WHwest8597 85 #1 Posted July 29, 2017 I'm looking for some info on how to service the PTO Clutch on a 315-8. This is my 1st electric clutch tractor and I was wondering how I remove every thing to grease the bearings. Share this post Link to post Share on other sites
pfrederi 21,145 #2 Posted July 29, 2017 You do not service them they are sealed ...You replace them, when they fail. (Yes i suppose you could press the bearings out pry out the seals and try to add some grease but i would not recommend trying it.) Share this post Link to post Share on other sites
WHwest8597 85 #3 Posted July 30, 2017 Any info on how to remove the Electric PTO? Share this post Link to post Share on other sites
pfrederi 21,145 #4 Posted July 30, 2017 None of my electric PTOs are nearly as new as yours. I would guess that yours probably comes off the same way. You push it off by removing the small bolt holding it to the crank shaft they use a bigger bolt threading it into the PTO itself an tightening it pulling the Unit off the crank. You do not use a gear puller!! (You will damage the pulleys) Share this post Link to post Share on other sites
