Dan693 510 #1 Posted December 26, 2017 My Bro has a 60 Suburban 400 and is having traction trouble when plowing snow on asphalt with single stock ags. I say its mostly a rear weight issue since the blade he has is pretty heavy on the front. Any ideas on the best weight ballast for the rear?.....wheel weights.....weight box on the hitch? Thanks for any thoughts! Share this post Link to post Share on other sites
squonk 46,876 #2 Posted December 26, 2017 Wheel weights 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted December 26, 2017 Just a tombstone added to the front of my RJ... pushed this wet stuff like no tomorrow. 3 Share this post Link to post Share on other sites
SPINJIM 1,997 #4 Posted December 26, 2017 Wheel weights put the weight on the tires. A 'weight box' puts the weight on the axles as well as the tires. That puts more stress on the axle bushings and oil seals. Like Squonk said, better off with wheel weights. 9 Share this post Link to post Share on other sites
Sparky-(Admin) 25,577 #5 Posted December 26, 2017 Wheel weights over a weight box is my vote. A weight box will put a lot of strain on the axles and axle bearings where wheel weights won’t. Also ag’s are the worse choice for snow duty. Turf style tires with chains and wheel weights beat ag’s hands down. 6 Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #6 Posted December 27, 2017 I'm Told recently that wheel weights is what you need, weight boxes for more of a FEL application, that comes from the Higher Up's, Horse Gurus 3 Share this post Link to post Share on other sites
JoeM 10,037 #7 Posted December 27, 2017 Always a good debate. I prefer the weight box over hung weight to wheel weights. You don't need as much weight and is fairly easy to remove. The WH axles and bearings are pretty tough, keyways seem questionalble . I always had a concern with wheel weights adding momentum stress to the keyways. Kind of like a flywheel affect. I know liquid in tires is great for traction too. I guess to each their own. I would use what I have on hand. 1 Share this post Link to post Share on other sites
Adams94 1,071 #8 Posted December 27, 2017 I run both to plow snow. Plan to run both on the loader also 5 Share this post Link to post Share on other sites
953 nut 66,628 #9 Posted December 27, 2017 1 hour ago, OILUJ52 said: The WH axles and bearings are pretty tough The question was about a Suburban which has bronze bushings, not bearings. Loaded tires and wheel weights with two link tire chains would do the trick. 5 Share this post Link to post Share on other sites
Achto 31,902 #10 Posted December 27, 2017 (edited) Given the the machine in question ( '60 Suburban ) I would definitely say wheel weights only. You need to take into consideration that the axle tubes are only welded to the thin side plates on the transmission. Just running 23-10.50 x 12 tires alone, no added weight ( other than my butt ) on my Suburban caused the rear axle tubes to sag. The welds even started to crack around the tubes. When I rebuilt my tranny the last time I added gussets to keep this from happening again. If it were a '61 Suburban with a 2 piece trans, then a weight box might be an option. Edited December 27, 2017 by Achto 8 1 Share this post Link to post Share on other sites
Chris G 3,373 #11 Posted December 27, 2017 On my 400 I got weights on all 4 and plows great! 7 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,574 #12 Posted December 27, 2017 (edited) Wheel weights get my vote. And I run chains to. Glenn Edited December 27, 2017 by JERSEYHAWG / Glenn 5 1 Share this post Link to post Share on other sites
