Vinylguy 4,796 #1 Posted October 8, 2017 Mowing the lake front for the final time and this pulley flew off. Not sure what I need to repair it. Will be storing it at my brothers shop this winter where week ca n work on it. Share this post Link to post Share on other sites
pfrederi 21,183 #2 Posted October 8, 2017 Two bearings WH # 6593 Converts t0 1615-2RS There should be a spacer between the two bearings inside the pulley WH6595 Shaft looks to be in bad shape. 1 Share this post Link to post Share on other sites
rmaynard 17,589 #3 Posted October 8, 2017 Is this your Commando 8? Share this post Link to post Share on other sites
squonk 48,157 #4 Posted October 8, 2017 1 hour ago, pfrederi said: Two bearings WH # 6593 Converts t0 1615-2RS There should be a spacer between the two bearings inside the pulley WH6595 Shaft looks to be in bad shape. Yup shaft looks whupped. If you can't find another one, I bet @buckrancher could make you a new one. Share this post Link to post Share on other sites
Vinylguy 4,796 #5 Posted October 8, 2017 1 hour ago, rmaynard said: Is this your Commando 8? Yes Bob Share this post Link to post Share on other sites
rjg854 13,383 #6 Posted October 8, 2017 (edited) I just got done redoing the one on my 36" deck. What you guys are looking at is what is left of the roller bearings and a spacer. Easy cheap fix. The bearings didn't even cost $5 1 hour ago, squonk said: Yup shaft looks whupped. If you can't find another one, I bet @buckrancher could make you a new one. Edited October 8, 2017 by rjg854 More information 1 Share this post Link to post Share on other sites
squonk 48,157 #7 Posted October 8, 2017 I just blew that pick up. You may be right as long as the races come off the shaft. I don't see any bluing so they may have not gotten too hot. Share this post Link to post Share on other sites
Vinylguy 4,796 #8 Posted November 17, 2017 (edited) We just got the races off shaft and the spacer is still usable. What is a good way to get the races out of the pulley without harming the pulley? They are soaking now. Also who sells the bearings I need? Edited November 17, 2017 by Vinylguy Share this post Link to post Share on other sites
953 nut 69,556 #9 Posted November 17, 2017 if you have a large vise or a hydraulic press you can find a deep socket slightly smaller than the bearing's OD and use it to press them out and a larger socket on the other end to press them into. Given the outside diameter, inside diameter and width any good industrial supply house or auto parts store can hook you up. 3 Share this post Link to post Share on other sites
pfrederi 21,183 #10 Posted November 17, 2017 (edited) You just need the generic number any bearing supply house maybe even auto parts store should be able to order them Two bearings WH # 6593 Converts t0 1615-2RS Edited November 17, 2017 by pfrederi 1 Share this post Link to post Share on other sites
Vinylguy 4,796 #11 Posted November 17, 2017 Thanks guys. Should have the commando ready for spring in no time. Share this post Link to post Share on other sites
rjg854 13,383 #12 Posted November 17, 2017 That sounds kind of funny to me, I don't remember the bearings being so tight that they had to be driven out. Are they rusted in place, maybe? 1 Share this post Link to post Share on other sites
953 nut 69,556 #13 Posted November 17, 2017 10 minutes ago, rjg854 said: Are they rusted in place, Could be, or they may have slightly fused themselves due to friction heat. Share this post Link to post Share on other sites
Vinylguy 4,796 #14 Posted November 17, 2017 1 minute ago, 953 nut said: Could be, or they may have slightly fused themselves due to friction heat. the bearings are out but the outside of them or races are still in the pulley. I am not where I can get an image right now. Share this post Link to post Share on other sites
Vinylguy 4,796 #15 Posted November 17, 2017 Only image I have at home. Is this a stop for the new bearings or is it part of the old bearing? I am definitely ignorant when it comes to bearings. thanks for the help 1 Share this post Link to post Share on other sites
squonk 48,157 #16 Posted November 18, 2017 (edited) You can use a large socket, bigger than the o.d. of the race to support the pulley. Then use a thin punch to catch the race edge and drive it out from the inside. Edited November 18, 2017 by squonk 3 Share this post Link to post Share on other sites
ranger 1,862 #17 Posted November 18, 2017 If you're sure it's the outer track of the bearing you're looking at, if you have a welder, lay down a few runs of weld,not an awful lot, on the bearing race. What will happen is, the metal will expand, then after cooling, will be slightly smaller than it was originally. The bearing should then drift out much easier with less chance of damage to the housing. 2 Share this post Link to post Share on other sites
Vinylguy 4,796 #18 Posted November 22, 2017 should have thought of this sooner. Called A-Z tractor and he is sending me the parts I need ready to bolt on. problem solved. thanks everyone for the helpful replies. 2 1 Share this post Link to post Share on other sites
Vinylguy 4,796 #19 Posted December 1, 2017 The new to me pulley and bearings arrived and I picked up a new belt at car quest. Installed them yesterday and greased up the deck. Mowed a small patch of grass to make sure everything worked as it should. I am ready for spring. Thanks again for the help!! 4 1 Share this post Link to post Share on other sites
