crazyhorse1056 109 #1 Posted September 17, 2017 I'm replacing the axle seal and bearings in my 3 speed unidrive and need to know if the old seals and bearings were originally one piece because the book shows #1232 seal and #1528 needle bearing the ones I removed were one piece the brake shaft is the same way Share this post Link to post Share on other sites
stevasaurus 23,717 #2 Posted September 17, 2017 I would sure like to see a picture of what you think are a one piece bearing and seal. I know of no 1 piece bearing and seal for any wheel horse transmission. I can give you a list of all the bearings and seals that is takes to replace in a #5053 transmission. 2 Share this post Link to post Share on other sites
crazyhorse1056 109 #3 Posted September 17, 2017 Will upload pictures for you If I could see a picture of the 1232 seal it would help or had the dimensions of it 2 Share this post Link to post Share on other sites
953 nut 66,699 #4 Posted September 17, 2017 You could buy the kit listed here and have all you need. https://www.wheelhorsepartsandmore.com/transmissions.html#!/Base-Kit-1/p/85721183/category=23548039 This list attached has the standard part numbers used at NAPA or any industrial supply house. 1-3&4 speed UNI DRIVE TRANS 2 (2).pdf 3 Share this post Link to post Share on other sites
Racinbob 12,996 #5 Posted September 18, 2017 That may look like it's just one piece but it's two. The seal can be easily picked out with a small screwdriver and the new one installed. As long as there's no axle slop no further disassembly required. 2 Share this post Link to post Share on other sites
stevasaurus 23,717 #6 Posted September 18, 2017 Here ya go. That seal is only about 1/8" thick. 4 1 Share this post Link to post Share on other sites
