DBlackston 333 #1 Posted November 6, 2017 I'd love to see some pictures of a mounted HY-3 setup and a video of it in use. I recently purchased one and would like to see one in use. It won't fit my 704 so I'm going to be looking for a tractor to put it and mymid mount blade on. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,458 #2 Posted November 6, 2017 Why will it not fit your 704? Garry Share this post Link to post Share on other sites
953 nut 68,534 #3 Posted November 6, 2017 Check out this manual, it should get you going. Share this post Link to post Share on other sites
littleredrider 409 #4 Posted November 6, 2017 Need to get the dash tower of what model the setup came from.... Share this post Link to post Share on other sites
Racinbob 13,112 #5 Posted November 6, 2017 That will bolt right on your 704. Share this post Link to post Share on other sites
wheelhorseman 3,256 #6 Posted November 6, 2017 (edited) 7 hours ago, gwest_ca said: Why will it not fit your 704? Garry 6 hours ago, Racinbob said: That will bolt right on your 704. The 704 has a different hood stand then a 854. (the controls are in the way) Edited November 6, 2017 by wheelhorseman 1 1 Share this post Link to post Share on other sites
littleredrider 409 #7 Posted November 6, 2017 Plus the rock shaft is different size. I wanna say the 854 is 1” where as the 753 is 3/4”, but it’s been years since I had mine and swapped over. Share this post Link to post Share on other sites
Racinbob 13,112 #8 Posted November 6, 2017 3 hours ago, wheelhorseman said: The 704 has a different hood stand then a 854. (the controls are in the way) Oops! I didn't think about that. The rock shaft shouldn't be a problem. Same part #. Share this post Link to post Share on other sites
