TonyToro 1,190 #15101 Posted March 25, 2022 23 hours ago, squonk said: Correct length and end spark plug cables I have. Just need to know how long you want it. Points to coil is just 14 ga. wire with ring ends. You snip part of the ring end at the points to get it under the screw or use a spade end. I need a wire. Do you have extra for sale? 3 Share this post Link to post Share on other sites
TonyToro 1,190 #15102 Posted March 25, 2022 We started to weld up the hub on the commando! 7 Share this post Link to post Share on other sites
squonk 48,157 #15103 Posted March 25, 2022 8 minutes ago, TonyToro said: I need a wire. Do you have extra for sale? Yes. I just need to know how long you want it. $12 with shipping 2 1 Share this post Link to post Share on other sites
Gregor 4,848 #15104 Posted March 25, 2022 I did some un-modifying this morning. Casper is back to being good ole Casper. No more snow blowers, winches, or push button steering. I think all that extra weight was kind-a hampering his flying anyway, and the Lawn Boy snow blowers are happy just being snow blowers again. 6 1 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #15105 Posted March 25, 2022 9 hours ago, Gregor said: I did some un-modifying this morning. Casper is back to being good ole Casper. No more snow blowers, winches, or push button steering. I think all that extra weight was kind-a hampering his flying anyway, and the Lawn Boy snow blowers are happy just being snow blowers again. That pile is exactly what I would end up with if I try to modify… that’s why things work better if I just leave stuff alone… Although, I don’t see a thing wrong with modifications, just not when I do it. 1 Share this post Link to post Share on other sites
Gregor 4,848 #15106 Posted March 25, 2022 14 minutes ago, Horse Newbie said: That pile is exactly what I would end up with if I try to modify… that’s why things work better if I just leave stuff alone… Although, I don’t see a thing wrong with modifications, just not when I do it. The fun is in the trying, even if it never works. 1 1 1 Share this post Link to post Share on other sites
Fishroe 261 #15107 Posted March 26, 2022 (edited) Didn’t do anything but use it. Rented a stump grinder for the weekend with the 414-8 as an assistant A pile of sawdust builds up between the stump and stump grinder. Back stump grinder up, hop on wheelhorse and push it out the way. Beats shoveling. This grinder is pretty much brand new, only 28 hrs. 37hp briggs vanguard Have 30 some stumps to do Edited March 26, 2022 by Fishroe 10 Share this post Link to post Share on other sites
ebinmaine 80,765 #15108 Posted March 27, 2022 Got the '75 C160 Automatic head reinstalled with a new gasket and bolts. Also added a piece of sheet metal trim to the back of the hood. Looks good and tightens up the connection from hood to hood stand. 6 9 Share this post Link to post Share on other sites
Pullstart 71,312 #15109 Posted March 27, 2022 Realized I’m 8 pages whine on this thread, and had Mrs. P help me move the non-driving hilo. She spun the tires on Chloe the 953 but we got it rolling eventually! 8 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #15110 Posted March 28, 2022 Well changed the engine and gear box oils today for the 312. I did a gear box flush last year when I got it and when draining this years gear oil out it had water in it, again! I kept it inside the whole year, never used in rain or anything. Must be the condensation thing happening. I wasn't expecting it though so glad I did it again. Looks to just be an annual need at least to change it. Also took off the snow plow and put the deck back on. She's ready to go for spring/summer duties! 8 1 Share this post Link to post Share on other sites
ebinmaine 80,765 #15111 Posted March 28, 2022 19 minutes ago, OutdoorEnvy said: when draining this years gear oil out it had water in it, again! I kept it inside the whole year, never used in rain or anything. Must be the condensation thing happening How much of it was clear water and how much of it was muddy gear oil? 1 Share this post Link to post Share on other sites
JoeM 10,307 #15112 Posted March 28, 2022 Might want to do a crackle test on that oil. A good go or no go test. We did those in the field with a steel plate and a torch. Sometimes we thought it was water but just oil that had been subjected to aeration. The crackle test is a standard laboratory test to detect the presence of water in lubricating oil. A drop of oil is placed on a hot plate that has been heated to approximately 400° F. The sample then bubbles, spits, crackles or pops when moisture is present. 8 Share this post Link to post Share on other sites
JoeM 10,307 #15113 Posted March 28, 2022 made up a couple dual wheel spacers. Indoor stuff only today. 2 11 Share this post Link to post Share on other sites
WHX?? 58,218 #15114 Posted March 28, 2022 (edited) Did you go with the 6 3/4 tube length Joe? Pics once you get them on a tractor! Can you use the centers with some good blanks for a custom offset? Rebuilt a Squonky carb that the inlet that would not quit leaking by. Good thing it was easy on/off. Edited March 28, 2022 by WHX?? 3 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #15115 Posted March 28, 2022 2 hours ago, ebinmaine said: How much of it was clear water and how much of it was muddy gear oil? Not much water just thought it was there by the discoloration. Viscosity still felt fine. It was full synthetic gear oil I used. 8 minutes ago, JoeM said: Might want to do a crackle test on that oil. A good go or no go test. We did those in the field with a steel plate and a torch. Sometimes we thought it was water but just oil that had been subjected to aeration. The crackle test is a standard laboratory test to detect the presence of water in lubricating oil. A drop of oil is placed on a hot plate that has been heated to approximately 400° F. The sample then bubbles, spits, crackles or pops when moisture is present. When I did a flush last year I did 1 qt marine 90w gear oil, had an old extra laying around, and a 1 qt gasoline. Drove it for half in hour and went through all gears and ranges. Then drained over night lifted up. Then filled with full synthetic gear oil. That residue look may be from the gas from the flush a year ago? I did replace the shift boot last year as well so that was covered. I'll watch it more this next year and maybe do it twice a year if it always looks like that. 4 Share this post Link to post Share on other sites
