Oldskool 6,678 #14426 Posted January 28, 2022 1 minute ago, sjoemie himself said: That looks badass! I presume this is for snow rather than dirt? Obvious newb question, I know 😇 Actually anything it was pressed against lol. At one point those front corners were used for pushing small roots and stump out of the ground. 4 2 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #14427 Posted January 28, 2022 16 minutes ago, Oldskool said: those front corners were used for pushing small roots and stump out of the ground. That's an interesting concept. Sort of a side angled ripper. How did it work? What do you have for weights and chains to put on Hiram? 1 Share this post Link to post Share on other sites
Oldskool 6,678 #14428 Posted January 28, 2022 1 hour ago, ebinmaine said: That's an interesting concept. Sort of a side angled ripper. How did it work? What do you have for weights and chains to put on Hiram? It worked pretty good. I didn't force things alot but will be doing more of it. Weights/chains. I have quite a bit. I will post some pics as things happen. 2 1 Share this post Link to post Share on other sites
Lee1977 7,785 #14429 Posted January 28, 2022 (edited) 14 hours ago, Oldskool said: Built some rear axle brackets for Hiram this afternoon. It time for him to push a plow. The deeper you make the axle brackets the higher you can lift the plow. Got some scrap steel and longer bolts. If I remember correctly you lifted that tractor. A lock pin hole to keep them closed would be good. Edited January 28, 2022 by Lee1977 4 Share this post Link to post Share on other sites
peter lena 10,076 #14430 Posted January 28, 2022 @Oldskool like the heavier grade angle steel , that strength just takes over solid control , also prefer that grade in channel steel, , made up my spiker aerators , 30 + years ago , with 6" channel , also makes a great weight tray . nice job , pete 4 Share this post Link to post Share on other sites
peter lena 10,076 #14431 Posted January 28, 2022 @Oldskool like the heavier grade angle steel , that strength just takes over solid control , also prefer that grade in channel steel, , made up my spiker aerators , 30 + years ago , with 6" channel , also makes a great weight tray . nice job , pete 2 Share this post Link to post Share on other sites
peter lena 10,076 #14432 Posted January 28, 2022 @ebinmaine morning , talking about 2 ft , and also said it would be dry and fluffy , exact oposet of our usual wet sloppy mix , should be some good plowing / blowing fun , wear a safety vest if you are road plowing , pete 2 1 Share this post Link to post Share on other sites
Oldskool 6,678 #14433 Posted January 28, 2022 21 minutes ago, Lee1977 said: The deeper you make the axle brackets the higher you can lift the plow. Got some scrap steel and longer bolts. If I remember correctly you lifted that tractor. A lock pin hole to keep them closed would be good. I did lift this tractor. I should have all kinds of height. There is a lock pin hole on those. Maybe the angle hid that. I have a double nutted bolt to go in it for now 2 1 Share this post Link to post Share on other sites
peter lena 10,076 #14434 Posted January 28, 2022 @Oldskool just thinking how about using that grade angle for a frame upgrade ? that would be a horse / tank , pete 3 Share this post Link to post Share on other sites
ebinmaine 80,767 #14435 Posted January 28, 2022 5 minutes ago, Oldskool said: double nutted bolt That's all I use on my plow tractor. No pins in my handmade brackets. Tighten it up once in the fall and it doesn't come off... 4 minutes ago, peter lena said: ow about using that grade angle for a frame upgrade @Oldskool I did exactly that on the frame to transmission attachment point on Colossus. Some point or another I'll add a forward-facing brace as more reinforcement. 1 2 Share this post Link to post Share on other sites
Oldskool 6,678 #14436 Posted January 28, 2022 2 hours ago, peter lena said: @Oldskool that would be a horse / tank , pete I hope so . I'm going to need it to get thru this next snow 3 Share this post Link to post Share on other sites
sjoemie himself 3,228 #14437 Posted January 28, 2022 6 hours ago, Oldskool said: Actually anything it was pressed against lol. At one point those front corners were used for pushing small roots and stump out of the ground. Impressive. Thinking about building a dozerblade for my tractor because implements are pretty rare around here. I would like to use it to push dirt instead of snow and use it around the house and garden. Should'nt be a problem if I understand correctly? 3 Share this post Link to post Share on other sites
