Adams94 1,071 #1 Posted October 22, 2017 Just picked this up today, looks like the belt is maybe around 63 1/2" anybody have a number for the belt? 7 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,342 #2 Posted October 22, 2017 Drive belt 107740 (4L x 63.0" or 1/2" x 63") Garry 3 1 Share this post Link to post Share on other sites
Adams94 1,071 #3 Posted October 22, 2017 1 minute ago, gwest_ca said: Drive belt 107740 (4L x 63.0" or 1/2" x 63") Garry Thanks, since there isn't a tensioner I'm guessing the belt has to be exactly right. Which pulley on the tractor do I use, the outside one? Share this post Link to post Share on other sites
Racinbob 13,039 #4 Posted October 22, 2017 It goes in the outer pulley and the tensioner is the knob on the bottom. 2 1 Share this post Link to post Share on other sites
Adams94 1,071 #5 Posted October 22, 2017 1 minute ago, Racinbob said: It goes in the outer pulley and the tensioner is the knob on the bottom. Thank you! e What is the lift tube and the flag for, I don't understand why you need to lift it? Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted October 22, 2017 Nice, I wish I have a WH generator! 2 Share this post Link to post Share on other sites
Lane Ranger 12,030 #7 Posted October 23, 2017 (edited) The lift is to keep the generator stable. It weights a lot. A very good attachment . Edited October 23, 2017 by Lane Ranger 1 Share this post Link to post Share on other sites
cschannuth 3,821 #8 Posted October 23, 2017 (edited) I never use the lift tube. It very difficult to install and remove the tube. I bought a cheap, small 4 wheel movers dolly that I set the generator on. When I’m ready to install I just roll it in to place, line up the attach-a-matic hitches and latch them and pull the dolly out. When I’m done I roll the dolly under the gen, release the latches, and roll the gen into its storage location. I never have to lift it or lug it around. And, I don’t have to crawl under the tractor and mess with the flag/lift tube. Edited October 24, 2017 by cschannuth 2 Share this post Link to post Share on other sites
Adams94 1,071 #9 Posted October 23, 2017 7 hours ago, cschannuth said: I never use the lift tube. It very difficult to install and remove the tube. I bought a cheap, small 4 wheel movers dolly that I set the generator on. When I’m ready to install I just roll it in to place, line up the attach-a-matic hitches and latch them and pull the dolly out. When I’m done I roll the dolly under the gen, release the latches, and roll the gen into its storage location. I never have to lift it or lug it around. And, I don’t have to crawl under the tractor and mess the the flag/lift tube. Good idea I like that 1 Share this post Link to post Share on other sites
Adams94 1,071 #10 Posted October 24, 2017 Is the lift tube and flag the same as on a snowblower? Share this post Link to post Share on other sites
cschannuth 3,821 #11 Posted October 24, 2017 1 hour ago, Adams94 said: Is the lift tube and flag the same as on a snowblower? I believe so but I’m not 100% sure. Share this post Link to post Share on other sites
WHX?? 57,364 #12 Posted October 24, 2017 Mike @squonk has got a setup like that hopefully he can chime in. Share this post Link to post Share on other sites
wheelhorseman 3,256 #13 Posted October 24, 2017 2 hours ago, Adams94 said: Is the lift tube and flag the same as on a snowblower? The flag is but the tube is lighter steel (like water pipe) 1 Share this post Link to post Share on other sites
squonk 47,339 #14 Posted October 24, 2017 My genny base is home made. No lift tube and I use a bolt and welded nut from the bottom to tension the belt 1 Share this post Link to post Share on other sites
