Snoopy11 5,731 #13201 Posted October 19, 2021 1 minute ago, adsm08 said: hydrogen gas Basically what is immitted when I charge the electo golf cart... I like it! Don Share this post Link to post Share on other sites
adsm08 4,152 #13202 Posted October 19, 2021 Just now, Snoopy11 said: I don't know... but it is dry wood... 'cause Squonks can dissolve their own tears... Don I have 14 cords of dry wood and a small pile that needs to season yet, but it would probably be safe to burn if I did it one piece at a time. 1 Share this post Link to post Share on other sites
Gregor 4,847 #13203 Posted October 19, 2021 4 minutes ago, adsm08 said: I am using is just tap water and baking soda, so it's perfectly safe to just stick my bare hand in. Overnight lows are into the 40s and daytime highs are in the mid 60s, so the water is cold, but that's about it. Baking soda is sodium bicarbonate. Washing soda is Sodium carbonate. Everything I have read instructs to use "Washing Soda". BTW If you use a large battery charger, and set it at 40 amps, the water will get quite warm. 2 Share this post Link to post Share on other sites
adsm08 4,152 #13204 Posted October 19, 2021 1 minute ago, Gregor said: Baking soda is sodium bicarbonate. Washing soda is Sodium carbonate. Everything I have read instructs to use "Washing Soda". BTW If you use a large battery charger, and set it at 40 amps, the water will get quite warm. Sodium carbonate is generally considered the better of the two, but bicarbonate will work as well. It's been years since I did anything with this process, and so I had to do some research on the setup to remember how to build it. In the write-ups I read the only noticeable differences reported were that sodium carbonate worked a little faster, and the way the rust built up on the sacrificial anode was different between the two. But since the entire purpose of the compound is to make the water a better electrolyte the sodium alone should do that, however straight sodium is too corrosive. 1 Share this post Link to post Share on other sites
oliver2-44 11,184 #13205 Posted October 19, 2021 If you google E-Tank you will find lots of videos. I use Swimming Pool Ph+ since I can’t find washing soda around my area. It works good. The nice thing about an E-Tank is it will remove rust and if you let it cook longer the remains paint will come off with a nylon bristle brush. While it is somewhat line of site between the anode and part. But I have had a few rusted together pieces free up. I love it when something works while I sleep. 6 Share this post Link to post Share on other sites
953 nut 63,892 #13206 Posted October 19, 2021 11 hours ago, adsm08 said: muriatic acid mix to wash the rust off the donor metal, which is used in a lot of rust converters Phosphoric acid is used in most rust converters. Share this post Link to post Share on other sites
Goldnboy 1,076 #13207 Posted October 19, 2021 I was bored between the girls and home preparing for homecoming and football games. So I did some cleaning and painting to many excess parts. 4 5 1 1 Share this post Link to post Share on other sites
RandyLittrell 3,943 #13208 Posted October 19, 2021 Finally got my new shoes and repainted wheels back on my 310, just need to paint the rear wheels and a wash and wax and she will look new again! New spindle caps too. I made a weight rack from an old cast steel receiver hitch, had to drill a new hole for the pin and weld some tubing on to hold the weights. Just the hitch weighs a good 15 pounds, it's heavy. I have more weight at home I need to round up yet and get the blade mounted. 9 1 Share this post Link to post Share on other sites
adsm08 4,152 #13209 Posted October 20, 2021 11 hours ago, 953 nut said: Phosphoric acid is used in most rust converters. Years ago muriatic acid (hydrocloric acid) was used for acid washing rust, similar to vinegar. Phosphoric acid was also commonly used in rust converters to create iron phosphate. The green movement has push a switch by many companies to citric acid, which performs a similar function, but does not seem to work as well in my experience. 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #13210 Posted October 20, 2021 Had good results using this stuff. Found on the shelf a Wal-Mart. Pushed a good sized puddle of the gel... all over the rusted area, just keeping it wet with product for 20 or so minutes. Wiped the product off, then finished it with a quick wet sanding with 800 grit. Pretty pleased with my half hours worth putzing around. 8 6 1 Share this post Link to post Share on other sites
ebinmaine 76,965 #13211 Posted October 20, 2021 S'pose Millie wants out? 4 3 8 Share this post Link to post Share on other sites
