Alan R. 316 #126 Posted October 28, 2018 After discarding the chain drive the top sprocket was drilled and tapped 4 BA and an alloy bar bolted to it. This bar was drilled with extra holes for the push / pull rods so that various positions could be tried. The same was done with the bottom sprocket. The threaded rods are M6. These will be changed to round bar later and a better top bar made. All a temporary try out for now. Although this arrangement was better than the chain, there was still a lot of free play. A lot of this was from the various universal joints and male / female connections between the bottom sprocket and the front wheels. Better fitting U/J centers were made and various Male F/M, joints drilled and tapped for grub screws which tightened things up but still not enough. The gap between the pin and it's through hole can be seen below. The cavity for the small coil spring didn't help either as a lot of the bearing surface was lost. This was not used in the replacement centers. Probably cheap U/J's found at my usual parts supply location. 3 1 Share this post Link to post Share on other sites
Alan R. 316 #127 Posted December 16, 2018 Another update. The telescopic steering shaft was made from square box section tube, welded to the U/J which in turn plugged into the lower sprocket on the trailer. The inner sliding part was a length of 1/2" square bar filed to a nice sliding fit. This was drilled and threaded then screwed tightly onto the round rod which formed the other half of the shaft. A pin through the square bar and rod made sure nothing moved. A short extra piece was added later to give a bit more bearing surface although probably not needed. A bit of surface rust showing since it's last use. The large threaded hole is a left over from it's last life. The second photo shows it in it's storage position, held in place with the throttle cable. The trailer is disconnected by removing the throttle lever from the steering yoke, one screw, pulling the coupling pin and moving the trailer back which slides the two shaft sections apart. Coupling all together is just as simple. The throttle cable had to be extended to approx twice it's length. Think it was originally fitted to a lawn mower. Couldn't find anything suitable on the internet. The inner was 1mm. Most others found were 1.25 or 1.5mm. I could have opened up the cable slot in the carb piston but decided against this as after a bit of hunting found 1mm inner cable was available from China. A 5 metre length for £1 25 including postage. A 2 metre length of outer sleeve was found in the UK but couldn't find this to match the inner in China. Strange. After careful measurement the inner was cut to length and a short piece of brass tube soldered on one end. The carb top, outer sleeve etc was assembled followed by the lever end nipple being soldered in place. After connecting to the trailer everything was found to operate smoothly and with approx the same amount of movement as the original cable. This photo shows the new inner and brass tube nipple alongside the old. 3 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #128 Posted December 17, 2018 This has to be one of the most fascinating things I’ve ever seen. I’ve spent every free moment today since I found this thread reading it. Your ingenuity, resourcefulness, and craftsmanship is absolutely amazing. 2 Share this post Link to post Share on other sites
Alan R. 316 #129 Posted December 17, 2018 6 minutes ago, KyleLengerich said: This has to be one of the most fascinating things I’ve ever seen. I’ve spent every free moment today since I found this thread reading it. Your ingenuity, resourcefulness, and craftsmanship is absolutely amazing. Thank you. Share this post Link to post Share on other sites
Alan R. 316 #130 Posted February 1, 2019 Think I am near the end of this project now, apart from sorting teething problems out. During runs at last years shows, the clutch to gearbox drive chain kept locking up. The original chain tensioner wasn't up to the job. This has now been changed but not yet tested. Fingers crossed. There is still too much free play in some of the steering joints. Still working on how to overcome this. Mark ( meadowfield ) made up the decals. Thanks Mark. Couldn't get good photo's in my garage. Too many reflections etc with or without flash which also shows up dust specs. Need to retake in daylight, as and when. Dummy light and ignition switches were fitted but think the key could be slightly larger. A few more taken at the shows. And the almost finished trailer. Finally, the tractor needed someone to drive it while I just sat and enjoyed the scenery while being dragged behind. Hours of searching for a suitable size person resulted in nothing. As I wasn't allowed to borrow my 15 month old great grandson, ( he would have been cable tied on to stop him falling off ), the next best thing was to make something up. A head was obtained from China. Cheap as usual but a bit pink looking. His face was weathered, well he is a farm boy, using some of my old modelling paints which were well past the sell by date Some people say he is a little too brown, but he doe's get out in the sun a lot. An ice cream tub, wood, foam and tape were used to bring him to life. My great grandson donated some of his clothes. Calvin, that's his name, was knocked up in a hurry just before the shows, and had to make do with rough and ready gloves and hat until something better comes along. Here he is having fun and being followed by a Doc Brown ( from Back to the Future ) look a like. Don't all laugh at once. As said above, I think this just about wraps this project up, apart from a few modifications and better photo's of the decals. What next ? Watch this space. PS. Calvin had to wear sunglasses when looking at his passenger. 2 9 1 Share this post Link to post Share on other sites
