Tankman 3,528 #1 Posted November 13, 2017 In my 70’s, forgot. Who, where, supplies snow blade cutting edges? 48 incher, worn bad. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #2 Posted November 13, 2017 , or if you're up to it an old car/truck leaf spring will wear better than most anything you can buy that's what I have welded on mine, Jeff. Share this post Link to post Share on other sites
857 horse 2,588 #3 Posted November 14, 2017 I was gonna say,,,,go to Lowes,,,,,,48x3 is 25.00 But WVhillbilly,,,,,has a better suggestion !!!!!!!!!!!!!!!!!! gOOD iDEA !!!!!!!!!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
Tankman 3,528 #4 Posted November 14, 2017 19 minutes ago, 857 horse said: I was gonna say,,,,go to Lowes,,,,,,48x3 is 25.00 But WVhillbilly,,,,,has a better suggestion !!!!!!!!!!!!!!!!!! gOOD iDEA !!!!!!!!!!!!!!!!!!!!!!!!!!!! I was thinking Lowes, flat bar. I like the spring idea but, wouldn't weld it on. 3" flat bar, wide, would last twice as long as the standard edge. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #5 Posted November 14, 2017 1 minute ago, Tankman said: I was thinking Lowes, flat bar. I like the spring idea but, wouldn't weld it on. 3" flat bar, wide, would last twice as long as the standard edge. I should have made myself a little more clear, welded to the existing worn edge not to the moldboard, please forgive my poor looking welds but they seems to be holding up just fine, Jeff. 1 1 Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted November 14, 2017 Hillbilly: I have one, not needed, 48" plow the PO wore to, almost, the edge mounting holes. I flipped the edge, works well. I'm thinking, stitch weld the edge to the moldboard. Then drill the 3" wide flatbar to bolt on. I use stainless bolts and Never-Seez on all threads. WD-40 (water displacement) or any oil along the cutting edge top side so it runs between the moldboard and the bolted edge. Plow is always set down on wood blocks when in my barn, out of puddles. 2 Share this post Link to post Share on other sites
P3x 60 #7 Posted November 24, 2017 To save wear and tear on my asphalt drive way, I purchased a Heavy Duty Plastic (HV Yada-Ya) edge for my plow blade wear edge a couple of years ago from eBay. It's worked well but not sure if it will last this winter and is not wide enough to flip. Have read lots of posts with folks using conveyor belt strips for wear edges, deck seals, and a host of other uses. Wanted to give it a try but could not locate a source with reasonable shipping. Saw an an ad on CL from a place selling used Fire Hose with additional "re-purposed materials." They have conveyor belt strips 6"W X 10'L X 1/2" Thick listed for 40 USD and free shipping. Think it would work well with enough material to make two edges fora 48" blade. Going to place an order today and check it out. 1 Share this post Link to post Share on other sites
Tankman 3,528 #8 Posted November 24, 2017 (edited) Use tire tread? Edited November 24, 2017 by Tankman 1 1 Share this post Link to post Share on other sites
953 nut 68,535 #9 Posted November 25, 2017 6 hours ago, Tankman said: tire tread Would that be Radial or Bias belted? Share this post Link to post Share on other sites
Tankman 3,528 #10 Posted November 25, 2017 1 hour ago, 953 nut said: Would that be Radial or Bias belted? That would be a radial with studs, only in the winter. AKA the squeegee effect. 1 Share this post Link to post Share on other sites
P3x 60 #11 Posted December 1, 2017 Tire Tread... Now why didn't I think of that! Looks like it would do the trick and cheap too. Share this post Link to post Share on other sites
