Rick 55 BB 24 #1 Posted August 18, 2017 I'm trying to find out what length lift cable I need for my 1974 raider 8 , to lift my tiller ! tractor didn't have one on it when I got it . Is there a graph that shows what tractors took what length cables . And are the rockshafts interchangeable from different tractors . Any help would be appreciated . Thanks Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted August 18, 2017 (edited) @Rick 55 BB to Check with member @wheelhorseman as he makes new cables. He is in our vendors section. Edited August 18, 2017 by KC9KAS additional comment 4 Share this post Link to post Share on other sites
953 nut 68,536 #3 Posted August 18, 2017 Here is a link to the website for your cable. https://www.wheelhorsepartsandmore.com/parts.html 3 Share this post Link to post Share on other sites
Rick 55 BB 24 #5 Posted August 18, 2017 Thank you for the response to my question about my lift cable . And from what I read on the cable chart is pretty much the cables are all the same length . so if I find a used one with the rockshaft included it should fit my raider 8. as all the part numbers seam to be the same for most models and year tractors ? thanks. I've had wheel horses most of my adult life but am just now starting to play with them for more than just mow the lawn , now I have 4 . Share this post Link to post Share on other sites
953 nut 68,536 #6 Posted August 18, 2017 12 minutes ago, Rick 55 BB said: now I have 4 They are addictive! 13 minutes ago, Rick 55 BB said: used one with the rockshaft included it should fit my raider 8. That sounds like a safe statement. 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #7 Posted August 18, 2017 14 minutes ago, 953 nut said: They are addictive! That sounds like a safe statement. Thanks for the info , that's kind of what it looked like to me . Yes they are addictive , I have been trying to convince the wife that collecting and fixing these little beauty's up is her idea . lol not sure she believes it . YET ! 2 Share this post Link to post Share on other sites
Lee1977 7,750 #8 Posted August 21, 2017 The rocker shafts were changed then they went to the under the rear fender gas tank. The later model rocker shaft will not work on an older model tractor because it is too short. 1977 and back is what you need. 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #9 Posted August 22, 2017 17 hours ago, Lee1977 said: The rocker shafts were changed then they went to the under the rear fender gas tank. The later model rocker shaft will not work on an older model tractor because it is too short. 1977 and back is what you need. Well now that is some good info to have . I still haven't found a used one for sale yet , But I'm glad that I now know more about what I'm looking for . Thank you Lee1977 Share this post Link to post Share on other sites
JPWH 6,544 #10 Posted August 22, 2017 (edited) I have one from a 69 Raider 12. Pm me if interested. Edited August 22, 2017 by JPWH 1 Share this post Link to post Share on other sites
Lee1977 7,750 #11 Posted August 23, 2017 (edited) What are we talking about rocker shafts or bellcranks? The picture above shows a bellcrank. The rocker shaft is mounted in the rear fender support. The bellcrank looks the same but the lift lever is completely different in 1978 and up models. Edited August 23, 2017 by Lee1977 Share this post Link to post Share on other sites
Thor27 892 #12 Posted August 23, 2017 (edited) I think 75 is the magic year when they changed from the hinged fenders? My 76 has the same seat mounting as the later tractors but with out the rear tank, it uses the shorter style too. Following along to see what you come up with, I haven't seen a rock shaft on the earlier tractors. My raider has a long cable all the way up to the bellcrank, but it is a 68. 3931 was the part number for the cable. Lowell has them on his site at the link bellow: LOOK HERE! Edited August 23, 2017 by Thor27 add p/n and link Share this post Link to post Share on other sites