BOB ELLISON 2,983 #131 Posted February 1, 2019 Alan you look like Albert Einstein. And from the looks of your work I believe you are. I've never done the degree of work you do and I though I was pretty good at figuring out problems. Great work and I enjoyed following along. 1 Share this post Link to post Share on other sites
Stormin 9,988 #132 Posted February 1, 2019 (edited) Good to see it's about finished, Alan. I don't remember seeing all those graphics, Especially the suppliers name. A. Robinson. Thought Robinsons made jams with the Golly on the jar. Edited February 1, 2019 by Stormin 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #133 Posted February 1, 2019 Absolutely amazing! 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #134 Posted February 1, 2019 (edited) Other than Calvin spending too much time in the tanning booth , every thing looks excellent. You and the D 80 need to make a trip across the pond so we colonists can see your work up close. Edited February 1, 2019 by elcamino/wheelhorse can't spell 2 1 Share this post Link to post Share on other sites
Alan R. 316 #135 Posted February 1, 2019 6 hours ago, BOB ELLISON said: Alan you look like Albert Einstein. And from the looks of your work I believe you are. I've never done the degree of work you do and I though I was pretty good at figuring out problems. Great work and I enjoyed following along. Thanks Bob. Share this post Link to post Share on other sites
Alan R. 316 #136 Posted February 1, 2019 3 hours ago, elcamino/wheelhorse said: Other than Calvin spending too much time in the tanning booth , every thing looks excellent. You and the D 80 need to make a trip across the pond so we colonists can see your work up close. Thanks Jim. Need to scrub Calvin's face and get him a passport before heading over the wet stuff. 1 3 Share this post Link to post Share on other sites
Alan R. 316 #137 Posted February 1, 2019 4 hours ago, KyleLengerich said: Absolutely amazing! Thanks Kyle. Share this post Link to post Share on other sites
Alan R. 316 #138 Posted February 1, 2019 5 hours ago, Stormin said: Good to see it's about finished, Alan. I don't remember seeing all those graphics, Especially the suppliers name. A. Robinson. Thought Robinsons made jams with the Golly on the jar. The Golly's were on the jam jars for years Norm, then as you know the PC ******** stuck their beaks in. Share this post Link to post Share on other sites
Stormin 9,988 #139 Posted February 1, 2019 Carol has a collection of Golly badges. 1 Share this post Link to post Share on other sites
Alan R. 316 #140 Posted February 1, 2019 5 minutes ago, Stormin said: Carol has a collection of Golly badges. Think we had some at one time, but might have been cut outs from the jars. Share this post Link to post Share on other sites
dells68 7,499 #141 Posted February 2, 2019 Alan, all I can say is WOW! This has been an amazing build. I’ve followed along since the beginning and your level of craftsmanship and attention to detail are second to none! If you only saw the photos with the tractor by itself, you would swear it was a rare D that Wheel Horse had designed. Do you have any other similar builds of other makes and models? 1 1 Share this post Link to post Share on other sites
Alan R. 316 #142 Posted February 2, 2019 6 hours ago, dells68 said: Alan, all I can say is WOW! This has been an amazing build. I’ve followed along since the beginning and your level of craftsmanship and attention to detail are second to none! If you only saw the photos with the tractor by itself, you would swear it was a rare D that Wheel Horse had designed. Do you have any other similar builds of other makes and models? Thanks Dells. Yes, I need to get photo's of the tractor only. Maybe from low level, lying on the ground when the weather warms up. IF i can get up again afterwards that is. Creaking joints don't help. Sorry, no other similar builds but have restored a Sears / Roper GT16 recently and a BMB President years ago. Both shown over on MoM. Stormin Norm has the GT16 now. The BMB is still about somewhere too. 1 Share this post Link to post Share on other sites
dclarke 4,274 #143 Posted February 2, 2019 Absolutely amazing, Alan! A very interesting build to follow. Share this post Link to post Share on other sites
Alan R. 316 #144 Posted February 3, 2019 12 hours ago, dclarke said: Absolutely amazing, Alan! A very interesting build to follow. Thank you. Share this post Link to post Share on other sites
rjg854 13,405 #145 Posted February 3, 2019 On 7/29/2018 at 7:25 AM, rjg854 said: Truly amazing what you are doing, Alan I said it once, but its worth repeating! Amazing 1 Share this post Link to post Share on other sites
Alan R. 316 #146 Posted February 3, 2019 33 minutes ago, rjg854 said: I said it once, but its worth repeating! Amazing . Share this post Link to post Share on other sites
Stormin 9,988 #147 Posted February 3, 2019 2 hours ago, rjg854 said: I said it once, but its worth repeating! Amazing Just not to often please. It'll go right to his head. 1 Share this post Link to post Share on other sites
Alan R. 316 #148 Posted February 3, 2019 3 hours ago, Stormin said: Just not to often please. It'll go right to his head. Now Now Norm. Behave. Share this post Link to post Share on other sites
SylvanLakeWH 32,710 #149 Posted February 3, 2019 Wow! Share this post Link to post Share on other sites
Tractorhead 9,217 #150 Posted February 3, 2019 Alan, that was a pretty awesome Work at all. Fully respect to any of your Work and ideas you realize in that Project. You did a real great job. honestly a thing you can be proud thereon.👍 But one small detail i'm missing, for Doc Emmett Brown, you forgot the white protection suit...😂 The rest is absolutely Scale! But you Pic is realy Great! 1 Share this post Link to post Share on other sites
