Achto 29,374 #13326 Posted October 26, 2021 (edited) 2 hours ago, SylvanLakeWH said: Gonna make a sissy outa that tractor... putting' her in a rack like that.. Grizzly bears hibernate. Dare ya to walk up face to face with a grizzly & call him a sissy. Edited October 26, 2021 by Achto 1 5 Share this post Link to post Share on other sites
WHX?? 51,702 #13327 Posted October 26, 2021 34 minutes ago, Achto said: It drills like butter. You will not get any curly shavings from the drill bit, only fine dust. Taps just as easy. I only drill for an 1/8" -27 pipe plug, mainly cause I ain't got a 3/8" pipe tap or a hand held drill with a 1/2" chuck. The 1/8" pipe hole works just fine. I add it to all my . I got a 1/4 and a 3/8 drill & tap just bring it over here. I also would have just put compressed air in the tranny to blow out the shavings ....and the goo that comes with it..... pics on how that pans out..... yep let's not do it over here ..... 1 2 Share this post Link to post Share on other sites
ebinmaine 72,426 #13328 Posted October 26, 2021 Bear 🐻 here. Somebody called? 1 1 Share this post Link to post Share on other sites
Pullstart 66,636 #13329 Posted October 26, 2021 8 hours ago, 19richie66 said: Ok. That’s what I was thinking. I have my wife’s 1054 set up without a release arm. I appreciate the info. “Frank” has that stuff removed as well Share this post Link to post Share on other sites
Pullstart 66,636 #13330 Posted October 26, 2021 3 hours ago, SylvanLakeWH said: @Pullstart you tellin' me WHrat WHrecker needs a nap...???!!! Gonna make a sissy outa that tractor... putting' her in a rack like that... Rylee and I had to determine the best performers in snow. Last winter, we learned that fatties don’t work well in the white stuff… no matter how cool they look! 5 Share this post Link to post Share on other sites
SylvanLakeWH 28,328 #13331 Posted October 26, 2021 1 hour ago, Pullstart said: Rylee and I had to determine the best performers in snow. Last winter, we learned that fatties don’t work well in the white stuff… no matter how cool they look! Well...OK... As long as the brains of the outfit made the decision... 1 5 Share this post Link to post Share on other sites
Bens vintage tractors 1,555 #13332 Posted October 26, 2021 Picked up some 26-12-12s for my b-160 build! 3 2 Share this post Link to post Share on other sites
ebinmaine 72,426 #13333 Posted October 26, 2021 7 hours ago, Pullstart said: Rylee and I had to determine the best performers in snow. Last winter, we learned that fatties don’t work well in the white stuff… no matter how cool they look! I run 23 x 10.50s on Cinnamon Horse. Filled. Weighted. Me. That's. Heavy. 3 hours ago, Bens vintage tractors said: Picked up some 26-12-12s for my b-160 build! Very cool. How will you go about moving the fender to add clearance? 2 1 Share this post Link to post Share on other sites
Lee1977 7,189 #13334 Posted October 26, 2021 2 hours ago, ebinmaine said: I run 23 x 10.50s on Cinnamon Horse. Filled. Weighted. Me. That's. Heavy. Very cool. How will you go about moving the fender to add clearance? All depends on what model tractor you have, The 1976 and later models you put a spacer under the fender bracket. then you will need spacers under the seat mounts. If you have a clearance problem it will be at the footrest. I had to bend mine for the 25 x 900 x 12 on my 312-8.as the uprights are not bolted to anything. 2 2 1 Share this post Link to post Share on other sites
Gregor 4,847 #13335 Posted October 26, 2021 30 minutes ago, Lee1977 said: put a spacer under the fender bracket. Wondering what, if anything, that does to your fuel tank spout. 2 Share this post Link to post Share on other sites
Pullstart 66,636 #13336 Posted October 26, 2021 6 hours ago, Bens vintage tractors said: Picked up some 26-12-12s for my b-160 build! Awesome! “Poppy” my 552 has those, they sure do roll over the big stuff well! 3 1 Share this post Link to post Share on other sites
Lee1977 7,189 #13337 Posted October 26, 2021 (edited) 23 minutes ago, Gregor said: Wondering what, if anything, that does to your fuel tank spout. By putting it under the fender bracket it raises the fuel tank also. I put a 1/8" across and spacers raising the seat and fuel tan bracket also. I inch would have cleared, but I also braced my receiver hitch off the top of the transmission I raised 1 3/4". Edited October 26, 2021 by Lee1977 4 Share this post Link to post Share on other sites
