melonman
T-Series?? B80 in white w/electric lift... "White Unicorn"?
melonman
Hey Guys, any help with ID or info on this possibly rare bird? It appears to be the original paint but idk for sure. Alo, a B series with electric lift rather rare I think HUH?
Racinbob
It's a 74 or 75 and not likely the original paint. There appears to be white paint on some wiring and the choke cable. The electric lift was a pretty common add on. I had one like that but didn't care for the foot rest being moved out to clear it. But it's interesting.:)
melonman
Yes, good eye-paint on the cables-I missed that good job Racinbob!!
rmaynard
I agree with Bob on this one. I think it's a repaint. There have been many threads on different factory applied color. Red was what Wheel Horse painted their tractors, and if a multi machine purchaser like a municipality wanted their tractors painted a different color, it was usually done at the dealer level.
Just my :twocents-02cents: worth.
Nice B-80 anyway.
  • Similar Content
    • Barbara
      By Barbara
      312-8, purchased 1986, but may be a 1985. Original Kohler engine, still starts and runs if if jumped. Professional valve job 40 hours ago. Needs bearing to deck PTO.
      Sheet metal dented and banged up. Seat has tears. Deck needs to be replaced. Would keep, but unable to do own rebuild, have new tractor. Pick up
      by appointment only, at your own risk.
    • WildHorses
      By WildHorses
    • WildHorses
      By WildHorses
    • Gary S Minnesota
      By Gary S Minnesota
      Hi everyone,
      I'm having a battery draw down issue on my 516-H equipped with a factory electric lift for the deck/snow blower.
      I connected an ice pick/alligator clip trouble light between the negative battery post and the ground cable.  It glows!  I then began removing circuits until the light no longer glowed.  The only circuit that had an effect( made the light go out) was when I removed the electric lift relay from it's holder.  Upon doing so ,the light the light immediately went out.  I tested the relay with a multi meter and it seems to be good.  I then replaced  the momentary up/down switch thinking it might be feeding the relay NC circuit some current.  No change.  The electric lift wiring harness has a lead going directly to the pos. battery terminal.   It also has a lead to the negative battery terminal.  As soon as I connect the negative ground wire I can hear a slight "click" as the wire touches the neg battery post bolt connector.
      I have not been able to find the manual for the electric lift.  I have seen photos of the same lift here on the forum from time to time. Don't know the brand.
      If I remove the relay the electric lift relay battery holds its' charge just fine?
      Any suggestions?
      thank you!
    • Jennifer
      By Jennifer
      Well got my new weight yesterday!  My valentines gift from my husband now has the front weight less likely to pop those wheelies!!!!  There might be enough power still but doubt it…. He bought me the RJ from David in Arkansas a few years back we posted on the trip!  The moment we saw the ad on here about the front weight we had to have it!  Seize the moment, don’t know when ever come across another for sell…!  So here I just wanted to share pictures of it!  My tractor is a bit dirty from winter setting but i wipped it down just a little for the photo opt!!
