mikeeyre74 290 #1 Posted June 16, 2017 While cleaning up the front axle for a restoration I'm doing, I noticed this funny cast in notch on this axle… I checked a few others that I have in the yard and they are all there in the same spot but I can't figure out what they're for? Does anybody know what the history is? 2 Share this post Link to post Share on other sites
Uncle Buck 246 #2 Posted June 16, 2017 Unless there is a matching notch on the other side I would say it must be due to some sort of wear. I would use that part though if it was mine. I do not see that as causing failure of the axle. Or that notch could have been engineered into the part originally for clearance for a belt or attachment or something. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #3 Posted June 16, 2017 (edited) That's the 520 swept forward axle correct? It's for the mower/blower PTO belt clearance, or for tie rod clearance when turned full lock, Jeff. Edited June 16, 2017 by WVHillbilly520H 3 Share this post Link to post Share on other sites
mikeeyre74 290 #4 Posted June 16, 2017 No, it is neither the 520 forward swept axle or a wear mark. I have 6 bone stone standard axles off B and C series tractors and 300 series too, and they all have these notches. They're cast into the original axle shape, not machines or worn in there... they're on the left hand side of the machine as you're sitting on it, so it's not like it's even a clearance for the PTO belt, because that would be on the opposite (right hand) side. Share this post Link to post Share on other sites
tunahead72 2,662 #5 Posted June 16, 2017 I'll be darned, I just checked my '86 310-8, and sure enough that notch is there on my axle too. I never noticed that before, now you've got me curious. 2 Share this post Link to post Share on other sites
Uncle Buck 246 #6 Posted June 16, 2017 I think you can bet the notch was designed into the part for whatever reason. Now you just need someone that can confirm what that relief point was designed into that part to accommodate. 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,066 #7 Posted June 16, 2017 Checked my 310-8 and 1995 312-8, both have the notch. Share this post Link to post Share on other sites
slammer302 2,157 #8 Posted June 16, 2017 It's a steering stop I believe. Share this post Link to post Share on other sites
Cee245 861 #9 Posted June 17, 2017 Slammer, I don't think he's talking about the steering stop.... This is a 416h axle pto side. Doesn't have the notch. So it's just the 300,C, and B series? And I've seen how the 520 has their notch. 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,066 #10 Posted June 17, 2017 It's the flywheel side which has the notch. My 74 C-160, 87 414-8 and 94 416-H all have the notch as well. Great question, hope we can figure this out. 3 Share this post Link to post Share on other sites
Cee245 861 #11 Posted June 17, 2017 I think I've figured it out. If you go out to your tractor and turn the wheel all the way left. Look on the flywheel side (left) and then look underneath, you should see where the part that holds the tie rod would bind on axle if not for the notch being there. Looks like it helps with turning radius. Cory 5 Share this post Link to post Share on other sites
Chris G 3,392 #12 Posted June 17, 2017 Great Question. I got two extra front axles on the shelf from 8hp 4speeds. With the same notch. Noticed a few years ago and never could figure it out. 1 Share this post Link to post Share on other sites
EricF 589 #13 Posted June 17, 2017 Interesting! Yet another little bit of thoughtful engineering "magic" that offers up better performance (tighter turning radius here) than the competition, which is nearly invisible to buyers/owners. It "just works better". Little engineering touches like that were often discouraged by big companies, even in the era of the 1960s-70s -- it costs money to design and build the tooling as it gets more complex; over-engineering was discouraged. Of course, other manufacturers tended to use a design for a few years -- a decade at most, and then move on to a newer design. However much more Wheel Horse may have spent on engineering, they recovered and earned back several times over by keeping the same designs in use nearly forever. It's not even over-engineering, it's engineering to the maximum practical benefit. Things like that add up -- that's why 20, 30, 40, 50 -year old-and-beyond tractors can still out-work newer ones! 3 Share this post Link to post Share on other sites
