Mikey the Monkey 701 #1 Posted July 9, 2017 Hay everyone. I'm in the middle of my first restoration on a 701. I've got it all tore apart. Now I want to paint it and put it back together. I was hoping to glean some tips and tricks from the experts, like best ways to clean and prep everything? Do you paint pieces separate and then put together, or put them together then paint? Best way to clean oil and crap off engine that's been there for 40 years. Share this post Link to post Share on other sites
varosd 1,185 #2 Posted July 9, 2017 Mike, There numerous old posts that you can search through on this website,. All the restoration opinions on the best penetrating oil, rust removal, prep for paint and to final paint or powder coat etc etc Share this post Link to post Share on other sites
953 nut 63,031 #3 Posted July 9, 2017 There are a bunch of ways to get the job done. Jay did a great job of documenting every step and received a lot of input during his 854 restoration. Take a few minutes and read through it, use it as a reference during your project. Oh, one more thing, 1 Share this post Link to post Share on other sites
JPWH 6,542 #4 Posted July 9, 2017 I had never done any body work before my 854 build. I did a lot of studying and followed the advice I was given here on RS. I will say the prep work is important for a good finish. I would paint pieces and give the paint a few days to harden before assembly. 1 Share this post Link to post Share on other sites
varosd 1,185 #5 Posted July 9, 2017 like everyone has said, prep, pre, prep is the key! also depends on the end result that you want. do you want a show queen or a worker? numbers matching or is NOM (not original motor)? ok. wait.... sorry... was thinking about our muscle car brethren but it is the same. " Oh, that washer is a hair thicker than what came from the factory" ha ha! spray bomb or automotive paint? lots of info on this site and looks of help! Share this post Link to post Share on other sites
Mikey the Monkey 701 #6 Posted July 9, 2017 Thanks for pointing me in right direction. Is it OK to just clean off w diesel, carb cleaner and paint? Share this post Link to post Share on other sites
JPWH 6,542 #7 Posted July 9, 2017 The best thing would be follow the directions from whatever paint manufacturer you are using. Share this post Link to post Share on other sites
953 nut 63,031 #8 Posted July 9, 2017 2 hours ago, Mikey the Monkey said: clean off w diesel, carb cleaner and paint? If you want a good smooth finish that will last you can't take shortcuts. If you just want it to have a so-so paint job that will look OK from a distance then yes, get most of the crud off and cover the rest. 1 Share this post Link to post Share on other sites
Mikey the Monkey 701 #9 Posted July 9, 2017 OK...what's the long cut? Share this post Link to post Share on other sites
953 nut 63,031 #10 Posted July 9, 2017 7 minutes ago, Mikey the Monkey said: OK...what's the long cut? The proper way is to do as Jay did, remove all paint and other surface coatings down to bare metal, use an etching primer and build up with a couple of coats of primer then wet sand to a smooth finish prior to application of the color coat. 1 Share this post Link to post Share on other sites
RandyLittrell 3,942 #11 Posted July 9, 2017 I find the best way to clean things up before painting, is to use ez off oven cleaner. Spray it down, wait the recomended time, then haul it to the car wash and pressure wash it off. It will get all the grease off and sometimes a little paint. So, don't use it if your not gonna be painting it. I also will the tires cleaning setting at the car wash too. The two things combined will really get things clean. Randy Share this post Link to post Share on other sites
Mikey the Monkey 701 #12 Posted July 9, 2017 Thank you Randy Share this post Link to post Share on other sites
Digger 66 3,488 #13 Posted July 9, 2017 1 hour ago, RandyLittrell said: I find the best way to clean things up before painting, is to use ez off oven cleaner. Randy EZ Off is a great degreaser , but it is also very corrosive / caustic . If you go this route , be sure to THOROUGHLY RINSE every single part this may come in contact with with the hottest water you can find . I use EZ Off on the radiator of my wheeler every fall but it's out of the bike and after it has sat the recommended time it gets submerged and rinsed in the wash tubs . The stuff works great but it's N A S T Y ! 1 Share this post Link to post Share on other sites
953 nut 63,031 #14 Posted July 9, 2017 3 minutes ago, Digger 66 said: very corrosive / caustic It is mainly Sodium Hydroxide (caustic soda), use eye protection and a face shield as well as long rubber gloves. It will pull all of the oils out of your skin and make some nasty burns if you get it in your eyes. It works, but be cautious. 5 Share this post Link to post Share on other sites
ebinmaine 75,769 #15 Posted July 9, 2017 for the EZ off methods - it sure does work well... and Good reminders about the Safety needed when handling the stuff. 2 Share this post Link to post Share on other sites
ebinmaine 75,769 #16 Posted July 10, 2017 Also, don't spray easy off on aluminum unless you're going to rinse it off almost immediately. 3 Share this post Link to post Share on other sites
oliver2-44 11,062 #17 Posted July 15, 2017 if you don't have access to a sandblaster and want to remove all the rust and old paint down to bare metal use an e-tank. (electrolysis tank) google e-tank Share this post Link to post Share on other sites
Texas Todd 1,025 #18 Posted July 15, 2017 I have found a wire wheel on an angle grinder is effective. I use it for parts I can't get in my blaster cabinet. 1 Share this post Link to post Share on other sites
Mikey the Monkey 701 #19 Posted July 15, 2017 thanks Todd and oliver! When sandblasting, is it nessesary to clean old oil and grease off really well with chemicals? Or just scrape off as best you can with putty knife and blast the snot out of it? 1 Share this post Link to post Share on other sites
Texas Todd 1,025 #20 Posted July 15, 2017 (edited) I would power wash or use simple green (some degreaser) or something to get the worst of it off and then blast or wheel. The blast media will take it off, but if in a cabinet, it will just recycle it back through the gun. And go from this to that! Edited July 15, 2017 by Texas Todd 2 Share this post Link to post Share on other sites
953 nut 63,031 #21 Posted July 15, 2017 9 hours ago, Texas Todd said: wire wheel on an angle grinder Be sure to wear a heavy old coat and a face shield, when those wires begin to come out the go everywhere. Share this post Link to post Share on other sites
Texas Todd 1,025 #22 Posted July 16, 2017 12 minutes ago, 953 nut said: Be sure to wear a heavy old coat and a face shield, when those wires begin to come out the go everywhere. Amen to that! Had one jump out my hands and rolled up in my t shirt. Could have been brutal. Respect the grinder!!! 1 Share this post Link to post Share on other sites
19richie66 17,765 #23 Posted July 16, 2017 11 hours ago, Texas Todd said: Respect the grinder!!! 1 Share this post Link to post Share on other sites
ebinmaine 75,769 #24 Posted October 21, 2017 On 7/9/2017 at 4:39 AM, Mikey the Monkey said: paint it and put it back together I found this Topic when I was looking for painting tips... just wondering how it's coming along? Share this post Link to post Share on other sites
Mikey the Monkey 701 #25 Posted October 21, 2017 I'm sorry and embarrassed to say it's still in pieces. Been working 7 days a week and doing yard work getting ready for winter. I did buy the HF sprayer though! 1 Share this post Link to post Share on other sites
