Similar Content
By jmack
What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
Just shredded mine today.
By ryobi.warrior
The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
By seven
Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
By JackHorse
Hi Guys, Had a random occurrence this week. Mowing along with my C85 eight speed in 1 low (grass was thick and wet), went to depress clutch and the drive belt jumped off the idler. I've had this tractor 3 years and it's been working great. The belt itself looks good except the top of it was a bit chewed up in a short section which I believe happened after it came off. I put the belt back on and continued to mow with no further issue. Any ideas as to why this would happen or adjustments I might need to make to prevent another incident? Thanks
By chsteinke44
i need help finding the right size drive belt for my 212-h wheel horse and the diagram for installing the belt. i got the tractor from my wifes grampa and cant find the diagram for it or a replacement belt for it. the id tag is 3212be01 46590
the belt i need is the motor to transmition