squonk 48,229 #14 Posted June 17, 2017 None of my 3 tractors has that notch. but the location lines right up with the PTO belt to mower deck travel area. Just like in Hillbilly's first pic. If the belt is loose enough it will flop and rub against the axle. Also if you use too short a PTO belt the mule drive pulleys may contact the axle. I have seen this happen. Perhaps WH decided to give a little room in that area to keep the belt and pulleys from being damaged. Share this post Link to post Share on other sites
nylyon-(Admin) 9,066 #15 Posted June 17, 2017 The notch is on the flywheel side, not the PTO 2 Share this post Link to post Share on other sites
Racinbob 13,213 #16 Posted June 17, 2017 Cory nailed it. The front of my 76 is up in the air right now. It's to clear the spindle arm when fully turned to the left. Compare the right and left steering stops. The one on the right is 'taller' than the left and the arm hits it before the notch is needed and the turning radius isn't as tight as the left. Then, looking at my 500 Special that has a blade on it if the right turn was as tight as the left the tire would rub on the rod running up to the blade to angle it. 3 Share this post Link to post Share on other sites
squonk 48,229 #17 Posted June 17, 2017 Ok. Looks like Hillibliiy's pics are of different notches than Mikee's. (sent from in front of the A/C with crapatalk) 3 Share this post Link to post Share on other sites
rmaynard 17,613 #18 Posted June 17, 2017 (edited) So I'm still confused. I went out to the shed and pulled two horse out. The 1977 B-100 and 1968 Commando 8. Both have the same axle, both have the notch. The notch are on the underside and are depicted by the yellow lines. With the wheels turned left to the full extent, the spindle arm of the B-100 does not enter the notch. The Commando 8 is the same. I tried to get a shot from the underside of the B-100 as well. If the spindle arms are disconnected from the tie-rods, yes, they can move into the notch, however under normal operating conditions that is not the case. I'm still scratching my head. Edited June 17, 2017 by rmaynard 2 Share this post Link to post Share on other sites
Cee245 861 #19 Posted June 17, 2017 Not sure @rmaynard On my 97 416, the spindle arm enters the notch most noticeable from underneath. Now, if you use the steering wheel to turn all the way left, the spindle arm doesn't enter the notch as much as grabbing the tire and pulling it a little further into the notch. I just did this... try it, and let me know Cory 1 Share this post Link to post Share on other sites
Racinbob 13,213 #20 Posted June 17, 2017 That's weird. My 160 wouldn't hit the stop if not for the notch. I lowered it to the ground and the same thing. Same with the 500 Special. Bob, what is physically stopping your steering? 2 Share this post Link to post Share on other sites
rmaynard 17,613 #21 Posted June 17, 2017 I have to agree with Cory that the notch is for spindle arm clearance, however, I turned the steering wheel and pulled the tire on both tractors, and the results were the same, not even close to the stop or the notch. However...the 416-H is a different story. Thanks for starting an interesting thread. There's always something new to be learned. 5 Share this post Link to post Share on other sites
squonk 48,229 #22 Posted June 17, 2017 I rechecked my axles after I was confused by Hillbilly's pic of the notch on his PTO side. My C-160 and 1267 have the notch but my 520 which does not have the original axle on it does not. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #23 Posted June 18, 2017 Sorry for the confusion, from the original pic the axle looked slightly skewwed (or swept) to me but on the same token I did say... On 6/16/2017 at 3:32 PM, WVHillbilly520H said: , or for tie rod clearance when turned full lock, Jeff. Jeff. 1 Share this post Link to post Share on other sites
19richie66 17,937 #24 Posted June 18, 2017 The Ponds cast that there so 45 years later a bunch of guys would be sitting around going "wonder what that notch is there for?" 10 Share this post Link to post Share on other sites
tunahead72 2,662 #25 Posted June 19, 2017 I think somebody just has to ask Terry (TT) if he goes to the big show this week, he'll know! 1 Share this post Link to post Share on other sites