Handy Don 15,716 #13212 Posted October 20, 2021 51 minutes ago, ebinmaine said: S'pose Millie wants out? Keep 'er waitin' and you may see a puddle on the floor! 1 11 Share this post Link to post Share on other sites
kpinnc 16,911 #13213 Posted October 20, 2021 1 hour ago, AMC RULES said: Pretty pleased with my half hours worth putzing around. Rusty or not, that tractor is awesome! 2 Share this post Link to post Share on other sites
TJ5208 1,841 #13214 Posted October 20, 2021 Rebel Is running now so happy about that check it out on my YouTube TJ salyers 4 Share this post Link to post Share on other sites
Maxwell-8 4,370 #13215 Posted October 20, 2021 27 minutes ago, TJ salyers said: Rebel Is running now so happy about that check it out on my YouTube TJ salyers That techy sounds good, that's the engine my raider had originally. 1 Share this post Link to post Share on other sites
Ifixoldjunk 778 #13216 Posted October 20, 2021 @RandyLittrell Ive built something similar in the past. Just some tubing and a chunk of flat bar and I can mount a 12in weight to the bagger mounts. 5 1 Share this post Link to post Share on other sites
squonk 45,269 #13217 Posted October 20, 2021 (edited) Carb off for a cleaning. Had to rewire the C-160 I just got. The only wire in the correct location on the switch was the start wire to the solenoid. Someone managed to connect it so it still worked but we're overly generous with the wire nuts Edited October 20, 2021 by squonk 8 2 Share this post Link to post Share on other sites
Ifixoldjunk 778 #13218 Posted October 20, 2021 (edited) just finished winterizing my deck. Probably won’t use it again this season. When do y’all think it’s time to start hooking up the blowers? Probably a bit early now. I usually wait until the first frost or so. I used a paint brush and some near vintage mystery transmission fluid to coat the underside of the deck. I’m always amazed how little rust is on it, I’d like to keep it that way😅 Edited October 20, 2021 by Ifixoldjunk 4 1 Share this post Link to post Share on other sites
953 nut 63,892 #13219 Posted October 20, 2021 23 hours ago, adsm08 said: muriatic acid (hydrocloric acid) was used for acid washing rust Yes, but it will flash to rust as soon as it is rinsed off. Rust converters will leave a rust preventive coating. 2 Share this post Link to post Share on other sites
8ntruck 8,557 #13220 Posted October 21, 2021 Started the day doing trailer work. Hauled the 7 dock sections up the hill to their winter storage spot, then one load of dock legs and feet up to their storage spot in one of the sheds. Swapped out the RD deck for the SD deck with the mulching plate to mow the lawn and process round 1 of the leaves. Was almost done when the no name decided to work a math problem. I was turning the wheel left to try before I broadsides the travel trailer. Tractor was not responding. The new equation the tractor was demonstrating was: left front wheel full left + right front wheel full right = straight. The inner tie rod end on the right hand side had separated. Guess I'll be building up a set of tie rods with heim joints. I patched it together with a few wraps of electric fence wire. 3 2 Share this post Link to post Share on other sites
CB520HC 61 #13221 Posted October 21, 2021 Well finally installed my 44" 2 stage blower on one of my tractors hood came off due to fitment issues just sitting on the tractor for the pic everything works belt guard is off as well but id love to see if ohio will allow me to use this this winter. love to hear the k341 dig in. 8 1 Share this post Link to post Share on other sites
kpinnc 16,911 #13222 Posted October 21, 2021 On 10/19/2021 at 9:02 AM, Goldnboy said: So I did some cleaning and painting to many excess parts. Can I send a really small (fridge-sized) box and have you take care of my spares? 1 Share this post Link to post Share on other sites
kpinnc 16,911 #13223 Posted October 21, 2021 2 minutes ago, CB520HC said: id love to see if ohio will allow me to use this this winter. love to hear the k341 dig in. Can't use a snow thrower in your state? Not being smarty pants at all- just surprised by that comment. Have no use for one here, not for the past 10 years anyway. 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #13224 Posted October 21, 2021 9 minutes ago, CB520HC said: see if ohio will allow me to use this this winter Yeah, I would also like to hear more about the reason you think the state would not let you use it! Boy, talk about big bother! Share this post Link to post Share on other sites
CB520HC 61 #13225 Posted October 21, 2021 I can just last couple years haven't had enough snow to really be worth it also have a gravel driveway. I use the 520hc with 56 blade to push the snow planning on using this if i start running out of room to stack the snow. 4 Share this post Link to post Share on other sites
