19richie66 17,772 #51 Posted September 16, 2017 Awesome work sir! 2 1 Share this post Link to post Share on other sites
Alan R. 316 #52 Posted September 16, 2017 1 hour ago, 19richie66 said: Awesome work sir! Thank you. Share this post Link to post Share on other sites
Alan R. 316 #53 Posted September 27, 2017 Not many photo's of work on the hood. A slightly larger than required alloy sheet was cut and a shallow fold made on the center line. A board with a curved edge was clamped over the sheet, after carefully guesstimating where the side fold should start. Hope that makes sense. The sheet was then bent around the board forming one side of the hood. This was repeated for the other side resulting in a shape which was not far off the required result. What luck. A little tweaking with a rubber mallet and a length of round bar persuaded the front and rear of the curved folds to line up with the headlamp surround and dash. A lot of time was then spent trimming the oversize edges to get the best fit I could manage, followed by clamping to the headlamp surround and drilling for the pivot bolts. 1 6 Share this post Link to post Share on other sites
19richie66 17,772 #54 Posted September 27, 2017 Incredible! 1 Share this post Link to post Share on other sites
Alan R. 316 #55 Posted October 1, 2017 (edited) The fuel tank, non working, was bent up around a scrap wood former. The measurements were again supplied by my man with the tape, Iain, along with good side view photo's which showed the radius of each corner ! Although the base of the tank was wider than the top, all corners were the same radius. The original idea was to bend the alloy around the former then remove it which left the question, how to fix it all together. The obvious solution, apart from alloy welding, was to screw the panels to the wood which would be left in place hidden from sight. Odd bits of wood were dug out, cut to size, and screwed together after first using the ends to mark out and cut the alloy outer plates. These were bolted to the wood with countersunk BA bolts, the heads blended in with filler. The main panel was cut to size and after carefully lining up, was screwed to the underside of the former. Then it was bent around one face at a time, securing with screws before moving on to the next, and finishing on the underside. Where else. All the screw holes were countersunk, the screws again being blended in with filler. The filler neck was a short piece of alloy bar, screwed into place, and finished off with a cap from an oil can. Rubber edge trim was fitted after painting. Edited October 1, 2017 by Alan R. 6 1 Share this post Link to post Share on other sites
Cvans 1,009 #56 Posted October 4, 2017 You've created a real jewel there. Thanks for letting us watch. 1 Share this post Link to post Share on other sites
Alan R. 316 #57 Posted October 14, 2017 Various ideas were tried out for the seat using bits and pieces lying around and then discarded. A visit to a local upholstery shop with measurements resulted in a lottery win quote. Back to head scratching mode. I had already spent hours looking for something suitable on the internet without luck, trying various search word combinations. Then I spotted some cheap-ish scooter ( Lambretta / Vespa ) back rests. Not exactly what I wanted but worth a try. A pair were bought and after initial, not sure thoughts, the end result was better than expected. The fill in piece behind the seat cushion, made from plastic, still needs finishing off with padding. The first mock up from ply. The alloy frame, ex green house, just cleared the top of the gearbox. Fixing brackets were bolted on. Sheet steel was bent up for the base and back rest. There were two short threaded studs already fitted which made mounting easy. A length of U shaped trim finished off the steel plate and a similar section was fitted to the fuel tank. I finally managed to get my Great grandson Henry to try the tractor for size. Even though he is only 7 : 1/2 months he loved it. Mummy said she had never seen him so excited, squealing and swinging the steering wheel. We had to hold him though as mummy refused to let me cable tie him on. 6 9 Share this post Link to post Share on other sites
19richie66 17,772 #58 Posted October 14, 2017 Last picture says it all! Phenomenal work. 4 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #59 Posted October 14, 2017 Let him grow a little more and you two will be fighting over who gets to drive the D. A great picture. 2 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #60 Posted October 18, 2017 you sir are very talented...awesome build Share this post Link to post Share on other sites
Alan R. 316 #61 Posted October 18, 2017 3 hours ago, Professor1990 said: you sir are very talented...awesome build Thank you. Share this post Link to post Share on other sites
AMC RULES 37,254 #62 Posted October 18, 2017 (edited) Calendar shot. Click here to submit your entry... Edited October 18, 2017 by AMC RULES 4 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #63 Posted October 18, 2017 I agree with Craig...DEFINITELY a calendar shot 1 Share this post Link to post Share on other sites
Pullstart 68,667 #64 Posted October 27, 2017 so, when it's time for decals, what will it be? Instead of "D180" are you going to have "d1.80"? Share this post Link to post Share on other sites
