ebinmaine 63,636 #13251 Posted October 21, 2021 4 minutes ago, adsm08 said: When I first got my 855 running I tried it around the yard, with no deck, and almost dumped myself off the back of the seat on the first launch. Front wheels were definitely off the ground,. I'd bet that near to woke you up. 2 Share this post Link to post Share on other sites
AMC RULES 36,962 #13252 Posted October 21, 2021 You improvise when the color you're looking for is unobtainable. 5 Share this post Link to post Share on other sites
19richie66 17,025 #13253 Posted October 21, 2021 22 minutes ago, AMC RULES said: You improvise when the color you're looking for is unobtainable. Walmart paint shelves are bare. Not much better in Lowes. Looks good though! 1 Share this post Link to post Share on other sites
AMC RULES 36,962 #13254 Posted October 21, 2021 Silver aluminum base with a grey primer topcoat and finished with a gloss clear coat. 2 Share this post Link to post Share on other sites
8ntruck 6,506 #13255 Posted October 21, 2021 Tinkered with my C195 this afternoon. I installed the new hydraulic unit drive belt clutch linkage bits and pieces that have been sitting on my bench for about a month. The clutch now latches in the off position. Having this layer of interlock operational increases my trust level in this machine. It is one more thing to insure that the Horse won't run off on its own when I start it. Tackled the fuel system next. Last time I used the tractor, it seemed to be running rich. I found the choke linkage was bound up, not letting the choke open all the way. The last time I ran the tractor, it ran better when the fuel pump was off, so the plan was to check the fuel pump, and float valve operation. While checking the fuel pump, I discovered that the gas tank was empty - KT19 is a hungry beast. At this point, it would fire on carb cleaner, but not run. Off with the carb and to the bench to open it up. Lots of crud in the bowl and lots of crud around the float valve. The float valve did not follow the float by gravity. Pulled the float valve seat and found it mostly clogged with some sort of goo. The carb is in pieces ready for cleaning. Got to come up with a rebuild kit. I did notice that there is a freeze pug just below the idle needle. Should I chase down a replacement plug so I can remove the one in the carb to make sure everything under it is clean? 2 Share this post Link to post Share on other sites
Handy Don 10,789 #13256 Posted October 21, 2021 7 minutes ago, 8ntruck said: .... I did notice that there is a freeze pug just below the idle needle. Should I chase down a replacement plug so I can remove the one in the carb to make sure everything under it is clean? I can only speak to the Onan twins and their carb Welch Plug removal is essential. Important passageways behind. But have the replacement on hand (and know how to install the new one! 1 Share this post Link to post Share on other sites
ebinmaine 63,636 #13257 Posted October 21, 2021 1 hour ago, 8ntruck said: Should I chase down a replacement plug so I can remove the one in the carb to make sure everything under it is clean Fair chance it could be in the carb kit. 57 minutes ago, Handy Don said: I can only speak to the Onan twins and their carb Welch Plug removal is essential. Important passageways behind. But have the replacement on hand (and know how to install the new one! This past weekend was the first time I'd ever taken a welch plug out. The Briggs carb on the big splitter was some grungy. On a Kohler carb I've always left the plugs in. I have and to clean em twice occasionally. 1 Share this post Link to post Share on other sites
adsm08 1,464 #13258 Posted October 22, 2021 3 hours ago, ebinmaine said: I'd bet that near to woke you up. It sure got the blood pumping. I grew up driving my dad's 310-8, which is a bit more nose-heavy than the 855, and also was never without a deck or plow, so nothing of that sort ever happened to me before. 2 Share this post Link to post Share on other sites
ebinmaine 63,636 #13259 Posted October 22, 2021 4 minutes ago, adsm08 said: bit more nose-heavy Trina has an 867. Iron Kohler 8 horse. Her 657 however has an aluminum Briggs 8. HUGE difference..... 1 Share this post Link to post Share on other sites
WHX?? 47,093 #13260 Posted October 22, 2021 (edited) Dan @Achto.... what about ole pale face here now.... I'm jonesin. ... I was gonna ship it off to the glue factory that's why I give it to you! Did you find the gas tank strap? We want all the details! Edited October 22, 2021 by WHX?? 1 1 Share this post Link to post Share on other sites
Achto 26,752 #13261 Posted October 22, 2021 Spent a little time with the newest member of my herd over the last couple of days. "Pale Face" as @WHX?? calls him showed up as a non-runner with a few pieces missing, most of the pieces were included with him though. Yesterday I spent some time getting the steering wheel off, installing a dash and getting the cables to move. The throttle cable had to be replaced but the choke cable was savable. Tonight I pulled the bowl off from the carb and was happy to see that it was relatively clean. After seeing this I checked the vitals, performed some field triage, and hooked up an IV bottle. I'm happy to report that the engine purrs like a kitten. I still need to flush the gas tank, replace the petcock, and finish running new fuel line. Tomorrows project. Then I can shake down the rest of the tractor. No boot on the shifter so I can imagine that the inside of the tranny will be a hot mess. 8 1 Share this post Link to post Share on other sites
