TonyToro 1,190 #1 Posted September 22, 2017 I have the raider running and she is pulling well for my son but it still seems to have a carb problem. The carb was cleaned and all settings back to factory and "tuned" from there. It idles perfect and runs smooth. It just doesn't like to start or quickly throttle up from idle. With the choke on from cold it will initial fire and dies. It takes 4-5 fire on offs with the switch to get it to catch. Then once running it must be eased up with the throttle or it will die. We we are off in a few minutes to another fair to pull. Any thoughts would be appreciated. Share this post Link to post Share on other sites
Ed Kennell 47,399 #2 Posted September 22, 2017 Is the throttle plate shaft loose? It could be sucking air in around the shaft . With it running, spray it with carb cleaner. If it speeds up, it is sucking air. 2 Share this post Link to post Share on other sites
953 nut 69,551 #3 Posted September 22, 2017 Have you replaced the points and plug? 1 Share this post Link to post Share on other sites
TonyToro 1,190 #4 Posted September 22, 2017 11 hours ago, 953 nut said: Have you replaced the points and plug? Yes new plug and points last weekend. 11 hours ago, Ed Kennell said: Is the throttle plate shaft loose? It could be sucking air in around the shaft . With it running, spray it with carb cleaner. If it speeds up, it is sucking air. Oh ok good tip. I will go try that after dinner. thank you. I'll let you know how that goes. Share this post Link to post Share on other sites
Digger 66 3,530 #5 Posted September 22, 2017 12 hours ago, Ed Kennell said: Is the throttle plate shaft loose? It could be sucking air in around the shaft . With it running, spray it with carb cleaner. If it speeds up, it is sucking air. X-2 ^^^ Share this post Link to post Share on other sites
TonyToro 1,190 #6 Posted September 23, 2017 Ok just got done working on it for the night. Spraying carb cleaner by the top of the shaft the engine slows down? Thoughts? The shaft has some play left right up and down. Share this post Link to post Share on other sites
Ed Kennell 47,399 #7 Posted September 23, 2017 (edited) Hmm, they usually speed up. But it is indicating you have air leaking in. I would install a new shaft bushing or just replace the carb. Are the jets set to spec? Edited September 23, 2017 by Ed Kennell Share this post Link to post Share on other sites
Digger 66 3,530 #8 Posted September 23, 2017 8 hours ago, TonyToro said: Spraying carb cleaner by the top of the shaft the engine slows down? Thoughts? The shaft has some play left right up and down. Carburetor cleaner will kill the engine if it's entering the venturi . Starting fluid makes 'em speed up . Speaking from memory , there's a bushing kit available that comes with a new throttle shaft and a bushing with an oversize O.D. that will correct this . I did mine years ago but lost the before and after pics in the great computer meltdown . 3 Share this post Link to post Share on other sites
squonk 48,156 #9 Posted September 23, 2017 3 hours ago, Digger 66 said: Carburetor cleaner will kill the engine if it's entering the venturi . Starting fluid makes 'em speed up . Speaking from memory , there's a bushing kit available that comes with a new throttle shaft and a bushing with an oversize O.D. that will correct this . I did mine years ago but lost the before and after pics in the great computer meltdown . I have tried to buy that kit from several online vendors. Seems like they are always not in stock! If any one has a source besides Brian Miller let me know. I'll buy you a hot dog at the show! 1 Share this post Link to post Share on other sites
TonyToro 1,190 #10 Posted September 23, 2017 11 hours ago, Ed Kennell said: Hmm, they usually speed up. But it is indicating you have air leaking in. I would install a new shaft bushing or just replace the carb. Are the jets set to spec? I am dropping the carb off to my local repair shop. His dad was an old time wheelhorse guy. He said he has NOS parts. I will have him clean it and do what it needs. Thanks for the tips to pin point. 18 minutes ago, squonk said: I have tried to buy that kit from several online vendors. Seems like they are always not in stock! If any one has a source besides Brian Miller let me know. I'll buy you a hot dog at the show! When I go Monday I'll see what he has for WheelHorse parts. Share this post Link to post Share on other sites
oldredrider 2,553 #11 Posted September 24, 2017 @Squonk, you can get carb bushings at True Value hardware stores. Hillman bushing #58087. Just double stack them. Most likely, the throttle shaft will not need replacing. I like my hot dogs loaded! 2 1 Share this post Link to post Share on other sites
roadapples 6,987 #12 Posted September 24, 2017 @oldredriderwithout seeing these bushings yet, not sure what you mean by double stacking... Share this post Link to post Share on other sites
oldredrider 2,553 #13 Posted September 24, 2017 They are thinner than the Kohler bushings. Just use two of them stacked. 1 1 Share this post Link to post Share on other sites
Tuneup 1,459 #14 Posted September 24, 2017 I got mine at the blessed Ace Hardware. Two stacked and all the play is gone. Good luck! 4 Share this post Link to post Share on other sites
953 nut 69,551 #15 Posted September 24, 2017 8 hours ago, oldredrider said: double stack them. Most likely, the throttle shaft will not need replacing. An oiled felt washer between the two bushings could help seal them. 2 Share this post Link to post Share on other sites
TonyToro 1,190 #16 Posted September 24, 2017 9 hours ago, oldredrider said: @Squonk, you can get carb bushings at True Value hardware stores. Hillman bushing #58087. Just double stack them. Most likely, the throttle shaft will not need replacing. I like my hot dogs loaded! Oh no kidding. Ok I'll head there after work tomorrow. Thank you for that tip. I'll post up how it goes. 11 minutes ago, 953 nut said: An oiled felt washer between the two bushings could help seal them. Ok I'll get those too. Are there going to be bushings on the top and bottom of the throttle shaft? 1 Share this post Link to post Share on other sites
TonyToro 1,190 #17 Posted September 27, 2017 (edited) I installed 2 hillman bushings last night. Super easy. There was a rubber conical washer in there. Odd. It starts much better. A little more time and all the bugs will be worked out. Thank you guys for the tips. Edited September 27, 2017 by TonyToro 3 Share this post Link to post Share on other sites
