608KEB
Changing oil
608KEB
I changed the oil/filter on my 520H last fall. I only put 4 hours in the tractor last winter. The oil is still golden-brown in color. It's looks new  Should I change the oil and filter again?
pfrederi
If the four hours was just a couple of long runs that let the engine get hot then i wouldn't change he oil.  If it was a bunch of short runs  I might change it as condensation can build up.  Long runs boil off the water in the oil.
  • Like 3
Ed Kennell
Not necessary,   oil has a long shelf life.
Edited by Ed Kennell
pacer
I agree, not necessary - 4 hrs is nothing. Think about this: a 4 hr trip in your car would be, what 250-300 miles? you wouldnt change it in your car.
608KEB
That sounds good. I usually change the oil on my cast iron block Kohler engines around 20 hours. The air filter around 30 hours. The Onan's I usually change the oil and air filter around 40 hours.B)
Fordiesel69
No.  It would be wasteful on that engine.
On splash lube engines, sometimes it would make sense depending on conditions to change based on time intervals rather than actual usage.
shallowwatersailor
I would just change the oil and leave the same filter on. If you used it for snow removal, the conditions were probably wet. Two quarts of oil doesn't cost that much.
WHX??
I better come get it and put some hours on it then. :ychain:
I agree Ed but then why do they say to change your oil every xxxx miles or every six months? :confusion-shrug:
608KEB
I don't mind changing the oil and filter. It's less than rebuilding or a new engine. Come on down!
Edited by 608KEB
Ed Kennell
Probably the same reason the   manufacturers of my vehicles recommends 7500 and the dealer recommends 3000.    GREED
  • Like 4
WHX??
Agreed  Ed :handgestures-thumbupright:
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
