		Onan P-Series Ignition Module Replacement [Photos]
					By
Duramax7man7,   in Engines
Similar Content-
			 By lsc1257 By lsc1257
 I have a 1996 520H Wheel Horse for sale. The tractor has just over 800 hours on it. It comes with a 48 inch deck. The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago. This 520-H has the swept front axle so it can handle a 60 inch deck. I just replaced the battery and the deck belt this summer. The engine is a 20HP Onan and it starts right up but requires the full choke. The transmission is an Eaton 1100-062, hydrostatic. The deck is in rough shape but the spindles appear to be in good working order. The right rear tire has some cracking. The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck. Also included is a new PTO belt and several miscellaneous deck wheels and rollers. Additional pictures available upon request. Asking $500.
			 By Joe Warren By Joe Warren
 Wheel Horse
 Service Tool Kit
 Onan Industrial Engines
 ON-420-0556
 Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
 $129 plus shipping cost.
 Message me if you are interested in purchasing. Thank you. Joe
			 By Tenday By Tenday
 Experts - help please. I’m new to Wheel Horse Tractor life!
 So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
 I’m looking for help on diagnosing no spark.
 model - 417-8
 engine - Kohler KT17
 Done thus far: (aware that some have no implication on spark.)
 - new ignition switch
 - new battery
 - new starter
 - new ignition coil and wires w/ plugs
 - new condenser
 - new points
 - new starter solenoid
 - bypassed all switches except oil and seat.
 notes:
 idiot lights removed.
 All fuses tested with Ohms as well as visual inspection ..
 coil tested w/ ohms as well
 all switches bypassed except:
 -oil switch ( don’t think it has any implications other than a visual indication for idiot lights. )
 -seat switch
 ran a pos from batt direct to pos of coil - nothing; no spark.
 Electric is as follows:
 - Starter switch wired to solenoid
 - - solenoid to starter
 - - solenoid to batt
 - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
 - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil. Comes from switch and seat.
 Help - what the heck am I missing ?
			 By Rollo416H By Rollo416H
 I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester. The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good. I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch, and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter). Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived. Onanparts won't take anything back! There are a lot of coils on ebay and various suppliers from China. Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
 Thanks for any help!
 Rollo416H
			 By SPINJIM By SPINJIM
 1992, Wheel Horse 520-H. Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts. Seat is like new. Front tires are new. All tires hold air. Some repainting, but didn't need much; was stored indoors. New decals. Other new parts.
 Has swept front axle and Variable Ratio Steering. Belt cover ventilated to cool back cylinder. Rear wheel weights are 55 lbs. each.
