tobrien1949@yahoo.com 0 #1 Posted June 12, 2017 How do I determine fuel pump arm is above cam that drives pump, it's a kohler 10 hp Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted June 12, 2017 When installing the fuel pump, angle the pump down and insert the arm into the block. If you have it above the cam (as it should be), you should feel a slight resistance angling it back up to install the mounting bolts. 2 Share this post Link to post Share on other sites
rmaynard 17,230 #3 Posted June 12, 2017 This is a typical mounting position. As Paul said, tilt the pump as depicted below. You can also shine a light into the hole to see where the cam is, and aim the arm over top of it. 4 Share this post Link to post Share on other sites
jay bee 915 #4 Posted June 13, 2017 Thanks for asking the question tobrien1949!!! I learn something every time I read these posts...and to Jim Share this post Link to post Share on other sites
dcrage 634 #6 Posted June 13, 2017 Answer to a question I have had for a long time. 1 Share this post Link to post Share on other sites
