Lane Ranger 11,694 #1 Posted October 17, 2017 Here is a photo I took this afternoon of a Bad Third Gear and an Old but better/good one! 4 2 Share this post Link to post Share on other sites
WHX?? 53,566 #2 Posted October 17, 2017 Been ther seen that Lane ..you do know Lowell @wheelhorseman has them new? Unless you want to open it again? 3 Share this post Link to post Share on other sites
wallfish 18,842 #3 Posted October 17, 2017 It doesn't take much gear grinding to round over those 3rd gears. Every tractor missing a belt guard is suspect to this. 6 Share this post Link to post Share on other sites
Cvans 1,009 #4 Posted October 17, 2017 (edited) 2 hours ago, wallfish said: Every tractor missing a belt guard is suspect to this. I had not seen this before. Thanks for the info. Edited October 17, 2017 by Cvans 1 Share this post Link to post Share on other sites
Racinbob 12,493 #5 Posted October 17, 2017 Here's another shot of them. The left one is a NOS gear I got on Ebay well before Lowell was offering them. It's now in my Suburban. It's pretty clear why this is a weak spot in these transmissions. 1 Share this post Link to post Share on other sites
Lane Ranger 11,694 #6 Posted October 17, 2017 Even makes my teeth hurt Bob! The older worn but good ones are steps away from slipping ! The years take their toll on my teeth as well! I guess there is good reason for machinists and dentists! 3 Share this post Link to post Share on other sites
Racinbob 12,493 #7 Posted October 17, 2017 7 hours ago, Cvans said: I had not seen this before. Thanks for the info. No belt guard = grinding gears unless some other method is used to stop the drive belt. Also, ignore the blurb in the older owners manual that states "depress the brake/clutch half way when shifting while in motion". Always come to a complete stop. Another thing is input shaft play. With the transmission in 3rd gear if there's any in/out play of the input shaft that equates to the input gear disengaging from the inner teeth of the 3523 gear that same amount. 2 Share this post Link to post Share on other sites
WHX?? 53,566 #8 Posted October 17, 2017 (edited) 2 hours ago, Racinbob said: Another thing is input shaft play Good point Bob as I woulda never thought of that. Could a guy shim the input shaft during a rebuild to take care of that? 9 hours ago, Cvans said: . Thanks for the info. Your welcome, the 3523 gear conundrum is brought up here a lot. For more info put 3523 in the search block and you will find a few threads. Edited October 17, 2017 by WHX12 2 Share this post Link to post Share on other sites
Racinbob 12,493 #9 Posted October 17, 2017 That's exactly what I did on my 5010. I had about 1/10" in/out play in 3rd. I could actually feel the shifter push the rails sorta past the balls until the 3523 was fully engaged with the input gear. I would let go and it would pull back in place which separated the two gears a bit. I purchased a variety pack of shims from Grainger and experimented until I liked the feel when the detent balls latched it into gear. Zero play is your friend. 3 Share this post Link to post Share on other sites
WHX?? 53,566 #10 Posted October 17, 2017 Sounds like a lot of putting together, measure, take apart, shim, put together, measure, take apart, reshim, put together...stop me at any time here! Might be worth it tho! 2 1 Share this post Link to post Share on other sites
Racinbob 12,493 #11 Posted October 17, 2017 Actually not Jim. I measured the play with a dial caliper and I think it was on the second shot I was happy.I definitely think it was worth it. 2 Share this post Link to post Share on other sites
stevasaurus 23,530 #12 Posted October 17, 2017 As long as we got back into this 3rd/2nd gear thingy again. I think we should mention "5003 and 5010 Service Notes" paragraph #3 for everybody that would order or buy the 3523 gear. Transmissions before Serial # 11628...the spline shaft and the 2 fork gears have 10 involute splines. On transmissions after Serial # 11628 the spline shaft and 2 fork gears have 11 involute splines. It should be noted that these parts have the same part number...ie...3rd/2nd gear in both styles is part # 3523 and so on. If you count the teeth on Lane's, RacinBob's and Lowells gears...they are all the 11 tooth style. Make sure you count the teeth in your gears. Lane does have some of the 10 tooth style, if he would like to add some pictures. 2 4 Share this post Link to post Share on other sites
Lane Ranger 11,694 #13 Posted October 17, 2017 **** Steve mentioned some mof the splined gears for the shifters are 11 teeth and some are 10. I have three sets. two are 11 tooth and one is 10. The Input /drive shaft gear will ride smoothly in the third/second gear for either the 11 or the 10 tooth spline gear set. Not the greatest pics here but just did fast a few minutes ago. In first photo the one on right has 11 teeth and the and one on the left has ten. Both of the lower imput/drive shaft gears will interchange! 4 Share this post Link to post Share on other sites
