JZilla024
Hello everyone!
I recently inherited my grandpa's
Wheel Horse 753. I remember it running before his health declined about 15 years ago. My intentions are just to get it running and do a mild restoration, it'll stay in the family.
Without further ado, here it is!
Having a hard time with pictures due to no phone service at my shop. I'll be sure to update soon.
  • Like 6
  • Excellent 2
AMC RULES
welcomewagon.gif.8dccb1c4cbc4869fffb85174c881cfc1.gifhdr-logo-100b.png.51ce811ab28059f561cb82a56f68d214.png
Ken B
How about some more pictures? If that is the original paint I think I'd leave it alone...
953 nut
:WRS:       It looks like your grandfather took good care of his equipment. :handgestures-thumbupright: Glad you will be keeping it in the family, that makes it special.  :text-coolphotos:
SylvanLakeWH
:text-welcomeconfetti:
Another Michigander!
JZilla024
From the picture with id plate looks like paint overspray. I think the original red can be seen underneath.
  • Like 5
JZilla024
Here's what I know. It doesn't run, haha. The carb was disgusting so im cleaning that up and ordered a carb rebuild kit for the k161.
Spark plug sparked and looked clean enough. Spayed some starting fluid in and it made a couple loud bangs but no attempt to run on it's own.
Any advise, suggestions, or questions for me now that i have a few more pictures?
AMC RULES
In addition to the carb, completely clean the fuel delivery system, empty+clean tank, new fuel line & filter too.
Use no more starting fluid.  :blink:
Ken B
Yup, I'd leave that one alone. It looks real nice and has grandpa's finger prints all over it. Maybe a light clean up and a repaint of the rims. Of course, my opinion only.. If you can use it too push snow I think you'd be quite surprised at how strong a pusher it is.
  • Excellent 2
Electro12WH
What is the issue with the original gas tank?
JZilla024
I forgot to mention theres a blade out back that looks like it hooks to the wheel horse! Living in Michigan it would be super fun to clear snow with!
I'd assume it leaked. The whole 2 part tank or whatnot. I cleaned the fuel system and have a small inline filter I'll install when I'm putting it back together.
Chris G
I would definitely clean it up and keep her original. Clean all fuel delivery and carb. Check and either clean or replace points. Some fresh oil in the transaxle  and a good oil change on the engine. And also the two piece gasket for the tank is available through a member here. Here's is his email. ( rsgreco@embarqmail.com ) There great quality I just got one and there pretty easy to replace and he sends  instructions with it. Just don't over tighten the bolts is my tip.
JZilla024
Finally got my carb rebuild kit in the mail. Waiting for parts is torture! Heading out to the shop tonight. I'll be sure to update on my progress.
JZilla024
Installed the new gaskets on very clean carb. No luckin getting it started tonight. The spark plug was dry after cranking it. The gravity feed tank setup gramps had must not be working.
Im havent looked into cleaning or adjusting points. There is a stong blue spark from the plug. Air comes out plug hole and exaust so it must have some compression, right?
The electriclal he did is quite the job too upon further inspection. To the left of the kill button on the consol theres a 3 position pull knob that feels like its for headlights? I dont see in other pictures of 753s.
I really like this old tractor so im just going to keep trouble shooting and fixing things as i can.
Thanks for any input.20170906_171608.jpg.6a2e5f6b0b5264d55a3d921536cc1459.jpg20170906_180236.jpg.252f0eed4d6cdf577a9cd41707b50746.jpg
stevebo
Pressurize the tank with fuel in it. The needle my be stuck. I typically put some wd40 on the needle when installing it. You could also give the carb a light tap with a hammer and that may free it up.
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
