Pho Guy 49 #1 Posted October 21, 2017 Good morning, Newbie with a ? I have seen some pics of a 657 with foot rests but can't seem to find them online. Were these custom made? Fabricating a set is beyond my skill set but I would be willing to purchase a pair. Any help would be appreciated. Thanks, Share this post Link to post Share on other sites
JimmyJam 542 #2 Posted October 21, 2017 to Those footrest "pegs" were used on many models of that time period (early 60's). By the late 60's-70's Wheel Horse started using the longer wider footrests. What kind of Wheel Horse do you have? Look for an ID tag that should be mounted on steering tower that tag will have model number. or post a pic and someone on here will help you ID the tractor that you have. I looked around my barn but unfortunately found only a single footrest peg. I do have a pair of the longer style. 1 Share this post Link to post Share on other sites
SPINJIM 1,997 #3 Posted October 21, 2017 There are usually some that come up on ebay, but none showing right now. They're cast iron, so you don't want to try to fabricate. If they don't come up on ebay, they are fairly common at the WH show in June. Good luck. Jim 1 Share this post Link to post Share on other sites
953 nut 66,223 #4 Posted October 21, 2017 Give A-Z Tractor a call, they can fix you up. http://a-ztractor.com/ 1 Share this post Link to post Share on other sites
Pho Guy 49 #5 Posted October 21, 2017 Thanks for the replies I have the pegs. I'm looking for a flat rest for my feet. I have a 657 Thanks 953 nut I'll try the link. 1 Share this post Link to post Share on other sites
Pho Guy 49 #6 Posted October 21, 2017 Not sure I was clear. I am looking for horizontal foot rests similar to later models. I have the pegs with the small foot rest. Thanks. Share this post Link to post Share on other sites
Retired Wrencher 6,687 #7 Posted October 22, 2017 Pho Guy Just keep an eye out on E-bay or look here for a parts vender. I 1 Share this post Link to post Share on other sites
JimmyJam 542 #8 Posted October 22, 2017 Update: I found the second peg-style footrest. Now I have a pair. So, you are thinking of modifying to the later style of flat footrest? I have a restored pair for sale. Let me know. Here's a pic! 1 Share this post Link to post Share on other sites
Pho Guy 49 #9 Posted October 23, 2017 Jimmy Jam, I have sent you a message. Thanks to all for your help. This site is a great resource. 1 1 Share this post Link to post Share on other sites
JimmyJam 542 #10 Posted October 24, 2017 20 hours ago, Pho Guy said: Jimmy Jam, I have sent you a message. Thanks to all for your help. This site is a great resource. Thanks for PM. Yes this is an awesome site. Share this post Link to post Share on other sites
JimmyJam 542 #11 Posted October 24, 2017 The footrests that I have pictured are from a 1976 B-80 that I am parting out. I probably have the cross support piece that ties the two footrests together under the seat pan, as well as the B-80 seat pan. I will send you all the measurements so you can make sure that style footrests will bolt up to your 657 with minimal fabrication. Share this post Link to post Share on other sites
55rj35jr 626 #12 Posted October 24, 2017 This is what would be original on it Share this post Link to post Share on other sites
JimmyJam 542 #13 Posted October 24, 2017 3 minutes ago, 55rj35jr said: This is what would be original on it Exactly 55rj35jr. However PHO GUY already has that setup on his 657. What he is looking to do is remove the existing footrests and replace them with the later long horizontal type style. What he is asking is if he purchases those later type style would he have to make any modifications to his 657 to make them fit. Share this post Link to post Share on other sites
Pho Guy 49 #14 Posted October 25, 2017 Thanks JimmyJam, that is correct. Share this post Link to post Share on other sites
JimmyJam 542 #15 Posted November 2, 2017 PHO GUY Here are the measurements: Left-side (as you would be sitting on tractor) post must extend 7-1/2"; Right-side post must extend 5-1/2", From the dash tower 2 rear support bracket is 7-3/4", from the center off the front posts to rear support is 19-1/2". I have attached a pic of my 1974 B-80 setup if that helps. Let me know if that is something you can modify to work on your tractor. 1 Share this post Link to post Share on other sites
Pho Guy 49 #16 Posted November 3, 2017 JimmyJam, I have sent you a message. Thanks for your help. Share this post Link to post Share on other sites
