elliot ness
The Making of another loader
WHX??
Looks like you picked a good foundation! :handgestures-thumbupright:
  • Like 4
slammer302
Looks great so far.
slammer302
What made you decide to go with the C-160? That 318 parked next to it would make a good candidate.
WHX??
You in the right forum slammer?:ychain:
slammer302
I love my WH's but the JD 318 is a nice machine very similar to a XI. :wh:
12 hp Kohler
Looks great can't wait to see your progress as the project goes on
DennisThornton
elliot ness
The 318 is what my garage cat sleeps on, and she said no.
DennisThornton
I had to reread this in the daylight.  Missed the "JD" and saw just the "318". Now I understand!  Yes! I'd like to add some green to the herd and any of the 300 JD series would suit me just fine.
hcminis
very cool
Popasmurf
I need one of those.  I'm buying a new home that needs lots of yard work.
great job I can't wait for the next installment!
RedWheelz
Looks very well built!!
Do you have plans for this loader ?
Popasmurf
Plans for that loader would be a great thing. I'm sure a lot of folks would like to build one. Myself included.
Digger 66
I can't wait to see the movie :auto-driving:
Popasmurf
I'm sure it will have an Allstar cast and show case the original designer !
Duramax7man7
I'm curious why people don't choose to go with a 4 way joystick valve?
Popasmurf
Is the cost less to go with the joy stick? Is it easier to control?
Duramax7man7
From my inquiries, it seems that the cost of 4 way joystick is more than a 2 spool valve but it a lot easier to use and smother to operate.
elliot ness
The plan will be to sell it.
Popasmurf
After it sells can we get plans? Lol  great job!
elliot ness
I never use plans, I start with square tubing set two pieces on a table and find the angle that looks right, mark it and cut it and weld it, and make a double for the other side. Then make a bucket using 1/8 plate, and 1/2 cutting edge, make the mounts for the cylinders, then comes the fun of getting the hoses and metal lines where you need them. I have made many loaders and everyone turns out different. I go to the metal shop and try to buy all the short cut pieces they got to save money. Hope this helps, If you start on one and have questions, PM me and I will try to help. some where in red square I have put a few of the loader that I built.
Edited by elliot ness
Popasmurf
Thanks for the insight. I'm shire it will come in handy.
DennisThornton
I learned on a joystick and very quickly.  I'm guessing I'd look like an idiot on a two spool.  Same on a backhoe only worse!
Duramax7man7
I've used to multi-spools on other equipment so I'm sure I would be fine but I really love the idea of joystick. when I make a loader I'll be doing my best to use a joystick.