JoeM 10,307 #15116 Posted March 29, 2022 12 hours ago, WHX?? said: Did you go with the 6 3/4 tube length Actually, 6 1/4, one set of rims is the standard WH offset and the other is 3/4". With the spacing of 1 inch between rims, (I like the way yours looked) so I tightened them up a bit. These will be going on the WH Truck replacing the 10.50's for the show this year. They will stick out past the fender and look cool. I hope! 7 1 Share this post Link to post Share on other sites
peter lena 10,076 #15117 Posted March 29, 2022 @WHX?? do you see it ? opportunity for a 5/16 vertical fuel check valve just before carb entry , EVIL ENERGY has them on line . have them on my 3 magnum engines , instant starts , no fuel drain back , only if you want to , have a good one , pete 2 1 Share this post Link to post Share on other sites
peter lena 10,076 #15118 Posted March 29, 2022 @OutdoorEnvy from the looks of your stuff , would guess that your shift boot is good ? I regularly check my trans oil , drop it on any sign of discoloration / moisture , along with a road drive flush out routine. noting your rear hitch lower slide pin, regularly give that a lubrication shot , to stop rust . also added a thin piece of anti vibration pad under , front end under trans to snug that up and, slotted hose on vertical ends on back of trans to snug that up and make it stop the shucking movement . only a suggestion . glad you changed that oil . pete 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #15119 Posted March 29, 2022 16 minutes ago, peter lena said: @OutdoorEnvy from the looks of your stuff , would guess that your shift boot is good ? I regularly check my trans oil , drop it on any sign of discoloration / moisture , along with a road drive flush out routine. noting your rear hitch lower slide pin, regularly give that a lubrication shot , to stop rust . also added a thin piece of anti vibration pad under , front end under trans to snug that up and, slotted hose on vertical ends on back of trans to snug that up and make it stop the shucking movement . only a suggestion . glad you changed that oil . pete Yes shift boot was replaced a year ago when I got it. Thanks for the tips on the other things! 2 Share this post Link to post Share on other sites
WHX?? 58,218 #15120 Posted March 29, 2022 1 hour ago, JoeM said: Actually, 6 1/4, We just don't want to hear how you cut them off twice and still too short! 1 3 Share this post Link to post Share on other sites
peter lena 10,076 #15121 Posted March 29, 2022 @WHX?? when installed vertically , arrow up to carb , that valve looks like it was made for that set up , just fits into the gap on side of carb . I also build / assemble the installation before installing it , makes it easier , pete 1 1 Share this post Link to post Share on other sites
peter lena 10,076 #15122 Posted March 29, 2022 @WHX?? scary details on the pre build set up , measure it up for close location and fit , I use those dark green spring clamps , also , use just a light film of dielectric grease on each hose to filter slide point , lets you bottom out the hose fit , then squeeze and slide on the clamps , hose and 5/16 check valve are same size, lubricant makes for a very smooth / easy slide on fit . pre built this and its a very easy installation, leave the 2 final squeeze clamps on the hose , down from slide on point , once the hose is on carb / fuel pump , squeeze clamps on into place . your done ! start up leak check , retest for start . imagine that , no more fuel drain back , it works , I use clear vinyl hose ,pete 1 Share this post Link to post Share on other sites
Lane Ranger 12,114 #15123 Posted March 29, 2022 2 hours ago, peter lena said: @WHX?? do you see it ? opportunity for a 5/16 vertical fuel check valve just before carb entry , EVIL ENERGY has them on line . have them on my 3 magnum engines , instant starts , no fuel drain back , only if you want to , have a good one , pete pete : I bought two of these today and going to try them out on your recommendation! Looks like an easy install. https://www.amazon.com/dp/B09TT4T16M/ref=cm_sw_r_awdo_66C3TS7J7R7BSD2VKPY7?psc=1 2 Share this post Link to post Share on other sites
peter lena 10,076 #15124 Posted March 29, 2022 @Lane Ranger yes they are an easy install, after I did the first one , in place , I changed that over to putting it together away from the tight spot , think about it , hoses clamped on valve , last 2 clamps in place to slide on ends , lite hose lubricant , install and test run . flow arrow on valve facing up , easy pete 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #15125 Posted March 30, 2022 (edited) Hooked up the lawn airator that I purchased on the cheap a couple weeks ago. Ran it around the back 40 a few times.I was skeptical,it did the job.The grass and weeds should appreciate it,the worms,not so much. Edited March 30, 2022 by Wheelhorse#1 9 Share this post Link to post Share on other sites
