r1jakecfd
Thinking about 520H Repower
r1jakecfd
Hi Guys,
The Onan in my 520H was running poorly so last month I took the heads off, decarboned, cleaned/reseated the valves, checked valve seats and reassembled with new gasket set. When installing intake manifold, I realized last year (carb cleaning) I forgot to hook up vacuum line from manifold to gauge. Hooked it up correctly this time and ran great. First blizzard yesterday and started snow blowing. After about 15 minutes the became noticeably louder with less power.
I was wondering firstly if anyone has any idea what went wrong?
Also, I was thinking about repowering with a Honda or Vanguard and would love opinions on which way to go? Also, should I go with an engine or kit and which company? I’m good at fabrication, etc.
Thanks in advance!
Happy NewYear
Desko
You might have Ice or snow plugging your air cleaner and the loudness could be the blower? I would fix the onan as it'll be the best engine to have in that tractor in my opinion. But a Honda would be a better repower over the briggs but some wiring altercations will have to be made.
cafoose
Check this thread:
Mike Johnson
I repowered my B-100 about a year ago with a 22HP Honda twin that came in a kit from Repower Specialists.  It comes with a 3 year warranty and so far I have been delighted with it's performance.  Installation was relatively easy, and would be even easier on your 520 since it is a larger framed tractor.  You can see pictures and more details by doing a search on "B-100 Repower" in the customs forum.
WVHillbilly520H
You want cheaper? but seems durable so far, try the 22hp Predator basically a Honda clone many threads on here if the conversion, check out this video of @fast88pu modded predator, Jeff.
VID_20171104_172556_edit_0.mp4
r1jakecfd
Good idea! I didn’t think of the air cleaner. I’m also going to check the torque on the intake and exhaust bolts. I just redid the top end and used the $30 gasket kit vs Onan OEM. The gaskets look different than OEM ones so I wonder if that has something to do with it?
I definitely won’t find out today as it’s 12 degrees right now, going down to negative numbers tonight and I have an unheated garage!
Desko
That might be the issue I used those $30 ebay special gaskets and they leaked so bad around the intake and exhaust it sounded like a bad tick but it was the exhaust blowing past the gasket
r1jakecfd
Now that I think about it, after I started it for the first time, my vacuum gauge was reading about 28-30. When it started running poorly, it was reading about 20. I think I may have found the problem! I guess you get what you pay for!
fast88pu
That's the stock engine with header pipe
littleredrider
If the Onan goes  on my 520 I plan on getting the HF 22 horse motor. Love to put a V-twin diesel, but can't afford one right now...
r1jakecfd
At this point seriously looking at the Predator! Getting frustrated troubleshooting.
r1jakecfd
OK guys, here we go again! I decided to test the compression and have no compression in the front cylinder. I know it’s usually the rear cylinder that has issues but that has over 90 psi. Like I said in my first post, I decarboned the heads/valves, reseated and adjusted the valves, new (non-OEM) gaskets and new plugs. Running really rough and loud with misfires and loss of power. Any advice or recommendations before I convert it to a boat mooring?😂
Any input/advice would be greatly appreciated!
Thanks Guys!
John
fast88pu
Loose valve guide or seat. Mis adjusted valves. Bad plug. Dirty carb
WVHillbilly520H
During your compression test did you try a couple teaspoons of motor oil and try again, this will let you know if it's rings/valve guides/seals (compression comes up) or no increase valve stuck open no piston movement ect, both cylinders fire from the coil at the same time, easier way to check fire is a $10 inline spark tester, try these first if you havent already, Jeff.
r1jakecfd
Great point. I think I’m going to check the valve adjustment first and while I’m in there make sure I didn’t lose a valve spring retainer. I just read about that on another feed for the same symptoms I’m having. I’ll keep you updated on the progress/problem found.
Thanks everyone!
WHX??
Any chance that head gasket  blew & how many hours on it? If it's got no compression on that front  something bad must have happened. Since that's the easiest jug to get at I would at least pop the head off. Maybe just a stuck valve.  I'm kinda in the same boat anchor :lol: as you John in that I have one that smokes worse than I do & eats plugs. Haven't  got past the carb cleaning stage yet but afraid to even stick a decarbon gasket set in it. Jeff just beat me to the stuck valve diagnosis.
Edited by WHX14
r1jakecfd
Haven’t tried oil yet and I do have spark plug tester but also had a good spark when I removed the plug to test compression.
r1jakecfd
I’m going to take the valve cover off first to check adjustment and if I threw a spring/retainer. If things look good I’ll take the head off to check that. I just decarboned and put a new gasket set in about an hour ago. I torqued everything to specs so it should be good but I am human!
ericj
my cousin's daughter called me last summer and said that their 520's deck had a loose blade and she had just tightened it and it was loose again, I told her to bring me the deck to look at, instead of bringing me just the deck she brought me the whole tractor and deck. So when I started the tractor to pull the deck off I right away said something didn't sound right on the tractor. diagnosed the deck as a broken bearing housing. then looked at the tractor. Checked the spark plug and while out decided to do a compression check and found low compression on the back cylinder. Pulled the motor and stuck a spare on it and gave them the tractor back to use. When I checked the motor couldn't find a problem at first. Finally pushed on the valve seat and found some movement. My guess is the seat had just came loose and didn't have a chance to were to bad. Seat was still fairly tight in the block, just not tight enough to run as is. So what I'm saying is to check the seat closely, might have to push on the inside of the seat or even tap on it LIGHTLY to detect any movement. sounds more likely that either your valve keeper came apart or something foreign is holding the valve open. good luck.
eric j
r1jakecfd
Well, I’ll let my new head gasket speak for itself. I’m not sure what happened... was it installer (Me) error, old head bolts that backed out. Not sure. I’m definitely ordering a new OEM gasket kit and new head bolts. I’ve also bought High temp Threadlocker to install this time around. I’ll let you all know how it works. Very relieved it’s not a valve seat! Thanks to everyone for their input!
  • Thanks 2
lynnmor
That gasket does look like inferior material.  Do you know if the head is flat?  I don't think you are to use thread locker on the head bolts, usually you use a drop of oil.
WVHillbilly520H
This is what I used on my SBC head bolts, ARP thread sealant...
Howie
Yeah but that is because the head bolts go into the water jacket on the SBC!:)
r1jakecfd
It’s a good lesson in buying OEM parts. Material is completely different material, not aluminized. OEM set on order
WVHillbilly520H
If it's a factory block with through holes the aftermarket blocks have blind holes,  plus this sealer is for the steel to aluminum so the threads don't gall up and you can remove them without breaking the bolts off plus helps get the correct torque reading when installing, Jeff.
  • Similar Content
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
