Big_Red_Fred 1,548 #1 Posted November 11, 2017 Well its Cold in the North but that didnt keep many home today, Not even BRF ! Went to my sons Stable and grabbed my K321 ! Taking to my shop to begin a Full rebuild to Live again in my C125 which will become a C145, Whats your project Red Square Members ? 7 Share this post Link to post Share on other sites
953 nut 63,031 #2 Posted November 11, 2017 I will continue work on the 953 until it gets too cold and then seek shelter in the wood working shop (has a good heating system). I have a couple of end tables, coffee table and entertainment center to build. 7 Share this post Link to post Share on other sites
Adams94 1,069 #3 Posted November 11, 2017 Get my 520-8 ready to mow, got some work to do on the 48" deck that goes on it and I'm hoping to find a good front deck carrier for it. 7 Share this post Link to post Share on other sites
Chris G 3,363 #4 Posted November 11, 2017 (edited) My winter project is 1958 Copar Panzer T55. Made a post in other brand area. Edited November 12, 2017 by Chris G 7 Share this post Link to post Share on other sites
Achto 30,204 #5 Posted November 12, 2017 Hmmm My 701? 867? the Franken mutt? I think maybe my Raider 12 plow mule will be the victim this winter. Hope to make this one a trouble free dirt turning machine. 5 Share this post Link to post Share on other sites
JPWH 6,542 #6 Posted November 12, 2017 1) I am going to totally tear down the custom 12 and build back like new. 2) Restore hoods for two 854's that was damaged last summer. 5 Share this post Link to post Share on other sites
ohiofarmer 3,383 #7 Posted November 12, 2017 a 1975 Honda old wing found me for only $300.00. it is very different from the old twin cylinders, but at the same time a lot of things are very familiar. The cult following they have has me making good progress already. Not including tires, the needed parts to have this baby running might be as little as $200 6 Share this post Link to post Share on other sites
ebinmaine 75,769 #8 Posted November 12, 2017 My "tractor related" project is going to be partially (ok, mostly) disassembling my B80 and repainting it. I'll start my own thread for updates on that within a month or so. Never done a project like this so I'll be looking for all the advice I can get !! 5 Share this post Link to post Share on other sites
Pollack Pete 2,273 #9 Posted November 12, 2017 Got the flathead V-8 out of my 1952 Ford F-6 on my engine stand for a valve job and some other freshening up.I think it's going to be a long,cold Winter here in up-state NY. 6 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,843 #10 Posted November 12, 2017 Easy - put on the front blade, chains and flasher and wait for some of that famous frozen white Michigan Sunshine!!! The old C-105 is running like a top! 5 Share this post Link to post Share on other sites
prondzy 3,889 #11 Posted November 12, 2017 I have a mower deck rebuild i got from @WHX12, a transmission rebuild for my suburban 400, and a workers resto for this little project 5 Share this post Link to post Share on other sites
richmondred01 2,318 #12 Posted November 12, 2017 2 hours ago, Pollack Pete said: Got the flathead V-8 out of my 1952 Ford F-6 on my engine stand for a valve job and some other freshening up.I think it's going to be a long,cold Winter here in up-state NY. All the best with that flathead. Here's one I did 2 2 1 Share this post Link to post Share on other sites
Sarge 3,470 #13 Posted November 12, 2017 While not a tractor - this is truly related as a tool used to repair them and make new parts - 1952 Atlas/Clausing model 1810 drill press . Currently in about 200 pieces in various spots of the shop taking up precious space , really need it back together and in service . What started as a simple bearing/spindle check snowballed into a full resto - So glad I found an IPL and book on this thing - they are quite rare and putting it back together correctly would be some serious head scratching . Biggest thing I have to work on for it is the table/head lift's gear box - found a used one and will have to rebuild it as they gears are severely worn . Will be welding those teeth up once I figure out what metal they are made from and re-profile the teeth to fit better . The truly unique thing about how they built this unit is that table/head lift is positioned in a way that it can lift either the table or head - makes it a much more versatile machine . It's taken a serious learning process , but setting it up to be used with a variable frequency drive for the Atlas 3/4hp 3ph motor running on 220vac 1ph power here . Head and base is painted already - need to finish painting the table and gear box , then start the assembly nightmare . Few other small parts have to be made that were missing - finding anything used for it is a joke . Sarge 4 Share this post Link to post Share on other sites
