Mal(Pa) 73 #1 Posted August 22, 2017 Well guys,I'm back. I've been busy trying to keep my gravel driveway from washing out to no avail. Washed out 4 times already.Trying to keep the drainage ditch open but with each rain, it fills in and water goes down the driveway along with"of coarse" the gravel. The amount of water in these downpours lately is amazing then it was every afternoon for I don't know how long.Thanks for letting me vent guys as I'm sure most have had these kind of things happen. Mal 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted August 22, 2017 While maintaining over 70 miles of range roads at work.... keeping material in place is one of my specialties. Post up a pict here, let's see what your working with. 6 Share this post Link to post Share on other sites
Mal(Pa) 73 #3 Posted August 22, 2017 12 minutes ago, AMC RULES said: While maintaining over 70 miles of range roads at work.... keeping material in place is one of my specialties. Post up a pict here, let's see what your working with. Ok,you got me.Ha Ha I'm just 1 old guy with a shovel, a hoe, and a tractor with a 7 ft back blade working against gravity and mother nature on a 150 ft drive way slanted toward the ditch. Mal Share this post Link to post Share on other sites
AMC RULES 37,254 #4 Posted August 22, 2017 You got a back hoe there to change it's pitch... lower the grade, on the high side of the drive way(side farthest from the ditch) Even a slight change in elevation here, will have a dramatic effect on the speed of the water entering your ditch. Slows it down, & will really help your material stay put. 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,696 #5 Posted August 22, 2017 Depending on the grade, small periodic rip rap dams (old broken concrete) placed across the ditch will also help slow it down. Water will pool behind as it makes its way through the gaps in the dams...Could also line the ditch with 1"-3" broken stone. It will keep base of ditch from eroding and slow it down... Pic would help! Share this post Link to post Share on other sites
c-series don 11,548 #6 Posted August 22, 2017 I've been operating a road grader for 25 years. One thing I've learned is that the sooner you can get the water off the road, the less washouts and potholes you will have. I actually dealt with this issue today! If water is allowed to accumulate, especially down a steep grade gravel road washouts are almost inevitable. 1 Share this post Link to post Share on other sites
953 nut 64,392 #7 Posted August 23, 2017 If you could cut the center of the travel lane down and fill it with rip rap and have the tire tracks pitched slightly toward the center it should direct and slow the water. May need to have an occasional drain line to divert the water to the drainage ditch. 1 Share this post Link to post Share on other sites
