squonk 46,095 #26 Posted June 17, 2017 Might want to think about cleaning the underside of the deck as well and make sure the belt tensioner /slider on the deck itself is working correctly. Share this post Link to post Share on other sites
Racinbob 12,896 #27 Posted June 17, 2017 If the PTO quit spinning when it bogged down then your PTO clutch needs adjusting. You're not getting a good engagement. Maybe the lining is shot. Also, I'm not real familiar with hydros but I'm thinking the first picture showing the tractor drive belt is fine. The belt doesn't run across the top of the belt guard like a manual does. In any case, it's not related to the mower issue. 1 Share this post Link to post Share on other sites
oldlineman 1,674 #28 Posted June 17, 2017 you should have a spacer between the two pulleys on the mule drive so that the two pulleys do not touch each other. 2 Share this post Link to post Share on other sites
zeke37 24 #29 Posted June 17, 2017 I am now holding the PTO shaft in my hand. Sure there are other parts to be replaced. How far should I go? I'll send a pict as soon a it becomes available. -Thanks....Tim Share this post Link to post Share on other sites
Ed Kennell 45,732 #30 Posted June 17, 2017 PTO or mule drive? Share this post Link to post Share on other sites
zeke37 24 #31 Posted June 17, 2017 Hello- think I figured it out., the PTO shaft seems to have sheared the bolt in. I have removed the pulley. what next..don't want bang on anything too much,.....any info is much appreciated... Share this post Link to post Share on other sites
953 nut 65,210 #32 Posted June 17, 2017 10 hours ago, zeke37 said: Yes it did, and i just downloaded a drawing of the mule drive and spacers and it is clear that I am missing one. So if the PTO stops when I am mowing tall grass is there something else I need to look at? Thanks again. If the spacers are missing from the PTO your pulleys are causing a significant drag which probably contributed to the clutch problem. You need to address both problems. Share this post Link to post Share on other sites
