Pollack Pete 2,273 #26 Posted October 12, 2017 Not a bad looking 520H.You'll appreciate that aux.fuel tank.Those Onan's are hogs when it comes to fuel.Haha.Just be careful you don't back into anything.Have fun with your new toy. 2 Share this post Link to post Share on other sites
Steve_O 25 #27 Posted October 12, 2017 Whx12, Both front tires are pretty well weather checked, and the leaker has a big gash in the side wall. But tube may serve as a stop gap. If I was to buy new tires, what is recommended assuming primarily winter duty with heavy blower. Pricey tri-rib, 5-rib, Carlisle snow tires or generic turf tires. Share this post Link to post Share on other sites
Searcher60 209 #28 Posted October 12, 2017 Agri-supply has the best tube prices by far. Their tire prices are good also. Share this post Link to post Share on other sites
Ed Kennell 41,772 #29 Posted October 12, 2017 (edited) 3 hours ago, Steve_O said: If I was to buy new tires, what is recommended assuming primarily winter duty with heavy blower. Pricey tri-rib, 5-rib, Carlisle snow tires or generic turf tires. These blowers have a mind of their own when it cones to steering. Turfs are just not aggressive enough. A deep 3rib or 5 rib is probably best with a bar tread as a second choice. Some also use a chain around the OD of the turf tires with success. Edited October 12, 2017 by Ed Kennell 1 Share this post Link to post Share on other sites
WHX?? 51,688 #30 Posted October 12, 2017 3 hours ago, Steve_O said: front tires are pretty well weather checked Yeah mine were too but some cheap tubes were the answer. if the gash is real deep may have to spring for new tires. Got other horses that needed shoes worse and I can save up for some nice 5 rib V-61's. Plan on going that route when I finish my 2 stage refresh project and get ready to put it on. I think these are what most guys here are running. http://www.millertire.com/products/implement-tires/rib-implement-tires/16x6-50-8/16x6-50-8-v61-hd-5-rib-170-60-8-6-ply/ Keep in mind these tires need tubes anyway. 1 Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #31 Posted October 12, 2017 10 hours ago, ohiofarmer said: Another taco bell salute??????? Wheel Horse Ala King, Yum, checked my drawer's, Oop's Share this post Link to post Share on other sites
608KEB 796 #32 Posted October 12, 2017 I agree with tubing the tires if the weathering is minor. I think you got a excellent deal. All the accessories are worth $800.00. 1 Share this post Link to post Share on other sites
ericj 1,579 #33 Posted October 12, 2017 3 hours ago, Ed Kennell said: These blowers have a mind of their own when it cones to steering. Turfs are just not aggressive enough. A deep 3rib or 5 rib is probably best with a bar tread as a second choice. Some also use a chain around the OD of the turf tires with success. I respectfully disagree with you Ed on the tires on a snowblower, I don't have a problem with turf tires on my snowblower tractors, but I do on plow tractors. if you angle a plow on a tractor it will push the front end in heavy wet snow. if the blower pushes you just lift the blower a little and put weight on the front end and the tractor will turn where you want it. Not saying that other tires wouldn't be a nice plus and help some, every little bit helps right ? but not totally necessary good luck eric j 3 Share this post Link to post Share on other sites
Ed Kennell 41,772 #34 Posted October 13, 2017 (edited) I hear ya Eric. I don't have a steering problem on the first pass in new snow when the pressure is equal on the blower. But after that, the blower tends to keep going toward the wing that is cutting the new snow. And with my steep driveway and stone road, I have to lift the blower to back out and realign. Of course when you lift the blower, you loose traction on the rear wheels. I have added wheels to my blower that should help it to track in a straight line, but we haven't had a good snow to test it in for a few years. Maybe this will be the year. BTW Eric, we lost the football game last night. Edited October 13, 2017 by Ed Kennell 1 1 Share this post Link to post Share on other sites
ericj 1,579 #35 Posted October 13, 2017 51 minutes ago, Ed Kennell said: But after that, the blower tends to keep going toward the wing that is cutting the new snow. And with my steep driveway and stone road, I have to lift the blower to back out and realign. Of course when you lift the blower, you loose traction on the rear wheels. I don't have the problem with pull on the 2 stage blower so that makes the difference, and I'm sure the hill and stones makes a difference too. Lifting the that hulking 2 stage blower takes weight off the back tires, that is why I do run chains on my blower tractors. if we get some snow this year I might get to try the single stage blower more. I do remember running a single stage blower on my C120's and having the problem of the blower pulling in on the side of the snow. eric j 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #36 Posted October 13, 2017 Best of luck with your new machine, it will do the job. Glenn 1 1 Share this post Link to post Share on other sites
Searcher60 209 #37 Posted October 13, 2017 (edited) If that carb is the emissions carb just like on my 1997, it will probably need a little more than just cleaning. The Nikki emissions carb has an accelerator pump. That accelerator pump needs to work properly. Parts are available from Onan to fix the accelerator pump. Others will tell you to trash the emissions carb simply because they do not know how to repair it. But, my emissions carb works great now. If your compression gauge was accurate, your compression my be a little high due to carbon build up. Also keep in mind that the Onan book says to take compression readings with the engine warmed up. Edited October 13, 2017 by Searcher60 Share this post Link to post Share on other sites
Steve_O 25 #38 Posted October 17, 2017 It is a '96. I pulled off the tire with the gash. It turns out there was a tube in there and it was repairable. This was good as the tube I had purchased was a 13" misplaced in a 16x6.5-8 box. Tires are due for replacement, but they are back on and good enough for now. It has an emissions carb, with an accelerator pump. My sense is that it was not getting fuel on the idle circuit. The accel pump was giving a healthy shot of fuel when the governor eased up (tried to stall w/ no fuel from idle circuit). The engine would then rev up, running on the accel shot until the governor closed the butterfly and the cycle would repeat. I ran some sea foam through it and idle improved considerably, but after a while a hint of the hunting at idle returned. It really does need to be torn down and cleaned. It's not clear to me whether the idle feed restrictor is just covered with a welch plug or something more difficult to remove/replace. I'm also not sure if I need a rebuild kit on hand, or if the gaskets will survive disassemble for reuse. So, sea foam for the short term. Changed the oil and the transmission fluid. Needed an easy-out to remove the hydro plug. There was ATF in there, so I'll need to change again to flush. Share this post Link to post Share on other sites
Searcher60 209 #39 Posted October 18, 2017 (edited) That carb can be cleaned without removal in most cases. If you remove the top to clean the carb, there is a tiny spring and ball like piece for the accerator circuit that you need to be very careful not to loose as you lift the top off. I use carb/choke cleaner with the little spray stick to clean out the bowl and the jet, and all the tiny holes. You can also check float adjustment. Edited October 18, 2017 by Searcher60 Share this post Link to post Share on other sites
