HandCannotErase
Toro 212-5 no electrical power
HandCannotErase
Hello everyone. The other day I picked up a 92 Toro 212-5 lawn tractor with no deck non-running for $30 (MN: 32-12O503). The guy I bought it from said the ignition was left on with the headlights on and killed the battery so it should just need a new one. I made attempts to jump start the tractor, it would get power (the headlights would turn on and clutch would click) but wouldn't crank. I tried jumping the solenoid terminals to see if the starter was good (and it does work, tho I couldn't attempt to start the tractor due to the position of the solenoid terminals I couldn't maintain a good connection). But since doing that I've lost all electrical power on the tractor; absolutely nothing turns on, even with a new battery. Did I short something out? Also when I got the tractor I noticed one of the fuses had melted into the fuse block, so I spliced in some new connectors and fuse (as well as replacing the 2 other fuses). I tested the key switch and thats working fine. All my connections are good.
I'm really stumped, I'm not sure where to go from here. I'm really not the best at figuring out electrical issues. If it was a mechanical issue I'd have had it running the same day I got it.
Edited by HandCannotErase
gwest_ca
This should simplify it
Garry
HandCannotErase
So I looked over the wiring and found the seat switch wires were cut, so spliced them back together. I also took the solenoid off and inspected the terminals and cables, everything looks okay, so I put it all back together. Now whenever I connect the battery the starter continuously spins (but doesn't engage the engine) until I disconnect the negative battery cable (which will arc when I do that).
What on earth is going on??
953 nut
:WRS:      You may have a bad solenoid. Remove the lead that goes to the engine starter and connect the battery cables, turn the key and see if it closes, check the output with a test light to see if it is working.
You will probably find that it isn't getting enough voltage to allow it to go to full speed. Could be the Bendix drive needs to be cleaned up too.
gwest_ca
Disconnect the small wires from the solenoid small terminals and see if the starter still wants to run. If it does the solenoid is shorted internally and requires replacement.
Garry
HandCannotErase
So the solenoid was bad and I found a replacement for $20. It arrived today, I installed it, and it's doing the same thing: running the starter when I connect the battery.
Somewhere the circuit is being completed without the key being on, but it must not be enough to make the starter engage the engine. Like I said above the ignition switch is fine, I tested it and it's working like it should be. I'm really stumped here.
gwest_ca
2 large terminals on the solenoid.
One terminal has a white wire that goes to the battery (+).
The red wire on the other large terminal goes to the starter.
2 small wires on the solenoid.
Black wire grounds the solenoid coil.
Purple wire supplies power only with the key in the start position.
If you leave these 2 wires disconnected what happens when you connect the battery cable?
Garry
ohiofarmer
  It could be that the switch is melted together internally and the start circuit does not disengage. Short work to find this out if you are handy with a multimeter or a test light.
 You mentioned that a fuse block was melted, so the possibility of something like this increases.Even though you tested the switch, is it possible that the PO put on the wrong switch in his attempt to repair it?
Edited by ohiofarmer
  • Similar Content
    • Joe Reese
      By Joe Reese
      Wheelhorse Snow blower Fits c100's 500's etc. with a front mule setup. Works. Comes with lift Flag & Lift spring relief. Also have a set of rear tire chains for additional - $50
      Have a set of custom exctra heavy rear wheel weights if interested as well. $75
      Snow Blower Only, Tractor Not For Sale.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • Stratman
      By Stratman
      This is a (1-Owner) 42” Single Stage snowblower attachment (low hours of use) . This is the Attach a Matic system that will fit WHEELHORSE- Toro 5Xi series tractors , as well as New Holland GT (18 , 20 & 22) series machines . It comes complete , with Factory Manual , chute direction crank arm & support , every clip , nut n bolt , bracket needed to mount it to your tractor . Only used on paved surface / Rock Solid ~ Light surface rust only , No holes or weakened metal , nice skid wear pads .
      The (dedicated) Mule Drive & Drive Belt are also included . It works Great , however I now have a plow truck , and no longer need this attachment for my mower .
      Note ; I also have the W/H 75lb wheel weights & tire chains , that can be worked into the deal (if needed) !!!!!
      For additional purchase information ; Please Reply with a name & phone number / I will respond with with my Contact info ; Thanks 4 lookin’ / P.S. I can skid this all up & drop off @ FASTENAL for your Pre-Arranged shipping .
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
