r1jakecfd
Thinking about 520H Repower
WHX??
My understanding is head bolts should be checked & re-torqued after a little run in and when warm. Couple of my Kohlers were very loose after running.
WVHillbilly520H
:text-yeahthat:
r1jakecfd
Good point. I’ll run it, let it warm up and retourque. It ran great for about 15 min then got really loud and lost power. New head gaskets on order. I’ll let you know how it works out! Thanks
WHX??
Just to further educate a Onan wrenching newbie does the motor have to turned to get at the rear jug head?
r1jakecfd
Yes. There’s no clearance to get at the rear cylinder head if you don’t remove it. Also, it’s a good idea to remove it so you can inspect and clean the mating surface for a good seal.
Howie
Did not give the aftermarket block a thought when I made the comment. I do know what the ARP stuff is. Guess I could get some from my engine builder friend, he uses something else instead.
Bulds a lot of circle track engines. On these small engines I just use engine oil on the threads and a dab underhead of bolt. And re-torque after a heat soak. Not trying to be a pain.
Edited by Howie
  • Thanks 2
WVHillbilly520H
Same here, just pointing out this is some good stuff to have (or an equivalent) especially with aluminum threads and steel bolts and torque values, kinda like never seize with stainless steel, Jeff.
onanparts.com
The new gaskets might show up tomorrow, Saturday. Monday only if USPS gets lost! :)
Use a High Temp anti sieze on the head bolts. Nickel based is good but the copper stuff is OK too. No anti seize? Motor oil is better than nothing. Torque the bolts to 5 Ft-Lb, then 10 Ft-Lb, then go around again at 14-16 Ft-Lb. Wait a minute or two, go around again and double check the torque. Graphoil gaskets compress when torqued, more so than non graphoil gaskets, and will settle slightly. Have never had to retorque Onan air-cooled head gaskets once done as described. Good Luck!
bigplow1
If you want to repower don't be afraid of the vanguard kit from small engine warehouse just put one in a friends 520h runs great mows better he has the 60 deck and is not easy on it he mows for a couple cities around here that people don't mow or move out some of the yards are 12 plus high and it does great will put one on my dad's when the onan pukes I am not a onan fan to temperamental for me I like my 1 lung Kohler k series
Cable
On 1/6/2018 at 12:28 AM, r1jakecfd said:
Hi Guys,
The Onan in my 520H was running poorly so last month I took the heads off, decarboned, cleaned/reseated the valves, checked valve seats and reassembled with new gasket set. When installing intake manifold, I realized last year (carb cleaning) I forgot to hook up vacuum line from manifold to gauge. Hooked it up correctly this time and ran great. First blizzard yesterday and started snow blowing. After about 15 minutes the became noticeably louder with less power.
I was wondering firstly if anyone has any idea what went wrong?
Also, I was thinking about repowering with a Honda or Vanguard and would love opinions on which way to go? Also, should I go with an engine or kit and which company? I’m good at fabrication, etc.
Thanks in advance!
Happy NewYear
I just pulled a P220G from a 1990 520H.  It had 453 hours on a working hour meter.  I wanted a number of the parts for another restoration.  The engine is listed on the York, PA Craigs List, where you can see it, see compression readings that were taken, and there is a link to see and hear it running. $875.
r1jakecfd
r1jakecfd
Thanks, the Vanguard will definitely be my next move. The strange thing that I can’t figure out is that the vanguard costs more as a bare engine but the converted WH Repower is $400 less than a Honda. The Vanguard is just over $1700 from Small Engine Warehouse and I was just quoted $2080 for the Honda GX630 conversion from Repower Specialists. At Northern Tool, the bare Honda is $1200 vs $1450 for a Vanguard. Who knows???
r1jakecfd
Thanks for all the advice Onan! You hit the nail on the head. I bought the cheap graphoil set which I had never used before. I’ve always used the OEM aluminized gaskets and never worried about re-torquing. New gaskets coming are OEM! I’ll still re-torque after a short run. When I checked the bolts when removing the head the Middle ones were obviously loose. Lesson learned. I’ll be happy to get it back together for more snow duty! Who knows after that... Turbocharger, supercharger, Nitrous (for snowbanks)?!? 👍 Cheers
608KEB
:thumbs:
Edited by 608KEB
r1jakecfd
On 1/9/2018 at 6:34 PM, lynnmor said:
That gasket does look like inferior material.  Do you know if the head is flat?  I don't think you are to use thread locker on the head bolts, usually you use a drop of oil.
On 1/9/2018 at 9:27 PM, r1jakecfd said:
It’s a good lesson in buying OEM parts. Material is completely different material, not aluminized. OEM set on order
Lynnmor,
I think the gaskets are the graphoil which I’ve never used. I’ve never had to retorque the heads with the OEM gaskets. The head looks to be pretty flat but having said that, it’s a pretty thin aluminum head with 9 bolts holding it. I’m sure it would have been fine if yours truly had retorqued when warm😁
lynnmor
55 minutes ago, r1jakecfd said:
Lynnmor,
If you have no other way to check flatness, try holding the heads together and check how much feeler gauge you can get between them.  The spec is .004" maximum, so theoretically  that would be a maximum of .008" allowed.  Obviously this is just a rough check because there is no way to say which and how much each head is out, but if .008" goes in then they certainly need to be corrected.  If you have a known flat surface, simply check each with a .004" feeler gauge.  Also if you have that known flat surface, a head can be lapped on a piece of good 240 grit sandpaper.  While I have granite surface plates and wouldn't abuse them, I find that my DoAll saw table works fine for lapping.
r1jakecfd
Heads look good. I didn’t take the R head off. It has 90+ psi. I retorqued those bolts and reinstalled a new gasket on the L side. Will keep you updated on the test run.
r1jakecfd
Well guys, gasket installed, ran it to warm it up and retorqued. It sounds great and pretty quiet too! I have a bad voltage regulator so haven’t fully reinstalled yet. I need to add a fuse block as the last person didn’t see the need for fuses🤣. I mean, I’ve never heard of anything shorting out on our beloved horses!😂 I’m going to buy some LED bar lights and an amber led Lightbar for snow duty too.🌬❄️
Desko
The repower in my opinion isn't worth it. You can have your onan rebuilt for right around $1,200 with all new oem parts not including machine work but are here its $70 to bore them and $25 to cut and grind the valves and seats which imho isn't bad for a smooth running engine. I've seen them go to 5,000 hours in welder gen sets running WOT. Keep the screen clean and blow out the fins with an air gun when you're done they'll go forever. Glad you got her fixed though and she's running good!
  • Similar Content
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