WHX?? 47,093 #13262 Posted October 22, 2021 Saaaweet. . Yah tranny might need some love. She was sittin outside at my place much to my displeasure but what's a guy gonna do when he runs out of stalls? . Had pretty good luck getting all the horses running out of that score. 2 Share this post Link to post Share on other sites
WHX?? 47,093 #13263 Posted October 22, 2021 (edited) Moved some tractors, implements & engines around with the FEL tonite . My Lord how did I get along without this tractor. My back thanks it. Now all I have to do is get someone to hook and unhook for me so I never have to get off the tractor! Got some light duty forks ordered for it but on the slow boat I guess. Be nice to stack decks & motors on a pallet and pick the whole thing up. After giving it several workouts @cschannuth she does not like to back up hills with the weights we have on her despite the loaded tires. She has a tendency to dig. All soft sand around her tho and cursed to live on a hill. Forwards not much of a problem. Building a ballast box/chain box for her see out that helps. Edited October 22, 2021 by WHX?? 1 9 Share this post Link to post Share on other sites
ebinmaine 63,636 #13264 Posted October 22, 2021 34 minutes ago, WHX?? said: Forwards not much of a problem. Building a ballast box/chain box for her see out that helps You get 300 or 400 lbs back there and it'll be a tad bit betterer. 1 Share this post Link to post Share on other sites
cschannuth 3,795 #13265 Posted October 22, 2021 2 hours ago, WHX?? said: Forwards not much of a problem. Building a ballast box/chain box for her see out that helps. When I had all seven suitcase weights on there it always did really well so I think once you get some more weight back there you’ll be in good shape. Of course, my 250 pounds sitting on the seat probably didn’t hurt anything either, ha ha. 1 1 3 Share this post Link to post Share on other sites
Maxwell-8 4,271 #13266 Posted October 22, 2021 9 hours ago, AMC RULES said: Silver aluminum base with a grey primer topcoat and finished with a gloss clear coat. A always use a alloy-zinc spray and then a mettalic flake spray 3 1 Share this post Link to post Share on other sites
cblessj 88 #13267 Posted October 22, 2021 Installed a Johnny Products Uni-Sleeve on my 1968 Raider 12. Bought it for another tractor but decided to sell the other tractor and bought my Raider. I fabbed up the bracket for the switch and the hitch adapter myself. Also had to modify it slightly (had to cut notches at the top) to clear the seat/fenders when its open. 3 10 Share this post Link to post Share on other sites
squonk 39,210 #13268 Posted October 22, 2021 Ah tires don't like backing up Share this post Link to post Share on other sites
jtrosp1980 87 #13270 Posted October 22, 2021 Looks sharp 1 Share this post Link to post Share on other sites
8ntruck 6,506 #13271 Posted October 23, 2021 to the forum. Good looking machine. I tinkered some more with the C195 today. Discovered that the high speed needle is slightly bent while I was cleaning the carb. The needle valve , splash shield, and bowl gasket were still in pretty good shape, so I reassembled it and hoped for the best. I also made sure that the very fine wire handle on the float valve needle was around the tang on the float when it went back together. Mounted the carb back on the tractor and hit the starter after letting the electric fuel pump come up to pressure. The engine fired on the first or second turn of the crank. Took a parameter patrol ride around my property. Had to stop once to tweak the idle and high speed needles. Runs a whole lot better now. I even stopped and backed up to a tree to perform a 'wheel spin transmission test'. It passed. I do have an annoying rattle in the clutch lever. I think the drive belt took a set while the tractor was sitting for almost 20 years. That kink is probably what is causing the rattle. Installing a new belt won't hurt anything. 4 1 Share this post Link to post Share on other sites
Gregor 4,838 #13272 Posted October 23, 2021 14 minutes ago, 8ntruck said: I do have an annoying rattle in the clutch lever. It's a Wheel Horse trademark. 4 Share this post Link to post Share on other sites
8ntruck 6,506 #13273 Posted October 23, 2021 58 minutes ago, Gregor said: It's a Wheel Horse trademark. Did not know that. This is my first hydro. 1 Share this post Link to post Share on other sites
Lee1977 6,310 #13274 Posted October 23, 2021 (edited) 18 hours ago, Gregor said: It's a Wheel Horse trademark. The hole is worn. I had that problem, drilled it out to 5/8" and installed brass bushings. I put the bushing on the wood dowel and sawed it into.. Edited October 23, 2021 by Lee1977 1 1 Share this post Link to post Share on other sites
peter lena 8,143 #13275 Posted October 23, 2021 @TJ salyers , detail in that for lubrication , especially check tension and lubrication at chain gear box drive area , rarely serviced and dry / rusty . also went after all related linkage / movement areas , like chute rotation rod , once it started running easier , I just went after every moving point . just my own experience, pete Share this post Link to post Share on other sites
