Jeffreyg0565
Recently mowing lawn treactor won't go into any gear. Not sure if there are belt tensioner or if needing new belt. Any help would be greatly appreciated.  P.S. I don't have owners manual so I'm not even sure how to adjust or change belt.  Thanks Jeff
953 nut
:WRS:     If you will tell us the year and model number we can fix you up with a free download for an owner manual. When you say it won't go in gear please be a bit more specific. Is this a problem that just occurred or one that has gotten worse? Will it seem to go into gear while stationary with the engine shut off, but grind gears when running? We need a bit more to go on here.
  • Like 5
N3PUY
Sounds like he is saying "won't GO in any gear".  Like it won't "move" in any gear.  My thoughts are first check the axle hubs and the input pulley.
Jeffreyg0565
I have since fixed the problem. I had some how taken it out of high. The lever was between high and low. Thank you all for the help P.S.  new owner 😳😀😀👊
  • Like 4
Racinbob
Now there's something we've all done. Some of us more than once........many more :blink:
:WRS: and enjoy the forum.
953 nut
Glad you found the problem. If you go to the "Manuals" tab at the top of the page and search for your year and model you can download one for free.
BOB ELLISON
If we keep getting Michigan guys on here we can have our own Big Show.
  • Like 5
steelman
I went to a show a few years back at the fair grounds in Charlotte MI. I didn't have much time to spend there but recall there being 6 or 8 guys there with WH but mostly farm tractors.
  • Similar Content
    • rustyedge1
      By rustyedge1
      Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
      This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
      Any info on better made belts appreciated..
    • River Rat
      By River Rat
      I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
      Any help is appreciated!
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • seven
      By seven
      Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
