pin that supports the deck and axle? Pictures? What model tractor? Edited April 16, 2022 by Ed Kennell 1 Share this post Link to post Share on other sites
davem1111 2,243 #15362 Posted April 16, 2022 Today I tried to drain, flush and re-fill the trans on my 416-8 that has water in the oil, but I can't get the drain plug to come out. Walked away from that for now. Re-filled the Eaton 700 hydro with fresh oil and put it back on the 312-A. It works! Put that tractor all back together and put the 42" deck on, and did a little mowing. Lots more to do tomorrow. 3 Share this post Link to post Share on other sites
TJ5208 1,841 #15363 Posted April 17, 2022 On 4/15/2022 at 8:00 PM, Sparky said: Plow came off the 308 a few weeks ago, hung the 36RD on it in preparation on the first mow . The deck is barely wider than the tires It winked at me. 1 2 Share this post Link to post Share on other sites
Chestnut 315 #15364 Posted April 17, 2022 Woke up the FEL from its winter nap and turned over the compost piles. Tried to move and turn another pile but the ground was too wet and the tires were digging more than the loader. Half a dozen bricks in my ruts gave the rear weight box clearance so I could get out. Changed the belt on the snowblower tractor 520H. Took about four tries and I think I figured out what the PO did and corrected it. That's a story for another thread. Maybe later today in the implements and attachments section 6 Share this post Link to post Share on other sites
TonyToro 1,133 #15365 Posted April 17, 2022 Well didn’t actually work on a WheelHorse but this York rake is going on a C-145. It was rust frozen. @TonyToro Jr. and I worked everything loose then oiled and greased it up. It will be doing work shortly. 11 5 Share this post Link to post Share on other sites
Desko 636 #15366 Posted April 17, 2022 Been a minute but I swapped the mower deck back over from the 416 onto the D160 and pulled the 42" RD our of hiding and ordered a load of parts for it to get it back into shape to mow with. I was never crazy about how the 48" cut under the 416 seemed like it could have turned a little faster to cut better. It definitely turns faster under the D160 and mows cleaner. I also ordered a set of seat springs and bumpers for the 416 because it apparently never came with them judging by the lack of wear marks on the fender pan and it's a rough ride without them. Now to give them a bath and wax for the mowing season. 7 2 Share this post Link to post Share on other sites
ebinmaine 75,038 #15367 Posted April 17, 2022 5 hours ago, TonyToro said: Well didn’t actually work on a WheelHorse but this York rake is going on a C-145. Nice save on that rake. I'd like to have one here for the BBT to drag around. What's the width? 2 Share this post Link to post Share on other sites
c-series don 10,705 #15368 Posted April 17, 2022 I have that same exact rake, found it in the scrap metal pile at the dump. It was like brand new, the tines had about a half inch of paint worn off of them. It really works well. I still can’t believe someone would throw that out 🤔 4 1 Share this post Link to post Share on other sites
cafoose 3,499 #15369 Posted April 17, 2022 1 hour ago, ebinmaine said: I'd like to have one here for the BBT to drag around. 7 Share this post Link to post Share on other sites
squonk 44,775 #15370 Posted April 17, 2022 40 minutes ago, c-series don said: I have that same exact rake, found it in the scrap metal pile at the dump. It was like brand new, the tines had about a half inch of paint worn off of them. It really works well. I still can’t believe someone would throw that out 🤔 They sell for about $400 around here. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,886 #15371 Posted April 18, 2022 Finished up the flat black k181 today.It’s going in a B80 later this week. 9 7 Share this post Link to post Share on other sites
sjoemie himself 3,105 #15372 Posted April 18, 2022 18 hours ago, TonyToro said: Maybe a silly question but, what would a rake like this be used for? Leaves or gravel paths..?? 3 Share this post Link to post Share on other sites
rjg854 12,590 #15373 Posted April 18, 2022 Not so much for leaves, more for dirt and gravel grading. 3 1 Share this post Link to post Share on other sites
Sam Pasch 450 #15374 Posted April 18, 2022 Boy it's been a minute since I've been on here. Life's been busy but I'm back. Anyway I got both my horses ready for the local garden tractor jamboree coming up next month. Oil changes and such. 9 1 Share this post Link to post Share on other sites
JoeM 9,092 #15375 Posted April 18, 2022 Worked on the old iron project, one of those that looked like a easy one but is turning out to be more. Cleaned the gas tank, replaced the the threaded in cobbled up fitting with correct valve, new fuel line, and filter. Installed a replacement left axle seal, hub, key and sets. Went to town and got some non e gas. $5.18 a gallon. that price makes me feel so good! 6 Share this post Link to post Share on other sites
