Ramanonos 17 #1 Posted June 2, 2017 Clicking on starting. C-125 with 12hp Kohler. I purchased a new cheapo starter on eBay about six months ago. I swapped that out with the old starter in to test whether it would at least spin and it did not. What do you think it is and what should I check next? See video Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #2 Posted June 2, 2017 The engine on a C-125 sits on a steel plate and the plate sits on rubber isolation mounts on the tractor frame. There is a ground cable between the plate and the frame. Have you checked it? Garry Share this post Link to post Share on other sites
pfrederi 19,815 #3 Posted June 2, 2017 (edited) What is your battery voltage?? How old is the battery?? Edited June 2, 2017 by pfrederi Share this post Link to post Share on other sites
953 nut 64,007 #4 Posted June 3, 2017 With any electrical problem the first step is to have the battery load tested and clean and tighten all electrical connections including grounds. Share this post Link to post Share on other sites
squonk 45,411 #5 Posted June 3, 2017 16 hours ago, Ramanonos said: Clicking on starting. C-125 with 12hp Kohler. I purchased a new cheapo starter on eBay about six months ago. I swapped that out with the old starter in to test whether it would at least spin and it did not. What do you think it is and what should I check next? See video Wheel Horses have a built in safety that won't allow it to start if someone is near it with bare feet! 1 Share this post Link to post Share on other sites
Texas Todd 1,025 #6 Posted June 3, 2017 Try jumping it across the solenoid and see what you get. Share this post Link to post Share on other sites
Ramanonos 17 #7 Posted June 4, 2017 Thanks all! It ended up being a frayed ground wire on the frame plate.Simple fix. Share this post Link to post Share on other sites
953 nut 64,007 #8 Posted June 4, 2017 8 minutes ago, Ramanonos said: Thanks all! It ended up being a frayed ground wire on the frame plate.Simple fix. Just as Garry @gwest_ca said it would be. 1 Share this post Link to post Share on other sites
