WHC-125 4 #1 Posted February 16, 2009 I was looking at a C-81 8 speed with a 36 inch Rear Discharge deck. The guy told me that it has been sitting a couple months and only needs minor work to get going. He also told me that his brother in law said it has a stuck valve and only has 30 lbs of compression. Something doesnt sound right What should a 8 horse Kohler have for compression. And I thought if an engine has a stuck valve it is shot or has no compression at all :thumbs: Share this post Link to post Share on other sites
pond195520032003 27 #2 Posted February 16, 2009 Chris, if it has a stuck valve they usually wont have compression im not certain on what they should have for compression but, could also be that the drive belt is not releasing all the way and seems like it does have compression it also wont have compression if the rod is broke if you can look at it take the plug out and look in the hole while turning the engine overs and you should be able to see the valves moving up and down if they are then see if the engine turns really free, as this is a real good indication of a broken rod hope some of this helps :thumbs: Share this post Link to post Share on other sites
WHC-125 4 #3 Posted February 16, 2009 Greg, Thanks for the info, I will let you know what happens Share this post Link to post Share on other sites
WHC-125 4 #4 Posted February 16, 2009 I called the guy up and he said that he didnt have it going but it should run Here is the ad http://newhaven.craigslist.org/grd/1035995039.html Share this post Link to post Share on other sites
pond195520032003 27 #5 Posted February 16, 2009 Chris, thats a nice lookin tractor but since its not running, i would offer less if possible maybe $200 that will give you some room in case you need to do any thing major to it :whistle: Share this post Link to post Share on other sites
WHC-125 4 #6 Posted February 16, 2009 Greg, I think I could even get it for $150 :thumbs: Share this post Link to post Share on other sites
Confused99 2 #7 Posted February 16, 2009 Yeah $150 or less Share this post Link to post Share on other sites
pond195520032003 27 #8 Posted February 16, 2009 that would be even better :banana: Share this post Link to post Share on other sites
WHC-125 4 #9 Posted February 16, 2009 I will see what happens. I am looking at a B-80 and a C-160 too. Maybe a 312-8 with a snowblower :thumbs: Share this post Link to post Share on other sites
Cvans 1,009 #10 Posted February 16, 2009 You are going to need a Semi and 10 acres of land the way your going :banana: Chris Share this post Link to post Share on other sites
Rod(NASNUT) 1 #11 Posted February 16, 2009 Chris, if it has a stuck valve they usually wont have compression im not certain on what they should have for compression but, could also be that the drive belt is not releasing all the way and seems like it does have compression it also wont have compression if the rod is broke if you can look at it take the plug out and look in the hole while turning the engine overs and you should be able to see the valves moving up and down if they are then see if the engine turns really free, as this is a real good indication of a broken rod hope some of this helps If the rod was broken it would no have any compression. He said it had 30 lbs. Pull the head and check to see if the valves are seating it may have buildup on the valves or the seats. Share this post Link to post Share on other sites
WHC-125 4 #12 Posted February 16, 2009 Rod, would the buildup give it 30lbs. compression. BTW when his brother in law checked for compression they used a gauge :whistle: Share this post Link to post Share on other sites
pfrederi 20,618 #13 Posted February 16, 2009 Didn't that vintage Kohler have compression release? If so compression readings are sort of worthless. Have to do a leak down test or crankcase vacuum test Share this post Link to post Share on other sites
Cvans 1,009 #14 Posted February 16, 2009 I don't think I've seen anyone mention this, Does this particular engine have an automatic compression release like my 10hp does. If so the compression is going to read low. Chris Share this post Link to post Share on other sites
WHC-125 4 #15 Posted February 16, 2009 So its fine? I am getting confused :whistle: Share this post Link to post Share on other sites
pfrederi 20,618 #16 Posted February 16, 2009 So its fine? I am getting confused Second hand remote diagnostics are not good. All I am saying is that a compression test on an engine with compression release is not diagnostically significant.. Share this post Link to post Share on other sites
WHC-125 4 #17 Posted February 16, 2009 Ok I will look into it :thumbs: Share this post Link to post Share on other sites
WHC-125 4 #18 Posted February 16, 2009 Can anyone check on a 8 hp Kohler the compression :thumbs: Share this post Link to post Share on other sites
TJ 184 #19 Posted February 16, 2009 Can anyone check on a 8 hp Kohler the compression At over 600 rpm, it should be around 125. below that and the compression release will drop it to 45-60. hope that helps. Share this post Link to post Share on other sites
WHC-125 4 #20 Posted February 16, 2009 tj4428, Then how is it getting 30 ? Share this post Link to post Share on other sites
wheelhorse101 0 #21 Posted February 16, 2009 tj4428, Then how is it getting 30 ? because either your valves arnt seating all the way or your rings are on the way out or already shot Share this post Link to post Share on other sites
linen beige 16 #22 Posted February 20, 2009 because either your valves arnt seating all the way or your rings are on the way out or already shot Any or all those reasons OR the rings are dry. If it has not run in a while and there is no oil on the rings compression will bypass the dry rings. A blown head gasket can also give low compression. Share this post Link to post Share on other sites
WHC-125 4 #23 Posted February 20, 2009 I was thinking a head haslet maybe too because I blew the one on my Sears abd had to replace it because of not having enough compression to fire off. Share this post Link to post Share on other sites
Docwheelhorse 2,929 #24 Posted February 20, 2009 Don;t worry about it, I went over and offered him $100 and its in my driveway now... Chris you better hurry as Jeff in East Hartford WILL pull it out from under you---hesitate even a second and he doesn't care. Tony Share this post Link to post Share on other sites
WHC-125 4 #25 Posted February 20, 2009 Tony, are you selling it? Or is jeff buying it from you :thumbs: Share this post Link to post Share on other sites
