wallfish 15,937 #1 Posted February 21, 2009 I could use some hydraulic advice. I picked up a power steering valve and cylinder to add PS to the 416-8. They are off a Simplicity Sunstar gth20. I was thinking to use a priority flow divider installed near the pump for pressure. The existing pump is 1200 PSI with 8 GPM. I can Share this post Link to post Share on other sites
Rollerman 290 #2 Posted February 21, 2009 John I'm no hydraulic wizz.....but if your building your own PS system & you have a gear dirive tractor. I assume your running this off the FEL,s hyd pump? If that is the case what would the pressure & flow rateings for the Sundstrand or Eaton hydro pumps give you? There is a free Sundstrand download with a lot of info...I'll try & dig it up later then post a link. Share this post Link to post Share on other sites
