Rustyred 63 #1 Posted October 28, 2017 Hello, I'm repainting both tractor and Kohler engine. 1979 C-81. My question is can you paint a carburetor? Currently it is kind of half painted with a very light coat over some of it. I don't want mine to look half baked. Can I paint or is it okay to leave no paint on? Thank you again for your needed advice. Rustyred Share this post Link to post Share on other sites
BOB ELLISON 2,983 #2 Posted October 28, 2017 I remove all the paint on mine. Gas will remove almost all paint if it gets on it. I would clean off the paint that's on it. I think bare aluminum looks good Just me I guess. Or you can paint it . I have seen them painted and they look fine. 7 1 Share this post Link to post Share on other sites
pfrederi 19,929 #3 Posted October 28, 2017 I used some of this Eastwood carb paint. Looked nice and has held up for a year or so. They have a bronze version but his looks more original to me. 3 Share this post Link to post Share on other sites
Rustyred 63 #4 Posted October 28, 2017 Both great input. Good to know I have a couple options. Is the Eastwood paint a certain color made by wheel horse or Kohler or what are you referring to? Share this post Link to post Share on other sites
Ed Kennell 44,939 #5 Posted October 28, 2017 I use carb cleaner to remove all the paint. 6 5 Share this post Link to post Share on other sites
pacer 3,179 #6 Posted October 28, 2017 I dont recall ever seeing one painted - like on purpose, but is pretty common to see the ones with overspray, sometimes heavier than others. I too clean them of all paint, a few times when Ive had one all apart and its really grungy, Ill stick it in the bead blast cabinet and really clean it. Share this post Link to post Share on other sites
953 nut 64,158 #7 Posted October 28, 2017 2 hours ago, Rustyred said: Is the Eastwood paint a certain color made by wheel horse or Kohler Eastwood is a retailer of fine quality automotive tools and restoration supplies. I have been doing business with them for 30 years or more. http://www.eastwood.com/ 2 Share this post Link to post Share on other sites
Rustyred 63 #8 Posted October 28, 2017 What do any of you think of the $20 carburetors for sale on Amazon. My original one is pretty banged up. Share this post Link to post Share on other sites
953 nut 64,158 #9 Posted October 28, 2017 I have used a couple of them and am very satisfied. Be sure the choke lever matches your application, some pull up and some pull down. 7 Share this post Link to post Share on other sites
oldredrider 2,553 #10 Posted October 28, 2017 Upon disassembly of the carb, removing all gaskets and seals, I use brake cleaner to not only clean, but remove all paint from the outside. Works great and does a good job of removing all paint. 3 Share this post Link to post Share on other sites
Ed Kennell 44,939 #11 Posted October 28, 2017 2 hours ago, 953 nut said: I have used a couple of them and am very satisfied. Be sure the choke lever matches your application, some pull up and some pull down. 3 Share this post Link to post Share on other sites
pacer 3,179 #12 Posted October 28, 2017 18 minutes ago, Ed Kennell said: 2 hours ago, 953 nut said: have used a couple of them and am very satisfied. Be sure the choke lever matches your application, some pull up and some pull down. Times two -- with a stress on checking the choke movement..... tho I did manage to change one out from the old carb - a bit of a pain, but doable. 2 Share this post Link to post Share on other sites
Wishin4a416 2,473 #13 Posted October 29, 2017 I also like the Aluminum look. I clean mine with brake cleaner and polish with SOS pad. Then rinse real well in HOT water and then Acetone. 3 1 Share this post Link to post Share on other sites
UncleJerm76 103 #14 Posted October 29, 2017 14 hours ago, 953 nut said: I have used a couple of them and am very satisfied. Be sure the choke lever matches your application, some pull up and some pull down. Same here! Share this post Link to post Share on other sites
WHX?? 55,081 #15 Posted October 29, 2017 You drop a stripped carb into Berryman's and fer sure you're gonna lose the paint. Just my 02 but I personally do not care if the the carb is original or in red as long as it carburats! Alway thought it would be cool to have a polished & highly detailed one on a trailer queen. BTW those are fine lookin motors Jack & Ed... 3 1 Share this post Link to post Share on other sites
pfrederi 19,929 #16 Posted October 29, 2017 If the choke works backwards so what. Put a sticker on the dash board up/out becomes run in/down choke. I have at least 3 that work backwards. Two i labeled...on the third it functions as an anti theft device as she won't start if you use the normal settings 3 2 Share this post Link to post Share on other sites
AlexR 2,614 #17 Posted October 30, 2017 11 hours ago, pfrederi said: If the choke works backwards so what. Put a sticker on the dash board up/out becomes run in/down choke. I have at least 3 that work backwards. Two i labeled...on the third it functions as an anti theft device as she won't start if you use the normal settings I ordered a $20 carb because its cheaper then getting a rebuild kit and a gasket for between the engine and carb and the $20 carb has all that I think the carb I got the choke is on backwards I figured I would just use the old choke shaft but maybe I will just use it backwards.. 1 Share this post Link to post Share on other sites
Shuboxlover 484 #18 Posted October 30, 2017 I have used a fine wire wheel on my grinder to clean them up, makes the aluminum shine pretty good and the brass adjustment needles almost look polished. 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #19 Posted October 30, 2017 Then, a quick polish using Mothers mag&aluminum polish... will keep 'em looking that way for the long term. Here's the before, and afters... 3 5 Share this post Link to post Share on other sites
