Chuck14025 9 #1 Posted July 19, 2017 I just acquired a 520H that ran for an hour. After sitting for a few days it started right up and quit after 5 seconds. Turn the key and nothing happens. If it were a fuel problem it would at least turn over. It won't even make a 'click' of the solenoid. I'm guessing the problem is electrical. Battery shows 12.6 volts. Load test for 10 seconds and it still has 12.2 volts. Battery contacts are clean. Have not checked the 'engine ground yet'. Haven't found it yet. Loosened and re-tightened cable connection at starter. Found the 30amp fuse severely burned. Replaced it. Still nothing. Cut the wires to the seat safety switch and soldered them together. Still nothing. Suggestions welcome. Share this post Link to post Share on other sites
Chuck14025 9 #2 Posted July 20, 2017 1 more clue: the voltmeter on the dash is not working. Share this post Link to post Share on other sites
Shynon 7,520 #3 Posted July 20, 2017 I would start with the 9 pin connector, mine kept stopping and the tach was not working. Unplugged it and 2 or the pins were discolored and corroded. Ordered a new one from @rmaynard in the vendor section. Replaced mine and all is good. Just picked up another 520 and was told it has no spark, connector looked the same as my other so I await another 9 pin connector before I proceed. 5 Share this post Link to post Share on other sites
Chuck14025 9 #4 Posted July 20, 2017 Thank you Shynon. I'll find the 9 pin connector and clean the contacts as best I can. Then I'll try to get a replacement as you suggested. 520h The 30 amp FUSE was fryed at the contact points, not inside the fuse itself. The wiring diagram indicates it runs to the COIL. Can anyone tell me how to TEST the COIL. Also, because the tractor started right up, ran for 10 seconds and quit then would not turn over, it acts like something is overheating very quickly and opening the run circuit. Is there a switch or circuit breaker somewhere in the 'run' circuit? Where is the 'kill' relay? Another dumb question: is there a kill switch I'm missing? Share this post Link to post Share on other sites
Chuck14025 9 #5 Posted July 20, 2017 I can't find 'Maynard' in the VENDOR section. Can anyone help? Share this post Link to post Share on other sites
WHX?? 53,589 #6 Posted July 20, 2017 Sounds like you have the host of electrical problems 520 are known for. Get the manuals for it with wiring diagrams out of the files section. You will need them. Also do a search on 520 electrical, you will find all kinds of problems guys have had and the fixes. Do start looking at the 9 pin and fuse block first. Bob @rmaynard guy is looking for a 9 pin... he'll be around Chuck ...give him a bit he's old! 2 Share this post Link to post Share on other sites
fast88pu 3,372 #7 Posted July 20, 2017 I have a 520H tractor side harness if needed 1 Share this post Link to post Share on other sites
WHX?? 53,589 #9 Posted July 20, 2017 Thanks TD... I can't do that on a stupid smart phone 1 Share this post Link to post Share on other sites
TDF5G 2,073 #10 Posted July 20, 2017 11 minutes ago, WHX11 said: Thanks TD... I can't do that on a stupid smart phone You're welcome. Glad to help. Share this post Link to post Share on other sites
608KEB 812 #11 Posted July 20, 2017 Check connections to fuse block. Also all safety switches 1 Share this post Link to post Share on other sites
ericj 1,579 #12 Posted July 20, 2017 up at the big show I was driving around my 416-H and shut it off waited for about 15 minutes, and then went to restart, nothing doa, all of the lights on the board went out, so I started to wiggle things to see what it would take to get it started and found the 30 amp fuse melted in to the fuse holder. got another fuse from a friend and still nothing. of course it was far away from all of my tools and test equipment. So Glenn Cockerham offered to tow it back to the show barn for me, didn't like to do it but had almost no choice, so we drug it back and I left it sit till Saturday when it was time to load it up. Turned the switch on and jumped the starter and she fired right up. Drove it down to the trailer and shut it off. then thought I wonder ?? and hit the key and it fired up. It actually started up. It's still sitting in the trailer, that's where I keep it, So I'll have to wait and see if it'll start next time I need it to. I think I'll know how to start it. eric j Share this post Link to post Share on other sites
953 nut 63,505 #13 Posted July 21, 2017 With any electrical problem the first step is to clean and tighten all electrical connections including grounds. Corrosion in the fuse holder could have caused the melting that occurred, it is basically a high resistance connection and resistors produce heat when current passes through them. 2 Share this post Link to post Share on other sites
