Seacrestbf
D 200 Engine
Seacrestbf
Hello
I have a D 200 and my sons have been cutting the lawn this summer and nerver check th oil and the seized the motor. I freed the motor up and it runs fine until there is a load. I checked the Compression  and I have one dead hole. ;-(   it broke my heart. I have a Mower, tiller, and snow thrower.
Any Advise? Should I buy a motor? Or rebuild or scrap?? I liked the machine. But I dont want to dump a ton of money into it if it is questionable. I am not sure if it is a Kohler or Onan??  Any thoughts
Thank you
Brian Foley
  • Sad 1
"D"- Man
Brian, not much advise but if the engine is original it would be a Kohler 20 HP.  That is a lot of tractor and accessories to let sit if the hydro was strong, it may be worth rebuilding the engine.
Seacrestbf
Thank you
Seacrestbf
Any Thoughts on where to buy parts for the rebuild?
Thank you
Thank you
pacer
The site achto shows is a good source as is ebay.
A word of caution here, parts for these big twins - like your K532 - are getting scarce ---- especially CONNECTING RODS!  Its very possible you will need machine shop work what with the engine running low on oil, bore job to clean up the cylinders and regrind the crankshaft, etc. Before you start buying parts determine what work will need to be done . IE: if your crank needs turned then you will need rods and they just may not be available!!
In the last couple yrs I have needed a rod for each of my 18 and 20hp twins, I ended up faithfully prowling ebay and after a few weeks was lucky enough to find them used -- and these were in standard size! You may well need undersized..
Edited by pacer
R. L. Addison
If it needs rods, I saw a site that makes rods out of aluminum billet stock  I would nose around a bit before making a hasty decision. While the "D"'s are not my favorite's they can do a lot of work for a long time yet.
Skipper
Do you have info on that site?
pfrederi
Looks like "Free" lawn mowing help wasn't very free.:(
  • Sad 1
R. L. Addison
You tube : Kohler K series connecting rods 2015/2016 design improvements explained - clearancing 1 cylinder engine for billet rod, Midwest Super Club.
As far as a direct link to the video, I did/could not persue it too far yet, ite a long time to find it the second time, and have nbot made it back yet to look any more.
Skipper
That's fine. Thanks. Know where to look now ;-)
Seacrestbf
Would you consider Replacing the motor with something else ??
Send the Motor to a rebuilder?? Brian Miller??
Spareparts
If you are not into keeping it stock consider the Preditor 22hp V twin as a replacement, I have used many of the HF engines
and have had very good luck with them. Their is many parts sources for them now and seem to be very reliable. In our pulling club several
guys have been running them for the last couple of years, and to be honest with you they are kicking our butts at about 1/3 the
 price of a rebuilt/built Kohler.  I think if you go to Brian Millers site the price of a rebuilt opposed twin is going to be in the $14-1500 range.
Seacrestbf
Thank you very much. Do you know where to buy? What about the fit?
Spareparts
Harbour Freight and a little fab work . not to complicated, put one of their 13 hp motors on my GT 2500
 and a couple of holes drilled in the base is all I had to do. Plan on replacing it with a 12hp Kohler when
time permits.
slufoot733
I feel for you. In 1993 western PA had a monster snow (22" in 24 hrs). My dad had a D200 (which I now own). He called my brother in law who lives on the same lane and suggested he fire up the Horse and use it to clear the lane. Jeff took him up on it. Unfortunately my dad forgot to tell him about the engine oil leak. After about three hours of running, clearing a 1/4 mile lane, the engine seized up. Dad had to get a new short block from Kohler and have it installed, not a cheap fix. But I am still using that tractor today.
If you can find the parts it is very well worth the time to repair this tractor. Do some research, those K532 engines are still out there. Maybe find a tractor bone yard for parts, or the whole engine.
Might also try this place:   www.isavetractors.com   207-298-9701. They advertise in LAWN & GARDEN TRACTOR magazine and claim to have "everything you need to bring your old engine back to life". They specialize in Kohler K series engine rebuild kits.
Good luck.
Edited by slufoot733
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • Nathan W
      By Nathan W
      Does this look factory for 1976
