Duramax7man7
Onan P-Series Ignition Module Replacement [Photos]
WHX??
GREAT write up Andrew  and thanks for sharing! May be doing just this pending final  diagnosis. :handgestures-thumbupright:
Edited by WHX11
Duramax7man7
My pleasure mate! That's exactly why I did it.
lynnmor
Thanks for the excellent job.  :text-goodpost:
If anyone wonders why the Onans have a hotter rear cylinder, and valve seat problems, just look at how the oil filter mount and other parts block air flow.  If they wouldn't have mounted ignition and other parts to the cover we could easily pop it off and clean it at every oil change.
Duramax7man7
True. but as long as it gets blow out with a leaf blower or compressed air after every mowing day, especially in the dry summer mowing days (more dust and lighter grass clippings get sucked into the air path easier) I think that should extend the duration in between having to worry about cleaning it out.
 The issue I think mainly lies in owners that don't do this routinely. That debris build up, starts breaking down and then turns into insulation on that rear cylinder and causes failure.
Still great engines! ;)
rmaynard
:text-bravo:A picture(s) is worth a thousand words (and there might be a thousand words there too.)
Might want to get a MOD to pin this one to the top of the Engine section.
Duramax7man7
I agree. I'm sure that this is a common interest with any Onan powered tractor owner...
Here is a brief talk about it and the tractor running.
Going to change the oil later today...
Edited by Mastiffman
EricF
GREAT step-by-step! :text-thankyouyellow:
6bg6ga
I would say good job.  If I were to offer several ideas they would be to incorporate the troubleshooting of the ignition module, and coil prior to the disassembly process. You could probably sell it as a book.  The "Spark Ring" is nothing than a magnet. The simple test for that is will it repel another magnet. They very seldom if ever will go bad but may be damaged by junk like debris and such. They are what one would call a misunderstood part because most people simply like to throw parts at something thinking they are doing preventative maintenance. If it still will repel another magnet and is not damaged the part is still good.
You might touch on the importance of the thermal insulator under the module/sensor. Its job is to provide thermal protection. It is not to provide electrical isolation however.
Edited by 6bg6ga
graywolf1939
Great job with demo photos Andrew! As others have mentioned, a picture is worth a thousand words. I have a 1988 Model 518-H that suddenly would not start after turning it off and trying to restart within 1 minute. One backfire and never to start again. Long story short, I pulled the flywheel today and found the key that mounts on the crankshaft and extends into the ignition ring broken. The only piece remaining was the part that sits into the depression in the crankshaft. I was looking at your photos of your repair of ignition module, but I could not detect the key beyond the end of the shaft in your photo. As I do not have the missing part of the key, I "assume" (bad word) that this key actually does extend all the way into the larger key-way slot in the ignition ring?
The long key that sits in the flywheel and extends a bit beyond the inside of the flywheel was OK. The Ignition ring was free to move without it's locking key to the drive shaft, thus throwing the starting effort way off timing as it could free-wheel around the crank shaft.
graywolf1939
This is the key that is listed for the WH model 518-H, P218 Onan engine. My question is, which way does this mount on the crankshaft? If you insert the long end into the flywheel, there is not enough reach on the other end to reach the slot in the trigger ring. If you insert the long end into the trigger ring slot, the stub end is not long enough for the flywheel slot !! Are there TWO keys that must be used ? If there is only one key, does that mean that the trigger ring does not need a key in it's larger spaced slot, but uses just a friction fit on the crankshaft ?
lynnmor
I am currently working on a P220, this afternoon I'll pull the key if it isn't stuck, and let you know what I found.
gwest_ca
Always amazed at the detail in the illustrations
Garry
lynnmor
I looked at mine and found that the long tail goes back into the keyway of the ring.  There is plenty of key in the flywheel so I don't know what you mean about not being enough for the flywheel slot.  Get a new key and it can only go one way without sticking way out.  It might be possible that the ring is damaged in some way that it moved back, perhaps it should be removed and inspected.
just noticed that the illustration shown above shows the key opposite the way mine is installed.
Edited by lynnmor
Duramax7man7
The key on my tractor was simply a long key with no tab at the end. The spark trigger ring should sit on the crank in a manner in which it will be locked to the correct timing by the flywheel key. There is only one key.