kpinnc 14,585 #13338 Posted October 26, 2021 These are 25s, with no raiser anywhere. So if you do have to add a little spacing, it should in fact be very little. On several of my tractors, I've had to put small (1/2 inch) blocks under the tank at the back under the transmission supports to keep the filler cap up, and that is with no spacing of any kind, just to make filling up easier. 1 Share this post Link to post Share on other sites
Maxwell-8 4,367 #13339 Posted October 26, 2021 On 12 inch wide, you will most likely hit the fueltank sideways or the brake, spacer will then be needed or making the stock rims wider. Share this post Link to post Share on other sites
Pullstart 66,636 #13340 Posted October 26, 2021 Quick tire change. One went soft, I pumped it up, next day… flat on the bottom again. 2 Share this post Link to post Share on other sites
Shed 249 #13341 Posted October 26, 2021 I hate when they go flat on the top over night 1 3 Share this post Link to post Share on other sites
ebinmaine 72,426 #13342 Posted October 26, 2021 24 minutes ago, Pullstart said: flat on the bottom Sooooo?? It's only one small part of the tire. 8 minutes ago, Shed said: I hate when they go flat on the top over night That's WAY worser. 4 Share this post Link to post Share on other sites
Pullstart 66,636 #13343 Posted October 26, 2021 Didn’t want to jeopardize my plans today… glad to have a spare or 20! 3 2 Share this post Link to post Share on other sites
Bens vintage tractors 1,555 #13344 Posted October 26, 2021 8 hours ago, ebinmaine said: Very cool. How will you go about moving the fender to add clearance? I usually make some small spacers that just lift the fender up an inch or 2.. I’ve fit 27s on a wheel horse before lol. 1 Share this post Link to post Share on other sites
kpinnc 14,585 #13345 Posted October 26, 2021 2 minutes ago, Bens vintage tractors said: I usually make some small spacers that just lift the fender up an inch or 2.. I’ve fit 27s on a wheel horse before lol. I can't wait for pics of this machine! 1 Share this post Link to post Share on other sites
Bens vintage tractors 1,555 #13346 Posted October 26, 2021 1 minute ago, kpinnc said: I can't wait for pics of this machine! 6 hours ago, Lee1977 said: you have a clearance problem it will be at the footrest. 1 inch fender lift and bent the foot boards out just a tiny bit to clear 27s 3 2 Share this post Link to post Share on other sites
Bens vintage tractors 1,555 #13347 Posted October 26, 2021 3 hours ago, Maxwell-8 said: On 12 inch wide, you will most likely hit the fueltank sideways or the brake, spacer will then be needed or making the stock rims wider. I’m putting them on a b series so I don’t have to worry about the tank.. however I do have some spacers kicking around if need be 1 Share this post Link to post Share on other sites
Thor27 835 #13348 Posted October 26, 2021 10 hours ago, Gregor said: Wondering what, if anything, that does to your fuel tank spout. I raised my fender 3/4" found out I couldn't get the cap off. I carefully enlarged the hole 1/4 all around with a drum sander. For those that raise the tank and all, what do you do to the rear lift cable? Share this post Link to post Share on other sites
Ed Kennell 41,801 #13349 Posted October 26, 2021 (edited) When I raised the fender on my 520, I bolted a 2" PVC cap to the fuel tank cap. Edited October 29, 2021 by Ed Kennell added pics 2 Share this post Link to post Share on other sites
Lane Ranger 11,394 #13350 Posted October 26, 2021 Put my 42 inch snowblower on my 314 50th Anniversary Wheel Horse hydro tractor with hydro lift today. This snowblower I bought two years ago and used once on my 314-8. I think it is a 1985 so maybe 36 years old but I think it just looks like new. Operates great but I am putting a new belt on it . This will be my first time using a hydro in winter so I hear you have to warm up tractor some in cold weather to get transmission fluid warmed and flowing good. I would like to hear any tips you folks that use a snowblower on a Wheel Horse hydro might have as this will be my first time! I used my old 1967 Lawn Ranger with snowblower for years but I sold her in 2020. Lots of old videos on here using that equipment. It was always fun! 5 Share this post Link to post Share on other sites