Oldskool 6,678 #14438 Posted January 28, 2022 18 minutes ago, sjoemie himself said: implements are pretty rare around here. I would like to use it to push dirt instead of snow and use it around the house and garden. 18 minutes ago, sjoemie himself said: Should'nt be a problem if I understand correctly? Mine was at one time a 4 wheeler plow. Impliments are few and far between around here as well. 2 1 Share this post Link to post Share on other sites
Oldskool 6,678 #14439 Posted January 28, 2022 Todays project is moving along.. Hiram never had a lift mechanism. He does now. 2 9 Share this post Link to post Share on other sites
johnnymag3 2,646 #14440 Posted January 28, 2022 The frame to rear transmission area needs some definite improvement / bracing. I don't understand how they cheaped out on that high stress area...especially since its a rotation /pressure area, subjected to plow blades trying to rip it off when plowing snow, or pushing back a snow bank. Pulling a Tiller...or any other implement that creates drag....Needs a 45 degree angle iron added from bottom hole of the transmission mount to the frame rails !! 4 Share this post Link to post Share on other sites
Ifixoldjunk 778 #14441 Posted January 28, 2022 supposedly getting 6-10 over the weekend. After I get done plowing at work I’ll finally be able to give the single stage a good test. Make a clean spot in the yard for the dog🤣 2 2 Share this post Link to post Share on other sites
johnnymag3 2,646 #14442 Posted January 28, 2022 6-10????? Where are you in NY? 1-3 forecasted here in Hudson Valley?? Share this post Link to post Share on other sites
peter lena 10,076 #14443 Posted January 28, 2022 @Oldskool nice looking job on that , you might try some chain and cable lubricant on that winch , before the moisture gets in there. spray it on while its pulling the tractor in to it , the cable twisting , pulls and pushes the lubricant into the cable , making it supple and rust free . pete 1 1 1 Share this post Link to post Share on other sites
TJ5208 1,841 #14444 Posted January 28, 2022 Pushed 2 inches of snow today with the 520-8 4 1 Share this post Link to post Share on other sites
kpinnc 18,978 #14445 Posted January 28, 2022 2 hours ago, johnnymag3 said: The frame to rear transmission area needs some definite improvement / bracing. I don't understand how they cheaped out on that high stress area...especially since its a rotation /pressure area, subjected to plow blades trying to rip it off when plowing snow, or pushing back a snow bank. Pulling a Tiller...or any other implement that creates drag....Needs a 45 degree angle iron added from bottom hole of the transmission mount to the frame rails !! The only ones I've ever seen break were from wheelies. It's a fair bet that if you get one that is broken, that or something similar caused it. There are several folks on here however, who have made nice braces under there for just such a concern. The pic below is not mine, but a good example. 4 Share this post Link to post Share on other sites
TJ5208 1,841 #14446 Posted January 28, 2022 35 minutes ago, kpinnc said: The only ones I've ever seen break were from wheelies. It's a fair bet that if you get one that is broken, that or something similar caused it. There are several folks on here however, who have made nice braces under there for just such a concern. The pic below is not mine, but a good example. That is @Achtos tractor 5 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #14447 Posted January 28, 2022 The BBT, her mom and I brought a little firewood in from the wood storage shed to the basement. I also got a Group 51 battery stuffed into the '75 C160 Automatic. That rig is ready to go for our weekend snowstorm. ❄️ 🌨️ ❄️ 4 6 Share this post Link to post Share on other sites
johnnymag3 2,646 #14448 Posted January 28, 2022 2 hours ago, kpinnc said: The only ones I've ever seen break were from wheelies. It's a fair bet that if you get one that is broken, that or something similar caused it. There are several folks on here however, who have made nice braces under there for just such a concern. The pic below is not mine, but a good example. I can promise you...it was not from wheelies...this is an adult who was 50 when he got it....its a real bad design, and I have seen several broken....not from wheelies 2 Share this post Link to post Share on other sites
johnnymag3 2,646 #14449 Posted January 28, 2022 (edited) Its a horrible design to put all of the power to a silly little square plate with NO support... Edited January 28, 2022 by johnnymag3 2 Share this post Link to post Share on other sites
kpinnc 18,978 #14450 Posted January 28, 2022 13 minutes ago, johnnymag3 said: Its a horrible design to put all of the power to a silly little square plate with NO support... The design like any other has room for improvement. I think if it were a horrible design there wouldn't be thousands of them still working 50-60 years later. It works just fine when used for the loads it was intended for. 6 1 Share this post Link to post Share on other sites