If your ring sits too far back then pull it off and see if it is damaged on the inside bore in which maybe it's sitting back against the timing gear cover to much and not locking onto the key. If it looks like its centered properly over the spark trigger sensor module, then check to see if there is damage done to the key way on the inside of the ring. If not then maybe, just maybe the key was replaced from a previous owner because of shear and the replacement key was a bit too short and has moved.
 I would think that it was one of those three things.
Hope this helps.
corpline
Do you still have the mower? I was wondering if you could send me a picture of the wiring on the ignition coil. I've looked at the wiring diagrams and it doesn't describe the wiring for the ignition coil. The issue I have is the new ignition coil I've installed is not producing a spark on either of the spark plugs and before I installed the new ignition coil I had taken a picture of the wiring. Black wire attached to the negative (or ground) post and ORANGE & YELLOW wires are attached together on the positive post of the ignition coil. There's nothing for me to verify this is the right setup. The old ignition coil looked to be fried and it was not producing spark. With wires off the ignition coil I did measure between ORANGE (in the picture looks RED) and both BLACK & YELLOW 12 volts as ignition key is turned ON. Which leads me to question the YELLOW wire. Any help with picture or description of the wiring is greatly appreciated.
Edited by corpline
lynnmor
1 hour ago, corpline said:
Do you still have the mower? I was wondering if you could send me a picture of the wiring on the ignition coil. I've looked at the wiring diagrams and it doesn't describe the wiring for the ignition coil. The issue I have is the new ignition coil I've installed is not producing a spark on either of the spark plugs and before I installed the new ignition coil I had taken a picture of the wiring. Black wire attached to the negative (or ground) post and Red & Yellow wires are attached together on the positive post of the ignition coil. There's nothing for me to verify this is the right setup. The old ignition coil looked to be fried and it was not producing spark. With wires off the ignition coil I did measure between RED and both BLACK & YELLOW 12 volts as ignition key is turned ON. Which leads me to question the YELLOW wire. Any help with picture or description of the wiring is greatly appreciated.
:text-welcomeconfetti:
Go to the Wheel Horse Manuals section and download the manuals that pertain to your particular tractor.  There is also a Demystification Guide to help with electrical issues.  Finally download the manual for your Onan P220G.  With these resources, you can do proper testing and wiring.
corpline
Lynn thank you for the information but running into brick wall finding the supporting information you've provided.
Edited by corpline
lynnmor
Here is a place to start: Demystification Guide
1995 520H+96+97
The studs on the coil are different size, large and small.
The terminals of the wiring of the ignition module are different size, large and small hole.
Edited by 1995 520H+96+97
corpline
Thank you QWEST_CA (Gary) that's an awesome library. Unfortunately I have not found what I am looking for but with additional information I might be getting close. Based on the diagrams in the wiring manuals I see that I need to correct the color mentioned above from RED to ORANGE wire based information from the download library. Mystery continues on why no spark. Still strange to me that 12 voltage across (now corrected color) ORANGE wire and YELLOW wire with ignition ON. That's why I was hoping someone would post a color picture of their 520H ignition coil with wires posted so I can ruled that strange observation out of my list.
Edited by corpline
cleat
Here is mine.
Red from the ignition control, yellow(ignition power) and the black from the condenser go onto the + terminal
Black from the ignition control goes to the - terminal.
Cleat
corpline
Thank you Cleat :D I am still troubleshooting "no spark".
Duramax7man7
You can test the coil itself but on the Primary coil (small wire posts) as well as the secondary coil (main spark coil posts) for continuity and proper resistance.  I believe the secondary coil will be around 16k-19k ohms...
IIRC, You can also test the wires coming from the ignition module for signal as you are turning over the engine?
 Either way, you can find all that you need to know from the demystification guide for testing the ignition components to find your issue.
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
    • Rollo416H
      By Rollo416H
      I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester.  The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good.  I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch,  and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter).  Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived.  Onanparts won't take anything back!  There are a lot of coils on ebay and various suppliers from China.  Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
      Thanks for any help!
      Rollo416H
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