Pollack Pete 2,273 #14 Posted November 12, 2017 23 minutes ago, Sarge said: While not a tractor - this is truly related as a tool used to repair them and make new parts - 1952 Atlas/Clausing model 1810 drill press . Currently in about 200 pieces in various spots of the shop taking up precious space , really need it back together and in service . What started as a simple bearing/spindle check snowballed into a full resto - So glad I found an IPL and book on this thing - they are quite rare and putting it back together correctly would be some serious head scratching . Biggest thing I have to work on for it is the table/head lift's gear box - found a used one and will have to rebuild it as they gears are severely worn . Will be welding those teeth up once I figure out what metal they are made from and re-profile the teeth to fit better . The truly unique thing about how they built this unit is that table/head lift is positioned in a way that it can lift either the table or head - makes it a much more versatile machine . It's taken a serious learning process , but setting it up to be used with a variable frequency drive for the Atlas 3/4hp 3ph motor running on 220vac 1ph power here . Head and base is painted already - need to finish painting the table and gear box , then start the assembly nightmare . Few other small parts have to be made that were missing - finding anything used for it is a joke . Sarge Sarge,I've got an old Walker-Turner floor model that's in about as many pieces as yours.Been that way for about 15 yrs now.Hope none of my parts walked away.The quality and workmanship of these old machines is incredible. 28 minutes ago, richmondred01 said: All the best with that flathead. Here's one I did Nice looking Flattie.What's it in?Looks like something older than mine judging by the location of the thermostat housings.Mine are more up toward the front of the heads.Looked at your pic again.I see the distributor on the front too. 1 Share this post Link to post Share on other sites
Shynon 7,505 #15 Posted November 12, 2017 (edited) Which one, the 753 for mowing duties next year, the 520 loader install, 58RJ trans rebuild and engine install, oh and a couple more kohler engine builds. A guy can never have too many projects. Edited November 12, 2017 by Shynon 8 2 Share this post Link to post Share on other sites
Sarge 3,470 #16 Posted November 12, 2017 I had passed on one smaller Walker Turner - the table on it was the small round one and I wanted a larger production table . The Clausing has a huge 22" wide table with t-slots included and of course a nice smile of shame from living in a high school shop in Chicago . Got all that damage welded/machined and just need to paint it plus work on that infernal gear box . Sarge 3 Share this post Link to post Share on other sites
ronhatch 407 #17 Posted November 12, 2017 1 hour ago, Pollack Pete said: Nice looking Flattie.What's it in?Looks like something older than mine judging by the location of the thermostat housings.Mine are more up toward the front of the heads.Looked at your pic again.I see the distributor on the front too. Pre 1949. I always wanted a Ford Flat V-8. The closest I got was a low milage1951 Ford FH, 95 HP straight 6 that my folks gave me when I turned 16 in 1959. I beat a lot of FH V-8's with it. Most of them were worn out though 2 Share this post Link to post Share on other sites
richmondred01 2,318 #18 Posted November 12, 2017 1 hour ago, ronhatch said: Pre 1949. I always wanted a Ford Flat V-8. The closest I got was a low milage1951 Ford FH, 95 HP straight 6 that my folks gave me when I turned 16 in 1959. I beat a lot of FH V-8's with it. Most of them were worn out though 1940 ford. 85 hp A block 2 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #19 Posted November 12, 2017 (edited) Converting a fully hydraulic (lift and angle) JD dozer/snowblade to fit and work my Kioti CK20 compact vs the manual angle winch lift version I did last year, so dad has a beastly snow pusher in WV. Edited November 12, 2017 by WVHillbilly520H 3 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #20 Posted November 13, 2017 Too many to count lol...gotta get the new garage set up for one...then have a 701 in pieces to get back to...a C141 to get up and running...and a C125 that is slowly getting a facelift. But probably will end up building my engine for the 1277 so I can have my mowing tractor going before summer, and if I get real ambitious I need to split the 2n and overhaul the engine. 5 Share this post Link to post Share on other sites
cschannuth 3,819 #21 Posted November 16, 2017 Working on loader for the 520. I’ve been looking for a long time and have been close on a couple of deals but financially it never worked out. Decided to gradually pull all the pieces together to build my own. My wife got me the P.F. Engineering plans for my birthday and my father-in-law has access to some free steel. I still need to buy some steel but not a lot. My dad had a forty year old Montgomery Ward stick welder that still works really well and I practiced for a few months on scrap and got to the point where my welds look Ok and have decent penetration. The other pieces I’m buying as money allows and I find things on sale. Here are a few early pics of the bucket and the partially complete subframe. 11 Share this post Link to post Share on other sites
richmondred01 2,318 #22 Posted November 16, 2017 Complete tear down and restore Cub Cadet model 73. 1969 Only 7600 made. 4th lowest production IH cadets. Its not red but yellow is also good. 3 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #23 Posted November 16, 2017 14 minutes ago, richmondred01 said: Complete tear down and restore Cub Cadet model 73. 1969 Only 7600 made. 4th lowest production IH cadets. Its not red but yellow is also good. Wish I had known this back in the early summer, spotted 1 for sale cheap, thanks for the tip. Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #24 Posted November 17, 2017 1 hour ago, WVHillbilly520H said: Wish I had known this back in the early summer, spotted 1 for sale cheap, thanks for the tip. I missed 1 in June this year, Mint for 400, ok where's that bull rope, taking a swing in the Pines tonite ! ;-( 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #25 Posted November 17, 2017 My project is to sit here and read about the work that you guys with garages are doing and cleaning up leaves. 4 3 Share this post Link to post Share on other sites