Alan R. 316 #65 Posted October 27, 2017 9 hours ago, pullstart said: so, when it's time for decals, what will it be? Instead of "D180" are you going to have "d1.80"? Not `100% decided yet, but probably D - 80 or D -100. Photo's and measurements of D -160's and D -200's were used in the build. Half size model, half the number. 2 2 Share this post Link to post Share on other sites
Alan R. 316 #66 Posted October 29, 2017 After looking for a suitable steering wheel on the internet without success, one was made up. Lots of ready made wheels but too large, too small, near enough the correct diameter but with a rim much too thick for scale etc. A local metal fabricator advertised various scroll work items for gates, garden furniture and so on. A visit was made expecting them to have a ring rolling machine. "Never heard of one" was the reply from one staff member. He called another older person, same answer. When I asked how they made the scroll work they advertised, "We don't, we buy it in ready made from China". Chris, Mr Showman, Sutton had previously mentioned that a friend might be able to roll a ring up. Within a few days I had a 7:1/2" ring x 3/8" section. The hub is a previously drilled cap screw with the spokes from flat strip jammed between two nuts after having a bend made at the inner ends. After trimming the spokes to length and clamping down Chris welded all the joints up. Thanks Chris. I keep thinking I ought to buy a welder but it probably wouldn't get much use. Grinding the welds down was easier than expected, especially around the hub, using a Dremel. A slot was cut in the cap screw head for a roll pin which together with a nut held the wheel onto the column. Two short pieces of tube were pressed / hammered over the nuts and all the joints blended in with filler. The last photo shows the pin resting on the head of the cap screw which is the column bush. This still needs a sleeve over it to finish off. Also a cap made for the wheel center. I should have made the spokes with a steeper angle but too late now. My great grandson, pictured above, liked it anyway. 7 3 Share this post Link to post Share on other sites
chris sutton 610 #67 Posted October 29, 2017 Happy to help, you have to know the right people, 3 Share this post Link to post Share on other sites
Alan R. 316 #68 Posted November 19, 2017 (edited) The original muffler which.was used for the test runs was unsuitable for scale appearance and was also in the wrong position. A 180 degree bend to fit within the side panels was needed. I tried a length of flexi pipe I had but this wouldn't bend into a tight enough radius. A piece of 15mm copper pipe was bent up using an ancient and crude pipe bender ( found at friend John's place ) where else, which gave the required result. The exhaust stub on the engine is approx 22mm outside diameter although the bore is a lot smaller. An adapter was turned up to suit. During the clear out at John's various stainless steel mufflers were found which John had made at work. This one was removed from a mower and cleaned up. This was connected to the copper pipe via an old 90 degree plumbing elbow after cleaning off all the muck. After finding a length of chrome plated water plumbing pipe a posher version was bent up. No prizes for guessing where these two items came from. Not sure how this pipe and the plating will stand up to the exhaust heat, but not the end of the world if it doesn't. An extension was made for the muffler again from copper pipe, as I didn't have anything else of a suitable diameter. This was drilled and the lower end plugged as per the full size. An adapter ring was turned up, drilled and tapped to hold everything together. This ring also located the assembly into the grill surround. The completed parts and after fitting. Still need to make some adjustments. Edited November 19, 2017 by Alan R. 2 2 Share this post Link to post Share on other sites
dells68 7,499 #69 Posted November 19, 2017 Alan, this is incredible! I'd give my left wingnut for that thing. Wait, just checked, wife got that one when we got married ! Sorry, couldn't resist. That tractor is a work of art! 3 1 Share this post Link to post Share on other sites
Alan R. 316 #70 Posted November 19, 2017 14 minutes ago, dells68 said: Alan, this is incredible! I'd give my left wingnut for that thing. Wait, just checked, wife got that one when we got married ! Sorry, couldn't resist. That tractor is a work of art! . The tractor Emory is restoring for you looks brilliant. Can't wait to see your face at Christmas. 2 1 1 Share this post Link to post Share on other sites
RandyLittrell 3,943 #71 Posted November 20, 2017 Holy Cow!! You Sir, are an artist!! Thank you for sharing, I love the work you have done! Randy 1 Share this post Link to post Share on other sites
Alan R. 316 #72 Posted November 20, 2017 9 hours ago, RandyLittrell said: Holy Cow!! You Sir, are an artist!! Thank you for sharing, I love the work you have done! Randy Share this post Link to post Share on other sites
slim67 2,822 #73 Posted November 20, 2017 It's a work of art ! Share this post Link to post Share on other sites
Alan R. 316 #74 Posted November 20, 2017 1 hour ago, slim67 said: It's a work of art ! Share this post Link to post Share on other sites
RandyLittrell 3,943 #75 Posted November 21, 2017 13 hours ago, Alan R. said: You should know, I am a body man and auto glass tech. I know when I see great work. I hope you will be able to pass your talents on to your grandchild! Randy 2 Share this post Link to post Share on other sites
