r1jakecfd
Transmission to lift valve hose fittings 520-H
r1jakecfd
Hi Guys,
Does anyone know where you can get the correct size, 90 deg crimp fittings for the hydraulic line going from under the hydro trans to the lift valve on the 520-H? I found a Gates fitting with the correct thread size but it was too long on the thread end. It came down too far under the transmission to allow the hose to come over the frame.
Hopefully I described this well enough?
Many thanks,
John
pfrederi
Check with one our vendors here.
r1jakecfd
Thanks pfrederi! I just emailed Wheelhorseman with the hose I need.
What a great resource!
Cheers,
John
  • Similar Content
    • davem1111
      By davem1111
      My original "inquiry" thread has been frozen but is still viewable, so please refer to it for pictures and descriptions:
      I've dropped in $800 as a "starting price" for the entire lot. At first I thought it should be a higher number, but as I mentioned I am not looking to get top dollar, I am looking to downsize. My preference is to sell the entire lot, but depending on the interest level I may be willing to sell some things separately, and possibly ship small things.  A lot of this is in the "Free Stuff" category, but that mostly applies to someone who wants to buy the tractors and wants all the free stuff along with them.
      If you have questions about anything in the pictures, ask here or send a PM. I can take more pictures if needed.
      Ideally I'd like this all gone before winter sets in.
    • gwood
      By gwood
      Question: I'm looking at the seat and decal drawing and could use an answer! Does the the seat spring or the adjusters go under the seat? It looks like the adjusters go directly under the seat and then the springs under the adjuster. If so, where does the spacer (110932) go?   The reason I ask is the seat is quit low and the back sets low making it hard for me to reach the brake/ return to neutral pedal.
    • Merl
      By Merl
      Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
    • M Robs
      By M Robs
      Hello - Last year I inherited a 1992 Wheel Horse 520-H Garden Tractor and several accessories. I was able to get it started at the end of last summer and drove it around a bit but I am now looking into get something better suited for my current situation. I have absolutely no idea what the tractor and accessories are worth and would love some ballpark numbers from those in the know. I've attached photos and would love any advice as to what I should try to sell these items for. Thanks so much!
      The tractor is a 528-H model - 1992
      289 hours on the hour meeter
      The mower is a Side Discharge Mower?
      48" Snow Dozer Blade - Part No. 810746R1
      36" Tiller
    • qudrcps
      By qudrcps
      I recently started experiencing "bucking" on my 1997 520-H with the Eaton 1100 series transaxle.  This occurred after 500 hours of heavy use with the 60" mowing deck, with all transaxle oil changes performed per specs.  In reviewing causes of "bucking", I came across this for a similar complaint in a Simplicity 4711 that used the same transaxle.  ( simpletractors.com/forums/topic/7441-simplicity-4211-hydro-bucking-problem/ ).  One thought was that this was due to missing or loose bolts securing the transaxle to the frame.
      This turned out to be precisely the reason for the "bucking" in mine.  One securing bolt replaced, all other securing bolts tightened (along with the engine bolts), and the Forward-Reverse lever/linkage adjusted and tightened, and the tractor is back to "usual".
      It's just something to consider before the nightmare of a transaxle overhaul...
