JERSEYHAWG / Glenn 4,524 #1 Posted January 14, 2018 (edited) Ok, a friend of mine just got a 314 hydro, Kohler engine. When he used it, he noticed the oil fill cap came off, besides the pressure coming out, oil shoots out to. He can't keep the cap on, when it's running, the cap pops off, oil sprays out. He temporarily duct taped it on to the fill neck. He asked me to post this here for help. Does anyone have a clue on what's going on here and how to resolve this? When he gets home from work he will forward a picture of the tag under the seat so we will know the year and such. Tanks, Glenn Edited January 14, 2018 by JERSEYHAWG / Glenn Share this post Link to post Share on other sites
ACman 7,686 #2 Posted January 14, 2018 Make sure the air cleaner is assembled correctly and or isn’t clogged . 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,524 #3 Posted January 14, 2018 35 minutes ago, ACman said: Make sure the air cleaner is assembled correctly and or isn’t clogged . Jeff, it has a new assembly with new filters, he was wondering if maybe the extreme cold we had here, might have had something to do with it. I will go over his house tomorrow and look at it with him. Thanks for the reply. Glenn 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted January 14, 2018 Crankcase breather??? 4 2 Share this post Link to post Share on other sites
953 nut 63,894 #5 Posted January 14, 2018 If it has been operated for short periods and is below freezing it may be condensation frozen in the CC Breather. 4 Share this post Link to post Share on other sites
Ed Kennell 44,541 #6 Posted January 15, 2018 If he just got it, could be the PO assembled the breather incorrectly. Clean the breather, but don't assume it was assembled correctly. 3 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,524 #7 Posted January 15, 2018 (edited) Can we get a link to this breather assembly, I am looking but not having luck yet. Pete is handy on mechanics, but it could be wrong. Thanks, you gave good starting points to look for tomorrow. Glenn I forgot, what year is this according to the serial number....a 1986?? Glenn Edited January 15, 2018 by JERSEYHAWG / Glenn Share this post Link to post Share on other sites
Ed Kennell 44,541 #8 Posted January 15, 2018 7 hours ago, ACman said: Make sure the air cleaner is assembled correctly and or isn’t clogged . Sorry Jeff, I didn't see your post. Glenn, If the breather is OK, I would look at the exhaust valve guide. If it is leaking, it could be pressurizing the crankcase on the exhaust stroke. 1 Share this post Link to post Share on other sites
Ed Kennell 44,541 #9 Posted January 15, 2018 (edited) 1986 314 should have the M14 Edited January 15, 2018 by Ed Kennell 1 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,524 #10 Posted January 15, 2018 5 minutes ago, Ed Kennell said: 1986 314 should have the M14 Thanks Ed, and all you guys. Gave me plenty of what to look fors. Will report back on findings. Glenn 2 Share this post Link to post Share on other sites
diesel cowboy 263 #11 Posted January 15, 2018 That style dipstick has an o-ring on the top of the tube. Try checking that and the cap where it slides over the tube. The o-ring might be worn out or broken or the cap on the dipstick might be cracked. If its loose, the pressure when it's running will make it pop off and spray oil everywhere. Ran into that a couple times on the newer Commands at work where it was hard to push the cap down all the way so it would seal and after a few minutes running would pop loose. Stewart 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,970 #12 Posted January 15, 2018 5 hours ago, JERSEYHAWG / Glenn said: I forgot, what year is this according to the serial number....a 1986?? Glenn Garry 2 Share this post Link to post Share on other sites
Lost Pup 173 #13 Posted January 15, 2018 A compression check and a cylinder leakdown test of the cylinder might help. 1 Share this post Link to post Share on other sites
Dirtdog524 61 #14 Posted January 15, 2018 The dipstick should snap into place. At work, we use the same tractor for sidewalk duty and if it is not snapped into place, oil will blow everywhere. 1 1 Share this post Link to post Share on other sites
Lane Ranger 11,741 #15 Posted January 15, 2018 Yes that O ring on the top of the dipstick needs to be in place for the stick to "lock" down. Otherwise you can blow oil out the top of the loose tube! 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,524 #16 Posted January 16, 2018 Ok, we have dual winners, the o ring seemed not to be seating properly. And the breather was moist / freezing up. Seems the assembly was a bit off. But what wasn't helping was the fact of one headight and headlight trim ring was missing. Letting snow, bitter cold air right in. He ordered the trim ring, I couldn't believe 40 bucks, and will get headlight. Everything back together. Test run showed no dipstick pop out or flooding oil THANKS FOR THE HELP FELLAS. Glenn 3 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #17 Posted January 18, 2018 @JERSEYHAWG / Glenn Thanks for keeping us updated on the actual fix! 2 Share this post Link to post Share on other sites
