FatJackDurham 318 #1 Posted September 6, 2017 So everyone dreams of having a loader on their tractor right? But there is the building, the hydraulics, the framing and attachment, what a hassle. But it might be easier to use a plow frame, attach a pivot box on the front and use that as a lowlevel bucket, just to move mulch around the yard. Especially if you have GT-14 with a hydraulic to do the lift. All you would need is an electric linear actuator to do the dumping. And, if you have a GT-14, you already have a cigarette lighter to plug it or a winch in when you have it attached. So, a decent linear actuator for this small application would draw about 15 amps under load. I am not sure how many amps my GT-14 stator produces, but I know I can add a 15/20 amp stator to the K321 engine. My question is, if I do that, what else to I need to do to make sure it all works? Is there a different condenser for the sparks? A different solinoid? I different voltage regulator or rectifier? Share this post Link to post Share on other sites
953 nut 63,922 #2 Posted September 6, 2017 Why not just get a "Johnny Bucket"? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #3 Posted September 6, 2017 Here is a parts list. Both the 60125b and 60149a specs show 15 amp stator. 1 Share this post Link to post Share on other sites
FatJackDurham 318 #4 Posted September 6, 2017 3 hours ago, 953 nut said: Why not just get a "Johnny Bucket"? Building one is what I had in mind. I think I can do it cheaper that the $1500 that a Johnny costs. 2 Share this post Link to post Share on other sites
953 nut 63,922 #5 Posted September 6, 2017 14 minutes ago, FatJackDurham said: Building one is what I had in mind. I think I can do it cheaper that the $1500 that a Johnny costs. Probably has been done, may be able find an internet article on it. Share this post Link to post Share on other sites
FatJackDurham 318 #6 Posted September 6, 2017 3 hours ago, gwest_ca said: Here is a parts list. Both the 60125b and 60149a specs show 15 amp stator. Mine is a 6010B, and going by the 6010 spec, if I am reading correctly, it's a 10 amp system, breaker less. There is a 15 amp stator that I could use, and the only other parts I would need would be a rectifier and a trigger lead. Still probably not a good idea.... Share this post Link to post Share on other sites
FatJackDurham 318 #7 Posted September 7, 2017 I see the specific stator for the K321 is unavailable, and people are charging stupid prices for it. The same stator for the K341 engine is much cheaper. I wonder if it would work? The K341 seems to have been identical to the K321 except the cylinder bore and head. Even the shaft is the same, so I wonder if the flywheel and stator parts are the same..... Share this post Link to post Share on other sites
cafoose 3,575 #8 Posted September 7, 2017 I successfully converted my GT-14 from 10 amp to 15 amp and also converted from electronic ignition to points Here are some threads on how I did it: 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #9 Posted September 7, 2017 12 hours ago, FatJackDurham said: Mine is a 6010B, and going by the 6010 spec, if I am reading correctly, it's a 10 amp system, breaker less. There is a 15 amp stator that I could use, and the only other parts I would need would be a rectifier and a trigger lead. Still probably not a good idea.... Spec 6010b is correct for the 1969 and 1970 GT-14's. Toro has incorrectly listed the engine as 60125b and knew that but missed it. Garry Share this post Link to post Share on other sites
pfrederi 19,785 #10 Posted September 7, 2017 If the linear actuator only draws 15 amps even 20 why change the charging system. You are not operating the actuator a dump control continually, probably only a small fraction of the time. Battery will cover draw and then be recharged between uses. If you have a breakerless system the engine isn't using any other electricity for a ignition system so between uses of the actuator the battery will be getting well charged...unless you are working in the dark with lights on.... 2 Share this post Link to post Share on other sites
FatJackDurham 318 #11 Posted September 7, 2017 1 hour ago, pfrederi said: If the linear actuator only draws 15 amps even 20 why change the charging system. You are not operating the actuator a dump control continually, probably only a small fraction of the time. Battery will cover draw and then be recharged between uses. If you have a breakerless system the engine isn't using any other electricity for a ignition system so between uses of the actuator the battery will be getting well charged...unless you are working in the dark with lights on.... To do that, I would hook directly to the battery, I guess. You don't thing that would still cause an issue? It could work, i guess. I'll price out the steel need for a POC and see if it's worth trying. 13 hours ago, cafoose said: I successfully converted my GT-14 from 10 amp to 15 amp and also converted from electronic ignition to points Here are some threads on how I did it: Cool! I'll check that out! I was curious about that. Why did you switch to points, may I ask? To get a tachometer to work? I was thinking of doing it to convert it to fuel injection turbo, merely as a thought experiment. I don't have the skills to really do it. Share this post Link to post Share on other sites
cafoose 3,575 #12 Posted September 7, 2017 1 hour ago, FatJackDurham said: Why did you switch to points, may I ask? To get a tachometer to work? When I got the tractor the wiring was hacked and it didn't run for five years according to the previous owner. I am unfamiliar with the old breakerless ignition and heard that the parts are expensive and hard to find so I found an engine with a broken rod for $50 that had all the parts I needed for the conversion. 1 Share this post Link to post Share on other sites
pfrederi 19,785 #13 Posted September 7, 2017 (edited) Incidentally I do not think Kohler made a 20 amp system for the K series. 10 15 and a rare one 30 which I have only seen on the big iron twins K482/532. May be on some singles but not many.... Edited September 7, 2017 by pfrederi 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #14 Posted September 7, 2017 @FatJackDurham I use a Linear actuator on my 310--8 to raise and lower my rear hitch. Never had any problem with the electric system since it was installed . Share this post Link to post Share on other sites
